  3. VOXL camera configuration
30 Posts 4 Posters 8.6k Views 4 Watching
      voxl-uvc-server only supports a few data types. You may need to modify the code to support the format of the e-CAM83
      If you have a gstreamer command that works on your linux box, it should work on VOXL as well though.
      KrisK 1 Reply Last reply
      • Chad SweetC Chad Sweet
        KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet
        Thank you so much for looking into this for me.
        Can I ask for some assistance with modifying the voxl-uvc-server?
        Do I modify the voxl-uvc-server C file, then make it into an ipk and push it into the VOXL?
          The instructions are in the readme here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server
          Chad SweetC 1 Reply Last reply
            @Chad-Sweet But yes, you modify the code, build it, and push the IPK to VOXL
            KrisK 2 Replies Last reply
              KrisK Offline
              KrisK Offline
              Kris
              @Chad-Sweet
              Is the Hires + TOF + Stereo (one stereo configured as the tracking camera) configuration possible?
              In case the e-CAM83 will not work with the Seeker.
                KrisK Offline
                KrisK Offline
                Kris
                wrote on last edited by Kris
                #14
                @Chad-Sweet
                Just to confirm,
                If I modify the voxl-uvc-server/src/main.c file, to allow H264 format, would this work?
                Or does the modification need to happen somewhere else in the main.c?
                I’m just not exactly sure what or where I need to modify the voxl-uvc-server to make my UVC camera work.
                • KrisK Kris
                  @Chad-Sweet
                  Just to confirm,
                  @Kris H264 is not supported in voxl-uvc-server. See https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/dev/src/main.c#L64. You may be able to add support for it but there are some tricky aspects to H264 streaming that you would need to be aware of before attempting it. Seems like you should start with the video3 interface since it supports 640x480 YUYV
                    KrisK Offline
                    KrisK Offline
                    Kris
                    Ok, thank you.
                    I will start with attempting /dev/video3 first.
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #17
                      It seems as if VOXL1 is not able to connect with my UVC camera.
                      Output when UVC camera is connected to the Seeker;
                      voxl:~$ gst-device-monitor-1.0 Video/Source
                      Probing devices...
                      (gst-device-monitor-1.0:4152): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                      No devices found!
                      Probing devices...
                      (gst-device-monitor-1.0:4157): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                      Device found:
                      	class : Video/Sink
                      	caps  : video/x-raw, format=(string)GRAY8, width=(int)[ 320, 854 ], height=(int)[ 240, 480 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, 2:6:5:7, 2:0:0:0 };
                      	properties:
                      		device.path = /dev/video1
                      		udev-probed = false
                      		device.api = v4l2
                      		v4l2.device.driver = msm_fd
                      		v4l2.device.card = msm_fd
                      		v4l2.device.bus_info = ""
                      		v4l2.device.version = 201287 (0x00031247)
                      		v4l2.device.capabilities = 69206018 (0x04200002)
                      		v4l2.device.device_caps = 2097152 (0x00200000)
                      Output when my UVC camera is connected to my Linux PC;
                      seeker3@seeker3-VirtualBox:~$ gst-device-monitor-1.0 Video/Source
                      Probing devices...
                      Device found:
                      	class : Video/Source
                      	caps  : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 15/1 };
                      	        video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                      	properties:
                      		udev-probed = true
                      		device.bus_path = pci-0000:00:0c.0-usb-0:2:1.0
                      		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video0
                      		device.bus = usb
                      		device.subsystem = video4linux
                      		device.vendor.id = 2560
                      		device.vendor.name = e-ConSystems
                      		device.product.id = c184
                      		device.product.name = e-CAM83_USB
                      		device.serial = e-ConSystems_e-CAM83_USB_00.00.01
                      		device.capabilities = :capture:
                      		device.api = v4l2
                      		device.path = /dev/video0
                      		v4l2.device.driver = uvcvideo
                      		v4l2.device.card = e-CAM83_USB
                      		v4l2.device.bus_info = usb-0000:00:0c.0-2
                      		v4l2.device.version = 328933 (0x000504e5)
                      		v4l2.device.capabilities = 2225078273 (0x84a00001)
                      		v4l2.device.device_caps = 69206017 (0x04200001)
                      	gst-launch-1.0 v4l2src ! ...
                      Device found:
                      	caps  : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
                      	        image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                      	properties:
                      		udev-probed = true
                      		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video2
                      		device.bus = usb
                      		device.api = v4l2
                      		device.path = /dev/video2
                      	gst-launch-1.0 v4l2src device=/dev/video2 ! ...
                      Probing devices...
                      Device found:
                      	name  : Monitor of Built-in Audio Analog Stereo
                      	class : Audio/Source
                      	caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                      	        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                      	        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                      	properties:
                      		device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
                      		device.class = monitor
                      		alsa.card = 0
                      		alsa.card_name = "Intel\ 82801AA-ICH"
                      		alsa.long_card_name = "Intel\ 82801AA-ICH\ with\ AD1980\ at\ irq\ 21"
                      		alsa.driver_name = snd_intel8x0
                      		device.bus_path = pci-0000:00:05.0
                      		sysfs.path = /devices/pci0000:00/0000:00:05.0/sound/card0
                      		device.bus = pci
                      		device.vendor.id = 8086
                      		device.vendor.name = "Intel\ Corporation"
                      		device.product.id = 2415
                      		device.product.name = "82801AA\ AC\'97\ Audio\ Controller"
                      		device.form_factor = internal
                      		device.string = 0
                      		module-udev-detect.discovered = 1
                      		device.icon_name = audio-card-pci
                      	gst-launch-1.0 pulsesrc device=alsa_output.pci-0000_00_05.0.analog-stereo.monitor ! ...
                      Device found:
                      	name  : Built-in Audio Analog Stereo
                      	properties:
                      		alsa.resolution_bits = 16
                      		device.api = alsa
                      		device.class = sound
                      		alsa.class = generic
                      		alsa.subclass = generic-mix
                      		alsa.name = "Intel\ 82801AA-ICH"
                      		alsa.id = "Intel\ ICH"
                      		alsa.subdevice = 0
                      		alsa.subdevice_name = "subdevice\ \#0"
                      		alsa.device = 0
                      		alsa.card = 0
                      		device.bus = pci
                      		device.string = front:0
                      		device.buffering.buffer_size = 17632
                      		device.buffering.fragment_size = 4408
                      		device.access_mode = mmap
                      		device.profile.name = analog-stereo
                      		device.profile.description = "Analog\ Stereo"
                      		device.description = "Built-in\ Audio\ Analog\ Stereo"
                      		alsa.mixer_name = "Analog\ Devices\ AD1980"
                      		alsa.components = AC97a:41445370
                      	gst-launch-1.0 pulsesrc device=alsa_input.pci-0000_00_05.0.analog-stereo ! ...
                      Device found:
                      	class : Audio/Sink
                      	properties:
                      		device.api = alsa
                      		alsa.subdevice = 0
                      		alsa.device = 0
                      		alsa.card = 0
                      		device.bus = pci
                      		device.buffering.buffer_size = 19188
                      		device.buffering.fragment_size = 6396
                      	gst-launch-1.0 ... ! pulsesink device=alsa_output.pci-0000_00_05.0.analog-stereo
                      Device found:
                      	properties:
                      		udev-probed = true
                      		device.bus = usb
                      		device.api = v4l2
                      Device found:
                      	properties:
                      		udev-probed = true
                      		device.bus = usb
                      		device.api = v4l2
                      A simple video test will not work either.
                      voxl:~$ gst-launch-1.0 videotestsrc ! videoconvert ! autovideosink
                      Setting pipeline to PAUSED ...
                      Pipeline is PREROLLING ...
                      WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Resource not found.
                      Additional debug info:
                      /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/gst/autodetect/gstautodetect.c(347): gst_auto_detect_find_best (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0:
                      Failed to find a usable video sink
                      Pipeline is PREROLLED ...
                      Setting pipeline to PLAYING ...
                      New clock: GstSystemClock
                      ^Chandling interrupt.
                      Interrupt: Stopping pipeline ...
                      Execution ended after 0:00:17.998587815
                      Setting pipeline to READY ...
                      Setting pipeline to NULL ...
                      Freeing pipeline ...
                      Are there any plugins that I could be missing?
                      • KrisK Kris
                        Probing devices...
                        No devices found!
                        Probing devices...
                        Device found:
                        	class : Video/Sink
                        	properties:
                        		udev-probed = false
                        		device.api = v4l2
                        Probing devices...
                        Device found:
                        	properties:
                        		udev-probed = true
                        		device.bus = usb
                        		device.api = v4l2
                        Device found:
                        	properties:
                        		udev-probed = true
                        		device.bus = usb
                        		device.api = v4l2
                        Probing devices...
                        Device found:
                        	properties:
                        		alsa.card = 0
                        		device.bus = pci
                        		device.string = 0
                        Device found:
                        	properties:
                        		device.api = alsa
                        		alsa.subdevice = 0
                        		alsa.device = 0
                        		alsa.card = 0
                        		device.bus = pci
                        Device found:
                        	class : Audio/Sink
                        	properties:
                        		device.api = alsa
                        		alsa.subdevice = 0
                        		alsa.device = 0
                        		alsa.card = 0
                        		device.bus = pci
                        Device found:
                        	properties:
                        		udev-probed = true
                        		device.bus = usb
                        		device.api = v4l2
                        Device found:
                        	properties:
                        		udev-probed = true
                        		device.bus = usb
                        		device.api = v4l2
                        KrisK Offline
                        KrisK Offline
                        Kris
                        #18
                        Keeps failing to find a usable video sink.
                        voxl:~$ show-video-device-info.sh
                        /dev/video2: e-CAM83_USB 2560:c184
                        /dev/video3: e-CAM83_USB 2560:c184
                        voxl:~$ gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                        ERROR: Pipeline doesn't want to pause.
                        ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video3' for reading and writing.
                        /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/sys/v4l2/v4l2_calls.c(625): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                        system error: Device or resource busy
                        voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! autovideosink
                        ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video2' for reading and writing.
                        voxl:~$
                        Output when debug command is used.
                        voxl:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                        0:00:00.229741613  4689    0xdf500 WARN              autodetect gstautodetect.c:347:gst_auto_detect_find_best:<autovideosink0> warning: Failed to find a usable video sink
                        0:00:00.277135238  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: Could not open device '/dev/video3' for reading and writing.
                        0:00:00.277213207  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: system error: Device or resource busy
                          @Kris You can't use autovideosink on VOXL because it doesn't have a display
                          • KrisK Kris
                            voxl:~$
                            @Kris Maybe try fakesink instead?
                              KrisK Offline
                              KrisK Offline
                              Kris
                              #21
                              I have tried both fakesink and playbin.
                              Neither of them work either.
                              Has anyone gotten gstreamer to successfully work on VOXL1?
                                KrisK Offline
                                KrisK Offline
                                Kris
                                #22
                                I also have another UVC camera, but it only outputs MJPG (compressed) and YUY2 (uncompressed 640x480 30fps) formats.
                                It works for streaming, but I am trying to record the video to the Seeker’s SD card.
                                Is there a way to do this with Gstreamer or a similar program?
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  Could this be the reason why no devices are found when I use gst-device-monitor-1.0 Video/Source on the VOXL1?
                                  • KrisK Offline
                                    KrisK Offline
                                    Kris
                                    I see that the VOXL1 has the gst-plugins-good.
                                    Is it possible to also add the gst-plugins-bad and gst-plugins-ugly?
                                    • KrisK Kris
                                      @Kris We use GStreamer in our voxl-streamer application. It does work on VOXL1.
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        Ok, thank you for the confirmation.
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          If possible, could you please provide me with a VOXL1 working pipeline (streaming or recording) using any UVC camera of your choice?
