  3. avoidance collision prevention disabled
voxl-2
41 Posts 4 Posters 26.3k Views 1 Watching
  • ? A Former User
    [[topic:post-is-deleted]]
    @AP123 When you click on Not Ready does it give you any more info?
    ? 1 Reply Last reply
      • ? A Former User
        @AP123 What hardware setup are you using? One of our drones or a custom setup?
          • ? A Former User
            @AP123 It's possible, I would take a look here as well for some relevant info: https://docs.modalai.com/configure-extrinsics/
            ? 3 Replies Last reply
                  • ? A Former User
                    @AP123 I'm at the end of my personal knowledge with VOA, I'll see if I can tag someone in
                      • ? A Former User
                        Cliff WongC Offline
                        Cliff WongC Offline
                        Cliff Wong
                        @AP123 Hey there. Are you running VOA against a stereo camera pair or via a ToF sensor?
                        If you run voxl-inspect-points voa_pc_out and see data, then the voxl2 SDK services are good and generating the correct mavlink obstacle distance points to PX4. If not then there's a configuration issue.
                        If that is good, then you need to make sure PX4 has
                        MPC_POS_MODE = Simple pos control or smooth pos control, COM_OBS_AVOID is enabled, CP_DIST > 0 (e.g. 2) and you must have an established home position (or good position from qvio if that is the case). Typically an "obstacle system not ready" is due to the MPC_POS_MODE (I think we default to acceleration-based input).
                        If all those check out, then it's likely missing a home position requirement in PX4 & not voxl, and we'll need to look that up.
                        • Cliff WongC Cliff Wong
                          #31
                          • ? A Former User
                            @AP123 We just released SDK 1.1 yesterday which contains a few months worth of bug fixes, I would recommend loading that and seeing if your issue is resolved
                              • ? A Former User
                                @AP123 No, didn't realize you were tackling that as well. M0065 PWM support will be in SDK 1.1.1 and we're actively polishing / testing that release and hope to have it out in the next couple weeks
                                  • ? A Former User
                                    @AP123 We don't have any known issues with the 4 in 1 escs. If you have an issue can you open a new thread?
                                      wilkinsafW 1 Reply Last reply
                                      • ? A Former User
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        @AP123 This is a shot in the dark, but can you turn off your GPS and Mag and see if that works. We tried to do collision prevention with GPS on and we were getting these errors
                                        • wilkinsafW wilkinsaf
