  3. VOXL camera configuration
30 Posts 4 Posters 9.2k Views 4 Watching
    The instructions are in the readme here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server
    Chad SweetC 1 Reply Last reply
    • Chad SweetC Chad Sweet
      @Chad-Sweet But yes, you modify the code, build it, and push the IPK to VOXL
      KrisK 2 Replies Last reply
        KrisK Offline
        KrisK Offline
        Kris
        @Chad-Sweet
        Is the Hires + TOF + Stereo (one stereo configured as the tracking camera) configuration possible?
        In case the e-CAM83 will not work with the Seeker.
          KrisK Offline
          KrisK Offline
          Kris
          wrote on last edited by Kris
          #14
          @Chad-Sweet
          Just to confirm,
          If I modify the voxl-uvc-server/src/main.c file, to allow H264 format, would this work?
          Or does the modification need to happen somewhere else in the main.c?
          I’m just not exactly sure what or where I need to modify the voxl-uvc-server to make my UVC camera work.
          • KrisK Kris
            @Chad-Sweet
            Just to confirm,
            @Kris H264 is not supported in voxl-uvc-server. See https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/dev/src/main.c#L64. You may be able to add support for it but there are some tricky aspects to H264 streaming that you would need to be aware of before attempting it. Seems like you should start with the video3 interface since it supports 640x480 YUYV
              KrisK Offline
              KrisK Offline
              Kris
              Ok, thank you.
              I will start with attempting /dev/video3 first.
                KrisK Offline
                KrisK Offline
                Kris
                #17
                It seems as if VOXL1 is not able to connect with my UVC camera.
                Output when UVC camera is connected to the Seeker;
                voxl:~$ gst-device-monitor-1.0 Video/Source
                Probing devices...
                (gst-device-monitor-1.0:4152): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                No devices found!
                Probing devices...
                (gst-device-monitor-1.0:4157): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
                Device found:
                	class : Video/Sink
                	caps  : video/x-raw, format=(string)GRAY8, width=(int)[ 320, 854 ], height=(int)[ 240, 480 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, 2:6:5:7, 2:0:0:0 };
                	properties:
                		device.path = /dev/video1
                		udev-probed = false
                		device.api = v4l2
                		v4l2.device.driver = msm_fd
                		v4l2.device.card = msm_fd
                		v4l2.device.bus_info = ""
                		v4l2.device.version = 201287 (0x00031247)
                		v4l2.device.capabilities = 69206018 (0x04200002)
                		v4l2.device.device_caps = 2097152 (0x00200000)
                Output when my UVC camera is connected to my Linux PC;
                seeker3@seeker3-VirtualBox:~$ gst-device-monitor-1.0 Video/Source
                Probing devices...
                Device found:
                	class : Video/Source
                	caps  : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 15/1 };
                	        video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                	properties:
                		udev-probed = true
                		device.bus_path = pci-0000:00:0c.0-usb-0:2:1.0
                		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video0
                		device.bus = usb
                		device.subsystem = video4linux
                		device.vendor.id = 2560
                		device.vendor.name = e-ConSystems
                		device.product.id = c184
                		device.product.name = e-CAM83_USB
                		device.serial = e-ConSystems_e-CAM83_USB_00.00.01
                		device.capabilities = :capture:
                		device.api = v4l2
                		device.path = /dev/video0
                		v4l2.device.driver = uvcvideo
                		v4l2.device.card = e-CAM83_USB
                		v4l2.device.bus_info = usb-0000:00:0c.0-2
                		v4l2.device.version = 328933 (0x000504e5)
                		v4l2.device.capabilities = 2225078273 (0x84a00001)
                		v4l2.device.device_caps = 69206017 (0x04200001)
                	gst-launch-1.0 v4l2src ! ...
                Device found:
                	caps  : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
                	        image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
                	properties:
                		udev-probed = true
                		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video2
                		device.bus = usb
                		device.api = v4l2
                		device.path = /dev/video2
                	gst-launch-1.0 v4l2src device=/dev/video2 ! ...
                Probing devices...
                Device found:
                	name  : Monitor of Built-in Audio Analog Stereo
                	class : Audio/Source
                	caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                	        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                	        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
                	properties:
                		device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
                		device.class = monitor
                		alsa.card = 0
                		alsa.card_name = "Intel\ 82801AA-ICH"
                		alsa.long_card_name = "Intel\ 82801AA-ICH\ with\ AD1980\ at\ irq\ 21"
                		alsa.driver_name = snd_intel8x0
                		device.bus_path = pci-0000:00:05.0
                		sysfs.path = /devices/pci0000:00/0000:00:05.0/sound/card0
                		device.bus = pci
                		device.vendor.id = 8086
                		device.vendor.name = "Intel\ Corporation"
                		device.product.id = 2415
                		device.product.name = "82801AA\ AC\'97\ Audio\ Controller"
                		device.form_factor = internal
                		device.string = 0
                		module-udev-detect.discovered = 1
                		device.icon_name = audio-card-pci
                	gst-launch-1.0 pulsesrc device=alsa_output.pci-0000_00_05.0.analog-stereo.monitor ! ...
                Device found:
                	name  : Built-in Audio Analog Stereo
                	properties:
                		alsa.resolution_bits = 16
                		device.api = alsa
                		device.class = sound
                		alsa.class = generic
                		alsa.subclass = generic-mix
                		alsa.name = "Intel\ 82801AA-ICH"
                		alsa.id = "Intel\ ICH"
                		alsa.subdevice = 0
                		alsa.subdevice_name = "subdevice\ \#0"
                		alsa.device = 0
                		alsa.card = 0
                		device.bus = pci
                		device.string = front:0
                		device.buffering.buffer_size = 17632
                		device.buffering.fragment_size = 4408
                		device.access_mode = mmap
                		device.profile.name = analog-stereo
                		device.profile.description = "Analog\ Stereo"
                		device.description = "Built-in\ Audio\ Analog\ Stereo"
                		alsa.mixer_name = "Analog\ Devices\ AD1980"
                		alsa.components = AC97a:41445370
                	gst-launch-1.0 pulsesrc device=alsa_input.pci-0000_00_05.0.analog-stereo ! ...
                Device found:
                	class : Audio/Sink
                	properties:
                		device.api = alsa
                		alsa.subdevice = 0
                		alsa.device = 0
                		alsa.card = 0
                		device.bus = pci
                		device.buffering.buffer_size = 19188
                		device.buffering.fragment_size = 6396
                	gst-launch-1.0 ... ! pulsesink device=alsa_output.pci-0000_00_05.0.analog-stereo
                Device found:
                	properties:
                		udev-probed = true
                		device.bus = usb
                		device.api = v4l2
                Device found:
                	properties:
                		udev-probed = true
                		device.bus = usb
                		device.api = v4l2
                A simple video test will not work either.
                voxl:~$ gst-launch-1.0 videotestsrc ! videoconvert ! autovideosink
                Setting pipeline to PAUSED ...
                Pipeline is PREROLLING ...
                WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Resource not found.
                Additional debug info:
                /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/gst/autodetect/gstautodetect.c(347): gst_auto_detect_find_best (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0:
                Failed to find a usable video sink
                Pipeline is PREROLLED ...
                Setting pipeline to PLAYING ...
                New clock: GstSystemClock
                ^Chandling interrupt.
                Interrupt: Stopping pipeline ...
                Execution ended after 0:00:17.998587815
                Setting pipeline to READY ...
                Setting pipeline to NULL ...
                Freeing pipeline ...
                Are there any plugins that I could be missing?
                KrisK 1 Reply Last reply
                • KrisK Kris
                  Probing devices...
                  No devices found!
                  Probing devices...
                  Device found:
                  	class : Video/Sink
                  	properties:
                  		udev-probed = false
                  		device.api = v4l2
                  Probing devices...
                  Device found:
                  	properties:
                  		udev-probed = true
                  		device.bus = usb
                  		device.api = v4l2
                  Device found:
                  	properties:
                  		udev-probed = true
                  		device.bus = usb
                  		device.api = v4l2
                  Probing devices...
                  Device found:
                  	properties:
                  		alsa.card = 0
                  		device.bus = pci
                  		device.string = 0
                  Device found:
                  	properties:
                  		device.api = alsa
                  		alsa.subdevice = 0
                  		alsa.device = 0
                  		alsa.card = 0
                  		device.bus = pci
                  Device found:
                  	class : Audio/Sink
                  	properties:
                  		device.api = alsa
                  		alsa.subdevice = 0
                  		alsa.device = 0
                  		alsa.card = 0
                  		device.bus = pci
                  Device found:
                  	properties:
                  		udev-probed = true
                  		device.bus = usb
                  		device.api = v4l2
                  Device found:
                  	properties:
                  		udev-probed = true
                  		device.bus = usb
                  		device.api = v4l2
                  KrisK Offline
                  KrisK Offline
                  Kris
                  #18
                  Keeps failing to find a usable video sink.
                  voxl:~$ show-video-device-info.sh
                  /dev/video2: e-CAM83_USB 2560:c184
                  /dev/video3: e-CAM83_USB 2560:c184
                  voxl:~$ gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                  ERROR: Pipeline doesn't want to pause.
                  ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video3' for reading and writing.
                  /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/sys/v4l2/v4l2_calls.c(625): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
                  system error: Device or resource busy
                  voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! autovideosink
                  ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video2' for reading and writing.
                  voxl:~$
                  Output when debug command is used.
                  voxl:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
                  0:00:00.229741613  4689    0xdf500 WARN              autodetect gstautodetect.c:347:gst_auto_detect_find_best:<autovideosink0> warning: Failed to find a usable video sink
                  0:00:00.277135238  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: Could not open device '/dev/video3' for reading and writing.
                  0:00:00.277213207  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: system error: Device or resource busy
                  • tomT Online
                    tomT Online
                    @Kris You can't use autovideosink on VOXL because it doesn't have a display
                    • KrisK Kris
                      voxl:~$
                      @Kris Maybe try fakesink instead?
                        KrisK Offline
                        KrisK Offline
                        Kris
                        #21
                        I have tried both fakesink and playbin.
                        Neither of them work either.
                        Has anyone gotten gstreamer to successfully work on VOXL1?
                          KrisK Offline
                          KrisK Offline
                          Kris
                          #22
                          I also have another UVC camera, but it only outputs MJPG (compressed) and YUY2 (uncompressed 640x480 30fps) formats.
                          It works for streaming, but I am trying to record the video to the Seeker’s SD card.
                          Is there a way to do this with Gstreamer or a similar program?
                            KrisK Offline
                            KrisK Offline
                            Kris
                            Could this be the reason why no devices are found when I use gst-device-monitor-1.0 Video/Source on the VOXL1?
                            • KrisK Offline
                              KrisK Offline
                              Kris
                              I see that the VOXL1 has the gst-plugins-good.
                              Is it possible to also add the gst-plugins-bad and gst-plugins-ugly?
                              • KrisK Kris
                                @Kris We use GStreamer in our voxl-streamer application. It does work on VOXL1.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  Ok, thank you for the confirmation.
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    If possible, could you please provide me with a VOXL1 working pipeline (streaming or recording) using any UVC camera of your choice?
                                    • KrisK Kris
                                      @Kris That's not how it works on VOXL1. The voxl-uvc-server application places frames into an MPA pipe and the voxl-streamer application (based on gstreamer) reads those frames and processes them for output using RTSP. However, I do believe that I did try command line gst-launch-1.0 style pipelines with UVC cameras in the past and they worked. I don't have an example of one though. You may want to start with one of our supported UVC cameras first and then try to get your particular UVC camera working. I always start with the Logitech C270. We list the specific cameras that we support because each one caused us some issues and required code changes to make it work. We even had to fork the libuvc library in order to make changes to that to get some of the cameras working properly.
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        Ok, I understand.
                                        Thank you for all your help and support with this issue.
                                        I will try one of your tested & supported UVC cameras.
                                          KrisK Offline
                                          KrisK Offline
                                          Kris
                                          #30
                                          I bought the Logitech C270 and tried testing it with some Gstreamer commands.
                                          So far I have been able to use it on my Linux PC with these commands.
                                          Connected to PC and viewing video;
                                          gst-launch-1.0 -v v4l2src ! video/x-raw,format=YUY2 ! videoconvert ! autovideosink
                                          Connected to PC and recording to PC;
                                          gst-launch-1.0 v4l2src device=/dev/video0 ! image/jpeg,width=640,height=480,framerate=30/1 ! jpegdec ! x264enc ! qtmux ! filesink location=C270.mp4 -e
                                          However, when I connect the C270 to the Seeker I cannot get any of these to work.
                                          I have tried different video devices 0-3 and I have also substituted the autovideosink with fakesink but these changes are still not working.
                                          Could you please show me a Gstreamer example for this Logitech C270 camera that works on the Seeker?
                                          I would like to either stream, record, or stream+record (possibly using tee) the video using gst-launch-1.0.
                                          Thank you
