  3. VOXL camera configuration
30 Posts 4 Posters 9.5k Views 4 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    Is it possible to have Hires + Stereo camera configuration only, for the Seeker? The configuration listed for the #13 option.
    available camera configurations are as follows:
    0  None
    1  Tracking + Stereo(OV7251)
    2  Tracking Only
    3  Hires + Stereo(OV7251) + Tracking
    4  Hires + Tracking
    5  TOF + Tracking
    6  Hires + TOF + Tracking
    7  TOF + Stereo(OV7251) + Tracking
    8  Hires Only
    9  TOF Only
    10 Stereo(OV7251) only
    11 Tracking + Hires + Dual Stereo(OV7251) Pairs
    12 Stereo(OV9782) only
    13 Hires + Stereo(OV7251)
    If so, is it possible to use one of the stereo cameras as a tracking camera?
    The reason why I am asking is because I would like to use the Seeker solely indoors and am having way too much trouble recording/capturing UVC frames to an SD card.
    Would both the IMX412 and the IMX377 image sensors work for this type of setup. I understand that the IMX412 would not fit inside the VOXL, but could the MIPI cables be extended to mount the camera between the VOXL flight and the battery of the Seeker?
      Please do not try to modify the Seeker, it is unlikely you will be successful.
      Have you tried to log your UVC camera on a linux computer? can you use that same method on VOXL?
      KrisK 1 Reply Last reply
      • Chad SweetC Chad Sweet
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        @Chad-Sweet
        I apologize if I gave the impression that I am trying to modify the Seeker.
        I am just wondering if it is possible to use Hires + TOF + Stereo, with one of the stereo cameras acting as a tracking camera. If it is possible I would gladly purchase one of ModalAi's Hires cameras. At the moment, I am using TOF + Tracking + Stereo and attempting to stream and record a UVC camera.
        Yes, I have tried viewing my UVC camera on my linux PC with several programs like OBS, guvcview, and Gstreamer.
        I am able to log my UVC video using gstreamer on my linux PC as well.
        However, when I try to connect my UVC camera on VOXL1 for the voxl-uvc-server, I receive this error;
        voxl:~$ voxl-uvc-server -d
        Enabling debug messages
        voxl-uvc-server starting
        UVC initialized
        Device found
        uvc_open failed
        UVC exited
        voxl-uvc-server ending
        I have also tried using Gstreamer on the VOXL but I am not able to get a connection.
        Here is the pipeline I used to stream the UVC camera on VOXL;
        gst-launch-1.0 -v v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
        I am not able to get a successful connection to the UVC camera on the VOXL. The led on the camera lets me know when there is a successful connection, and only the power led was on.
        I have tried a simple capture and send video command but this did not work either. I have tried all my dev/video options (video0~video3) but none of them work.
        gst-launch-1.0 v4l2src device=/dev/video0 ! decodebin ! omxh264enc ! rtph264pay ! udpsink port=8554
        Is there a way to install v4l2-utils on the VOXL1?
        Since the VOXL is not able to communicate/recognize the attached UVC h264 camera, than I think that VOXL might be missing the v4l2-utils package that my UVC camera needs.
        Does the voxl-utils ipk contain the v4l2 parameters?
          To change the image sensor on Seeker, you would have to disassemble the front end which would likely result in damage. It is really not recommended.
          gstreamer should work similar to your USB setup on your Linux PC. Do you have a gstreamer command that is working on your PC?
          if you type ls -la /dev/video* with your camera plugged in and unplugged, you should easily see which device it is enumerating to
          What is the exact module number of the camera you are trying to install?
          KrisK 3 Replies Last reply
            KrisK Offline
            KrisK Offline
            Kris
            @Chad-Sweet
            The gstreamer commands work on my Linux PC.
            I am able to stream and record video when my UVC 2.0 camera is plugged directly into my Linux PC.
            I just have to change some of the pipeline, because x264enc is not recognized on the VOXL. I use x264enc on my PC and omxh264enc on the VOXL.
            I am using the e-CAM83 UVC 2.0 camera.
            There is detailed information about this camera in this post.
              KrisK Offline
              KrisK Offline
              Kris
              @Chad-Sweet
              If it’s possible to configure the Seeker with Hires + TOF + Stereo, where one stereo camera is acting as a tracking camera, can I send my Seeker back to ModalAi for this setup?
              Would the Seeker still have the VIO and VOA capabilities with this kind of setup?
                KrisK Offline
                KrisK Offline
                Kris
                @Chad-Sweet
                My UVC camera is recognized on the VOXL but the voxl-uvc-server will not connect to it.
                voxl:~$ show-video-device-info.sh
                /dev/video2: e-CAM83_USB 2560:c184
                /dev/video3: e-CAM83_USB 2560:c184
                Here is the ls -la /dev/video* command output from my Linux PC.
                crw-rw----+ 1 root video 81, 0  3月 31 09:20 /dev/video0
                crw-rw----+ 1 root video 81, 1  3月 31 09:20 /dev/video1
                crw-rw----+ 1 root video 81, 2  3月 31 09:20 /dev/video2
                crw-rw----+ 1 root video 81, 3  3月 31 09:20 /dev/video3
                    voxl-uvc-server only supports a few data types. You may need to modify the code to support the format of the e-CAM83
                    If you have a gstreamer command that works on your linux box, it should work on VOXL as well though.
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet
                      Thank you so much for looking into this for me.
                      Can I ask for some assistance with modifying the voxl-uvc-server?
                      Do I modify the voxl-uvc-server C file, then make it into an ipk and push it into the VOXL?
                        The instructions are in the readme here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server
                        Chad SweetC 1 Reply Last reply
                          @Chad-Sweet But yes, you modify the code, build it, and push the IPK to VOXL
                          KrisK 2 Replies Last reply
                            KrisK Offline
                            KrisK Offline
                            Kris
                            @Chad-Sweet
                            Is the Hires + TOF + Stereo (one stereo configured as the tracking camera) configuration possible?
                            In case the e-CAM83 will not work with the Seeker.
                              KrisK Offline
                              KrisK Offline
                              Kris
                              #14
                              @Chad-Sweet
                              Just to confirm,
                              If I modify the voxl-uvc-server/src/main.c file, to allow H264 format, would this work?
                              Or does the modification need to happen somewhere else in the main.c?
                              I’m just not exactly sure what or where I need to modify the voxl-uvc-server to make my UVC camera work.
                              • KrisK Kris
                                @Chad-Sweet
                                Just to confirm,
                                @Kris H264 is not supported in voxl-uvc-server. See https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/dev/src/main.c#L64. You may be able to add support for it but there are some tricky aspects to H264 streaming that you would need to be aware of before attempting it. Seems like you should start with the video3 interface since it supports 640x480 YUYV
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  @Eric-Katzfey
                                  Ok, thank you.
                                  I will start with attempting /dev/video3 first.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    #17
                                    @Eric-Katzfey
                                    It seems as if VOXL1 is not able to connect with my UVC camera.
                                    Output when UVC camera is connected to the Seeker;
                                    voxl:~$ gst-device-monitor-1.0 Video/Source
                                    Probing devices...
                                    (gst-device-monitor-1.0:4152): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                                    No devices found!
                                    Probing devices...
                                    (gst-device-monitor-1.0:4157): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                                    Device found:
                                    	class : Video/Sink
                                    	caps  : video/x-raw, format=(string)GRAY8, width=(int)[ 320, 854 ], height=(int)[ 240, 480 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, 2:6:5:7, 2:0:0:0 };
                                    	properties:
                                    		device.path = /dev/video1
                                    		udev-probed = false
                                    		device.api = v4l2
                                    		v4l2.device.driver = msm_fd
                                    		v4l2.device.card = msm_fd
                                    		v4l2.device.bus_info = ""
                                    		v4l2.device.version = 201287 (0x00031247)
                                    		v4l2.device.capabilities = 69206018 (0x04200002)
                                    		v4l2.device.device_caps = 2097152 (0x00200000)
                                    Output when my UVC camera is connected to my Linux PC;
                                    seeker3@seeker3-VirtualBox:~$ gst-device-monitor-1.0 Video/Source
                                    Probing devices...
                                    Device found:
                                    	class : Video/Source
                                    	caps  : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 15/1 };
                                    	        video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                                    	properties:
                                    		udev-probed = true
                                    		device.bus_path = pci-0000:00:0c.0-usb-0:2:1.0
                                    		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video0
                                    		device.bus = usb
                                    		device.subsystem = video4linux
                                    		device.vendor.id = 2560
                                    		device.vendor.name = e-ConSystems
                                    		device.product.id = c184
                                    		device.product.name = e-CAM83_USB
                                    		device.serial = e-ConSystems_e-CAM83_USB_00.00.01
                                    		device.capabilities = :capture:
                                    		device.api = v4l2
                                    		device.path = /dev/video0
                                    		v4l2.device.driver = uvcvideo
                                    		v4l2.device.card = e-CAM83_USB
                                    		v4l2.device.bus_info = usb-0000:00:0c.0-2
                                    		v4l2.device.version = 328933 (0x000504e5)
                                    		v4l2.device.capabilities = 2225078273 (0x84a00001)
                                    		v4l2.device.device_caps = 69206017 (0x04200001)
                                    	gst-launch-1.0 v4l2src ! ...
                                    Device found:
                                    	caps  : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
                                    	        image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                                    	properties:
                                    		udev-probed = true
                                    		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video2
                                    		device.bus = usb
                                    		device.api = v4l2
                                    		device.path = /dev/video2
                                    	gst-launch-1.0 v4l2src device=/dev/video2 ! ...
                                    Probing devices...
                                    Device found:
                                    	name  : Monitor of Built-in Audio Analog Stereo
                                    	class : Audio/Source
                                    	caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                                    	        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                                    	        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                                    	properties:
                                    		device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
                                    		device.class = monitor
                                    		alsa.card = 0
                                    		alsa.card_name = "Intel\ 82801AA-ICH"
                                    		alsa.long_card_name = "Intel\ 82801AA-ICH\ with\ AD1980\ at\ irq\ 21"
                                    		alsa.driver_name = snd_intel8x0
                                    		device.bus_path = pci-0000:00:05.0
                                    		sysfs.path = /devices/pci0000:00/0000:00:05.0/sound/card0
                                    		device.bus = pci
                                    		device.vendor.id = 8086
                                    		device.vendor.name = "Intel\ Corporation"
                                    		device.product.id = 2415
                                    		device.product.name = "82801AA\ AC\'97\ Audio\ Controller"
                                    		device.form_factor = internal
                                    		device.string = 0
                                    		module-udev-detect.discovered = 1
                                    		device.icon_name = audio-card-pci
                                    	gst-launch-1.0 pulsesrc device=alsa_output.pci-0000_00_05.0.analog-stereo.monitor ! ...
                                    Device found:
                                    	name  : Built-in Audio Analog Stereo
                                    	properties:
                                    		alsa.resolution_bits = 16
                                    		device.api = alsa
                                    		device.class = sound
                                    		alsa.class = generic
                                    		alsa.subclass = generic-mix
                                    		alsa.name = "Intel\ 82801AA-ICH"
                                    		alsa.id = "Intel\ ICH"
                                    		alsa.subdevice = 0
                                    		alsa.subdevice_name = "subdevice\ \#0"
                                    		alsa.device = 0
                                    		alsa.card = 0
                                    		device.bus = pci
                                    		device.string = front:0
                                    		device.buffering.buffer_size = 17632
                                    		device.buffering.fragment_size = 4408
                                    		device.access_mode = mmap
                                    		device.profile.name = analog-stereo
                                    		device.profile.description = "Analog\ Stereo"
                                    		device.description = "Built-in\ Audio\ Analog\ Stereo"
                                    		alsa.mixer_name = "Analog\ Devices\ AD1980"
                                    		alsa.components = AC97a:41445370
                                    	gst-launch-1.0 pulsesrc device=alsa_input.pci-0000_00_05.0.analog-stereo ! ...
                                    Device found:
                                    	class : Audio/Sink
                                    	properties:
                                    		device.api = alsa
                                    		alsa.subdevice = 0
                                    		alsa.device = 0
                                    		alsa.card = 0
                                    		device.bus = pci
                                    		device.buffering.buffer_size = 19188
                                    		device.buffering.fragment_size = 6396
                                    	gst-launch-1.0 ... ! pulsesink device=alsa_output.pci-0000_00_05.0.analog-stereo
                                    Device found:
                                    	properties:
                                    		udev-probed = true
                                    		device.bus = usb
                                    		device.api = v4l2
                                    Device found:
                                    	properties:
                                    		udev-probed = true
                                    		device.bus = usb
                                    		device.api = v4l2
                                    A simple video test will not work either.
                                    voxl:~$ gst-launch-1.0 videotestsrc ! videoconvert ! autovideosink
                                    Setting pipeline to PAUSED ...
                                    Pipeline is PREROLLING ...
                                    WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Resource not found.
                                    Additional debug info:
                                    /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/gst/autodetect/gstautodetect.c(347): gst_auto_detect_find_best (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0:
                                    Failed to find a usable video sink
                                    Pipeline is PREROLLED ...
                                    Setting pipeline to PLAYING ...
                                    New clock: GstSystemClock
                                    ^Chandling interrupt.
                                    Interrupt: Stopping pipeline ...
                                    Execution ended after 0:00:17.998587815
                                    Setting pipeline to READY ...
                                    Setting pipeline to NULL ...
                                    Freeing pipeline ...
                                    Are there any plugins that I could be missing?
                                    • KrisK Kris
                                      @Eric-Katzfey
                                      Probing devices...
                                      No devices found!
                                      Probing devices...
                                      Device found:
                                      	class : Video/Sink
                                      	properties:
                                      		udev-probed = false
                                      		device.api = v4l2
                                      Probing devices...
                                      Device found:
                                      	properties:
                                      		udev-probed = true
                                      		device.bus = usb
                                      		device.api = v4l2
                                      Device found:
                                      	properties:
                                      		udev-probed = true
                                      		device.bus = usb
                                      		device.api = v4l2
                                      Probing devices...
                                      Device found:
                                      	properties:
                                      		alsa.card = 0
                                      		device.bus = pci
                                      		device.string = 0
                                      Device found:
                                      	properties:
                                      		device.api = alsa
                                      		alsa.subdevice = 0
                                      		alsa.device = 0
                                      		alsa.card = 0
                                      		device.bus = pci
                                      Device found:
                                      	class : Audio/Sink
                                      	properties:
                                      		device.api = alsa
                                      		alsa.subdevice = 0
                                      		alsa.device = 0
                                      		alsa.card = 0
                                      		device.bus = pci
                                      Device found:
                                      	properties:
                                      		udev-probed = true
                                      		device.bus = usb
                                      		device.api = v4l2
                                      Device found:
                                      	properties:
                                      		udev-probed = true
                                      		device.bus = usb
                                      		device.api = v4l2
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      #18
                                      Keeps failing to find a usable video sink.
                                      voxl:~$ gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                                      ERROR: Pipeline doesn't want to pause.
                                      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video3' for reading and writing.
                                      /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/sys/v4l2/v4l2_calls.c(625): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                                      system error: Device or resource busy
                                      voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! autovideosink
                                      ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video2' for reading and writing.
                                      voxl:~$
                                      Output when debug command is used.
                                      voxl:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                                      0:00:00.229741613  4689    0xdf500 WARN              autodetect gstautodetect.c:347:gst_auto_detect_find_best:<autovideosink0> warning: Failed to find a usable video sink
                                      0:00:00.277135238  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: Could not open device '/dev/video3' for reading and writing.
                                      0:00:00.277213207  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: system error: Device or resource busy
                                      • tomT Offline
                                        @Kris You can't use autovideosink on VOXL because it doesn't have a display
                                        • KrisK Kris
                                          voxl:~$
                                          @Kris Maybe try fakesink instead?
