  3. VOXL camera configuration
30 Posts 4 Posters 8.3k Views 4 Watching
    To change the image sensor on Seeker, you would have to disassemble the front end which would likely result in damage. It is really not recommended.
    gstreamer should work similar to your USB setup on your Linux PC. Do you have a gstreamer command that is working on your PC?
    if you type ls -la /dev/video* with your camera plugged in and unplugged, you should easily see which device it is enumerating to
    What is the exact module number of the camera you are trying to install?
    KrisK 3 Replies Last reply
    • Chad SweetC Chad Sweet
      KrisK Offline
      KrisK Offline
      Kris
      @Chad-Sweet
      The gstreamer commands work on my Linux PC.
      I am able to stream and record video when my UVC 2.0 camera is plugged directly into my Linux PC.
      I just have to change some of the pipeline, because x264enc is not recognized on the VOXL. I use x264enc on my PC and omxh264enc on the VOXL.
      I am using the e-CAM83 UVC 2.0 camera.
      There is detailed information about this camera in this post.
        KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet
        If it’s possible to configure the Seeker with Hires + TOF + Stereo, where one stereo camera is acting as a tracking camera, can I send my Seeker back to ModalAi for this setup?
        Would the Seeker still have the VIO and VOA capabilities with this kind of setup?
          KrisK Offline
          KrisK Offline
          Kris
          wrote on last edited by Kris
          @Chad-Sweet
          My UVC camera is recognized on the VOXL but the voxl-uvc-server will not connect to it.
          voxl:~$ show-video-device-info.sh
          /dev/video2: e-CAM83_USB 2560:c184
          /dev/video3: e-CAM83_USB 2560:c184
          Here is the ls -la /dev/video* command output from my Linux PC.
          crw-rw----+ 1 root video 81, 0  3月 31 09:20 /dev/video0
          crw-rw----+ 1 root video 81, 1  3月 31 09:20 /dev/video1
          crw-rw----+ 1 root video 81, 2  3月 31 09:20 /dev/video2
          crw-rw----+ 1 root video 81, 3  3月 31 09:20 /dev/video3
              voxl-uvc-server only supports a few data types. You may need to modify the code to support the format of the e-CAM83
              If you have a gstreamer command that works on your linux box, it should work on VOXL as well though.
              KrisK 1 Reply Last reply
                KrisK Offline
                KrisK Offline
                Kris
                @Chad-Sweet
                Thank you so much for looking into this for me.
                Can I ask for some assistance with modifying the voxl-uvc-server?
                Do I modify the voxl-uvc-server C file, then make it into an ipk and push it into the VOXL?
                  The instructions are in the readme here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server
                  Chad SweetC 1 Reply Last reply
                    @Chad-Sweet But yes, you modify the code, build it, and push the IPK to VOXL
                    KrisK 2 Replies Last reply
                      KrisK Offline
                      KrisK Offline
                      Kris
                      @Chad-Sweet
                      Is the Hires + TOF + Stereo (one stereo configured as the tracking camera) configuration possible?
                      In case the e-CAM83 will not work with the Seeker.
                        KrisK Offline
                        KrisK Offline
                        Kris
                        #14
                        @Chad-Sweet
                        Just to confirm,
                        If I modify the voxl-uvc-server/src/main.c file, to allow H264 format, would this work?
                        Or does the modification need to happen somewhere else in the main.c?
                        I’m just not exactly sure what or where I need to modify the voxl-uvc-server to make my UVC camera work.
                        • KrisK Kris
                          @Chad-Sweet
                          Just to confirm,
                          @Kris H264 is not supported in voxl-uvc-server. See https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/dev/src/main.c#L64. You may be able to add support for it but there are some tricky aspects to H264 streaming that you would need to be aware of before attempting it. Seems like you should start with the video3 interface since it supports 640x480 YUYV
                            KrisK Offline
                            KrisK Offline
                            Kris
                            Ok, thank you.
                            I will start with attempting /dev/video3 first.
                              KrisK Offline
                              KrisK Offline
                              Kris
                              #17
                              It seems as if VOXL1 is not able to connect with my UVC camera.
                              Output when UVC camera is connected to the Seeker;
                              voxl:~$ gst-device-monitor-1.0 Video/Source
                              Probing devices...
                              (gst-device-monitor-1.0:4152): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                              No devices found!
                              Probing devices...
                              (gst-device-monitor-1.0:4157): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                              Device found:
                              	class : Video/Sink
                              	caps  : video/x-raw, format=(string)GRAY8, width=(int)[ 320, 854 ], height=(int)[ 240, 480 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, 2:6:5:7, 2:0:0:0 };
                              	properties:
                              		device.path = /dev/video1
                              		udev-probed = false
                              		device.api = v4l2
                              		v4l2.device.driver = msm_fd
                              		v4l2.device.card = msm_fd
                              		v4l2.device.bus_info = ""
                              		v4l2.device.version = 201287 (0x00031247)
                              		v4l2.device.capabilities = 69206018 (0x04200002)
                              		v4l2.device.device_caps = 2097152 (0x00200000)
                              Output when my UVC camera is connected to my Linux PC;
                              seeker3@seeker3-VirtualBox:~$ gst-device-monitor-1.0 Video/Source
                              Probing devices...
                              Device found:
                              	class : Video/Source
                              	caps  : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 15/1 };
                              	        video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                              	properties:
                              		udev-probed = true
                              		device.bus_path = pci-0000:00:0c.0-usb-0:2:1.0
                              		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video0
                              		device.bus = usb
                              		device.subsystem = video4linux
                              		device.vendor.id = 2560
                              		device.vendor.name = e-ConSystems
                              		device.product.id = c184
                              		device.product.name = e-CAM83_USB
                              		device.serial = e-ConSystems_e-CAM83_USB_00.00.01
                              		device.capabilities = :capture:
                              		device.api = v4l2
                              		device.path = /dev/video0
                              		v4l2.device.driver = uvcvideo
                              		v4l2.device.card = e-CAM83_USB
                              		v4l2.device.bus_info = usb-0000:00:0c.0-2
                              		v4l2.device.version = 328933 (0x000504e5)
                              		v4l2.device.capabilities = 2225078273 (0x84a00001)
                              		v4l2.device.device_caps = 69206017 (0x04200001)
                              	gst-launch-1.0 v4l2src ! ...
                              Device found:
                              	caps  : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
                              	        image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                              	properties:
                              		udev-probed = true
                              		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video2
                              		device.bus = usb
                              		device.api = v4l2
                              		device.path = /dev/video2
                              	gst-launch-1.0 v4l2src device=/dev/video2 ! ...
                              Probing devices...
                              Device found:
                              	name  : Monitor of Built-in Audio Analog Stereo
                              	class : Audio/Source
                              	caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                              	        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                              	        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                              	properties:
                              		device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
                              		device.class = monitor
                              		alsa.card = 0
                              		alsa.card_name = "Intel\ 82801AA-ICH"
                              		alsa.long_card_name = "Intel\ 82801AA-ICH\ with\ AD1980\ at\ irq\ 21"
                              		alsa.driver_name = snd_intel8x0
                              		device.bus_path = pci-0000:00:05.0
                              		sysfs.path = /devices/pci0000:00/0000:00:05.0/sound/card0
                              		device.bus = pci
                              		device.vendor.id = 8086
                              		device.vendor.name = "Intel\ Corporation"
                              		device.product.id = 2415
                              		device.product.name = "82801AA\ AC\'97\ Audio\ Controller"
                              		device.form_factor = internal
                              		device.string = 0
                              		module-udev-detect.discovered = 1
                              		device.icon_name = audio-card-pci
                              	gst-launch-1.0 pulsesrc device=alsa_output.pci-0000_00_05.0.analog-stereo.monitor ! ...
                              Device found:
                              	name  : Built-in Audio Analog Stereo
                              	properties:
                              		alsa.resolution_bits = 16
                              		device.api = alsa
                              		device.class = sound
                              		alsa.class = generic
                              		alsa.subclass = generic-mix
                              		alsa.name = "Intel\ 82801AA-ICH"
                              		alsa.id = "Intel\ ICH"
                              		alsa.subdevice = 0
                              		alsa.subdevice_name = "subdevice\ \#0"
                              		alsa.device = 0
                              		alsa.card = 0
                              		device.bus = pci
                              		device.string = front:0
                              		device.buffering.buffer_size = 17632
                              		device.buffering.fragment_size = 4408
                              		device.access_mode = mmap
                              		device.profile.name = analog-stereo
                              		device.profile.description = "Analog\ Stereo"
                              		device.description = "Built-in\ Audio\ Analog\ Stereo"
                              		alsa.mixer_name = "Analog\ Devices\ AD1980"
                              		alsa.components = AC97a:41445370
                              	gst-launch-1.0 pulsesrc device=alsa_input.pci-0000_00_05.0.analog-stereo ! ...
                              Device found:
                              	class : Audio/Sink
                              	properties:
                              		device.api = alsa
                              		alsa.subdevice = 0
                              		alsa.device = 0
                              		alsa.card = 0
                              		device.bus = pci
                              		device.buffering.buffer_size = 19188
                              		device.buffering.fragment_size = 6396
                              	gst-launch-1.0 ... ! pulsesink device=alsa_output.pci-0000_00_05.0.analog-stereo
                              Device found:
                              	properties:
                              		udev-probed = true
                              		device.bus = usb
                              		device.api = v4l2
                              Device found:
                              	properties:
                              		udev-probed = true
                              		device.bus = usb
                              		device.api = v4l2
                              A simple video test will not work either.
                              voxl:~$ gst-launch-1.0 videotestsrc ! videoconvert ! autovideosink
                              Setting pipeline to PAUSED ...
                              Pipeline is PREROLLING ...
                              WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Resource not found.
                              Additional debug info:
                              /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/gst/autodetect/gstautodetect.c(347): gst_auto_detect_find_best (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0:
                              Failed to find a usable video sink
                              Pipeline is PREROLLED ...
                              Setting pipeline to PLAYING ...
                              New clock: GstSystemClock
                              ^Chandling interrupt.
                              Interrupt: Stopping pipeline ...
                              Execution ended after 0:00:17.998587815
                              Setting pipeline to READY ...
                              Setting pipeline to NULL ...
                              Freeing pipeline ...
                              Are there any plugins that I could be missing?
                              • KrisK Kris
                                Probing devices...
                                No devices found!
                                Probing devices...
                                Device found:
                                	class : Video/Sink
                                	properties:
                                		udev-probed = false
                                		device.api = v4l2
                                Probing devices...
                                Device found:
                                	properties:
                                		udev-probed = true
                                		device.bus = usb
                                		device.api = v4l2
                                Device found:
                                	properties:
                                		udev-probed = true
                                		device.bus = usb
                                		device.api = v4l2
                                Probing devices...
                                Device found:
                                	properties:
                                		alsa.card = 0
                                		device.bus = pci
                                		device.string = 0
                                Device found:
                                	properties:
                                		device.api = alsa
                                		alsa.subdevice = 0
                                		alsa.device = 0
                                		alsa.card = 0
                                		device.bus = pci
                                Device found:
                                	class : Audio/Sink
                                	properties:
                                		device.api = alsa
                                		alsa.subdevice = 0
                                		alsa.device = 0
                                		alsa.card = 0
                                		device.bus = pci
                                Device found:
                                	properties:
                                		udev-probed = true
                                		device.bus = usb
                                		device.api = v4l2
                                Device found:
                                	properties:
                                		udev-probed = true
                                		device.bus = usb
                                		device.api = v4l2
                                KrisK Offline
                                KrisK Offline
                                Kris
                                #18
                                Keeps failing to find a usable video sink.
                                voxl:~$ gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                                ERROR: Pipeline doesn't want to pause.
                                ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video3' for reading and writing.
                                /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/sys/v4l2/v4l2_calls.c(625): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                                system error: Device or resource busy
                                voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! autovideosink
                                ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video2' for reading and writing.
                                voxl:~$
                                Output when debug command is used.
                                voxl:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                                0:00:00.229741613  4689    0xdf500 WARN              autodetect gstautodetect.c:347:gst_auto_detect_find_best:<autovideosink0> warning: Failed to find a usable video sink
                                0:00:00.277135238  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: Could not open device '/dev/video3' for reading and writing.
                                0:00:00.277213207  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: system error: Device or resource busy
                                  @Kris You can't use autovideosink on VOXL because it doesn't have a display
                                  • KrisK Kris
                                    voxl:~$
                                    @Kris Maybe try fakesink instead?
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      #21
                                      I have tried both fakesink and playbin.
                                      Neither of them work either.
                                      Has anyone gotten gstreamer to successfully work on VOXL1?
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        #22
                                        I also have another UVC camera, but it only outputs MJPG (compressed) and YUY2 (uncompressed 640x480 30fps) formats.
                                        It works for streaming, but I am trying to record the video to the Seeker’s SD card.
                                        Is there a way to do this with Gstreamer or a similar program?
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          Could this be the reason why no devices are found when I use gst-device-monitor-1.0 Video/Source on the VOXL1?
