  3. avoidance collision prevention disabled
voxl-2
41 Posts 4 Posters 26.3k Views 1 Watching
  • ? A Former User
    [[topic:post-is-deleted]]
    @AP123 might be worth trying this to see if the voxl-vision-px4 is handling the avoidance data correctly: https://docs.modalai.com/voxl-vision-px4-collision-prevention-0_9/#debugging-collision-prevention
    ? 1 Reply Last reply
      • ? A Former User
        @AP123 When you click on Not Ready does it give you any more info?
          • ? A Former User
            @AP123 What hardware setup are you using? One of our drones or a custom setup?
              • ? A Former User
                @AP123 It's possible, I would take a look here as well for some relevant info: https://docs.modalai.com/configure-extrinsics/
                ? 3 Replies Last reply
                      • ? A Former User
                        @AP123 I'm at the end of my personal knowledge with VOA, I'll see if I can tag someone in
                          • ? A Former User
                            Cliff WongC Offline
                            Cliff WongC Offline
                            Cliff Wong
                            @AP123 Hey there. Are you running VOA against a stereo camera pair or via a ToF sensor?
                            If you run voxl-inspect-points voa_pc_out and see data, then the voxl2 SDK services are good and generating the correct mavlink obstacle distance points to PX4. If not then there's a configuration issue.
                            If that is good, then you need to make sure PX4 has
                            MPC_POS_MODE = Simple pos control or smooth pos control, COM_OBS_AVOID is enabled, CP_DIST > 0 (e.g. 2) and you must have an established home position (or good position from qvio if that is the case). Typically an "obstacle system not ready" is due to the MPC_POS_MODE (I think we default to acceleration-based input).
                            If all those check out, then it's likely missing a home position requirement in PX4 & not voxl, and we'll need to look that up.
                            • Cliff WongC Cliff Wong
                              #31
                              • ? A Former User
                                @AP123 We just released SDK 1.1 yesterday which contains a few months worth of bug fixes, I would recommend loading that and seeing if your issue is resolved
                                  • ? A Former User
                                    @AP123 No, didn't realize you were tackling that as well. M0065 PWM support will be in SDK 1.1.1 and we're actively polishing / testing that release and hope to have it out in the next couple weeks
                                      • ? A Former User
                                        @AP123 We don't have any known issues with the 4 in 1 escs. If you have an issue can you open a new thread?
                                          wilkinsafW 1 Reply Last reply
