  3. VOXL camera configuration
30 Posts 4 Posters 9.2k Views 4 Watching
  • KrisK Kris
    @Chad-Sweet
    Just to confirm,
    If I modify the voxl-uvc-server/src/main.c file, to allow H264 format, would this work?
    Or does the modification need to happen somewhere else in the main.c?
    I’m just not exactly sure what or where I need to modify the voxl-uvc-server to make my UVC camera work.
    @Kris H264 is not supported in voxl-uvc-server. See https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/dev/src/main.c#L64. You may be able to add support for it but there are some tricky aspects to H264 streaming that you would need to be aware of before attempting it. Seems like you should start with the video3 interface since it supports 640x480 YUYV
    KrisK 2 Replies Last reply
      KrisK Offline
      KrisK Offline
      Kris
      Ok, thank you.
      I will start with attempting /dev/video3 first.
        KrisK Offline
        KrisK Offline
        Kris
        wrote on last edited by Kris
        #17
        It seems as if VOXL1 is not able to connect with my UVC camera.
        Output when UVC camera is connected to the Seeker;
        voxl:~$ gst-device-monitor-1.0 Video/Source
        Probing devices...
        (gst-device-monitor-1.0:4152): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
        No devices found!
        Probing devices...
        (gst-device-monitor-1.0:4157): GStreamer-CRITICAL **: gst_element_message_full_with_details: assertion 'GST_IS_ELEMENT (element)' failed
        Device found:
        	class : Video/Sink
        	caps  : video/x-raw, format=(string)GRAY8, width=(int)[ 320, 854 ], height=(int)[ 240, 480 ], interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, colorimetry=(string){ bt601, smpte240m, bt709, 2:4:5:2, 2:4:5:3, 1:4:7:1, 2:4:7:1, 2:4:12:8, 2:6:5:7, 2:0:0:0 };
        	properties:
        		device.path = /dev/video1
        		udev-probed = false
        		device.api = v4l2
        		v4l2.device.driver = msm_fd
        		v4l2.device.card = msm_fd
        		v4l2.device.bus_info = ""
        		v4l2.device.version = 201287 (0x00031247)
        		v4l2.device.capabilities = 69206018 (0x04200002)
        		v4l2.device.device_caps = 2097152 (0x00200000)
        Output when my UVC camera is connected to my Linux PC;
        seeker3@seeker3-VirtualBox:~$ gst-device-monitor-1.0 Video/Source
        Probing devices...
        Device found:
        	class : Video/Source
        	caps  : video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction){ 30/1, 15/1 };
        	        video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
        	properties:
        		udev-probed = true
        		device.bus_path = pci-0000:00:0c.0-usb-0:2:1.0
        		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video0
        		device.bus = usb
        		device.subsystem = video4linux
        		device.vendor.id = 2560
        		device.vendor.name = e-ConSystems
        		device.product.id = c184
        		device.product.name = e-CAM83_USB
        		device.serial = e-ConSystems_e-CAM83_USB_00.00.01
        		device.capabilities = :capture:
        		device.api = v4l2
        		device.path = /dev/video0
        		v4l2.device.driver = uvcvideo
        		v4l2.device.card = e-CAM83_USB
        		v4l2.device.bus_info = usb-0000:00:0c.0-2
        		v4l2.device.version = 328933 (0x000504e5)
        		v4l2.device.capabilities = 2225078273 (0x84a00001)
        		v4l2.device.device_caps = 69206017 (0x04200001)
        	gst-launch-1.0 v4l2src ! ...
        Device found:
        	caps  : video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)15/1;
        	        image/jpeg, width=(int)1920, height=(int)1080, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)30/1;
        	properties:
        		udev-probed = true
        		sysfs.path = /sys/devices/pci0000:00/0000:00:0c.0/usb1/1-2/1-2:1.0/video4linux/video2
        		device.bus = usb
        		device.api = v4l2
        		device.path = /dev/video2
        	gst-launch-1.0 v4l2src device=/dev/video2 ! ...
        Probing devices...
        Device found:
        	name  : Monitor of Built-in Audio Analog Stereo
        	class : Audio/Source
        	caps  : audio/x-raw, format=(string){ S16LE, S16BE, F32LE, F32BE, S32LE, S32BE, S24LE, S24BE, S24_32LE, S24_32BE, U8 }, layout=(string)interleaved, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        	        audio/x-alaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        	        audio/x-mulaw, rate=(int)[ 1, 2147483647 ], channels=(int)[ 1, 32 ];
        	properties:
        		device.description = "Monitor\ of\ Built-in\ Audio\ Analog\ Stereo"
        		device.class = monitor
        		alsa.card = 0
        		alsa.card_name = "Intel\ 82801AA-ICH"
        		alsa.long_card_name = "Intel\ 82801AA-ICH\ with\ AD1980\ at\ irq\ 21"
        		alsa.driver_name = snd_intel8x0
        		device.bus_path = pci-0000:00:05.0
        		sysfs.path = /devices/pci0000:00/0000:00:05.0/sound/card0
        		device.bus = pci
        		device.vendor.id = 8086
        		device.vendor.name = "Intel\ Corporation"
        		device.product.id = 2415
        		device.product.name = "82801AA\ AC\'97\ Audio\ Controller"
        		device.form_factor = internal
        		device.string = 0
        		module-udev-detect.discovered = 1
        		device.icon_name = audio-card-pci
        	gst-launch-1.0 pulsesrc device=alsa_output.pci-0000_00_05.0.analog-stereo.monitor ! ...
        Device found:
        	name  : Built-in Audio Analog Stereo
        	properties:
        		alsa.resolution_bits = 16
        		device.api = alsa
        		device.class = sound
        		alsa.class = generic
        		alsa.subclass = generic-mix
        		alsa.name = "Intel\ 82801AA-ICH"
        		alsa.id = "Intel\ ICH"
        		alsa.subdevice = 0
        		alsa.subdevice_name = "subdevice\ \#0"
        		alsa.device = 0
        		alsa.card = 0
        		device.bus = pci
        		device.string = front:0
        		device.buffering.buffer_size = 17632
        		device.buffering.fragment_size = 4408
        		device.access_mode = mmap
        		device.profile.name = analog-stereo
        		device.profile.description = "Analog\ Stereo"
        		device.description = "Built-in\ Audio\ Analog\ Stereo"
        		alsa.mixer_name = "Analog\ Devices\ AD1980"
        		alsa.components = AC97a:41445370
        	gst-launch-1.0 pulsesrc device=alsa_input.pci-0000_00_05.0.analog-stereo ! ...
        Device found:
        	class : Audio/Sink
        	properties:
        		device.api = alsa
        		alsa.subdevice = 0
        		alsa.device = 0
        		alsa.card = 0
        		device.bus = pci
        		device.buffering.buffer_size = 19188
        		device.buffering.fragment_size = 6396
        	gst-launch-1.0 ... ! pulsesink device=alsa_output.pci-0000_00_05.0.analog-stereo
        Device found:
        	properties:
        		udev-probed = true
        		device.bus = usb
        		device.api = v4l2
        Device found:
        	properties:
        		udev-probed = true
        		device.bus = usb
        		device.api = v4l2
        A simple video test will not work either.
        voxl:~$ gst-launch-1.0 videotestsrc ! videoconvert ! autovideosink
        Setting pipeline to PAUSED ...
        Pipeline is PREROLLING ...
        WARNING: from element /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0: Resource not found.
        Additional debug info:
        /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/gst/autodetect/gstautodetect.c(347): gst_auto_detect_find_best (): /GstPipeline:pipeline0/GstAutoVideoSink:autovideosink0:
        Failed to find a usable video sink
        Pipeline is PREROLLED ...
        Setting pipeline to PLAYING ...
        New clock: GstSystemClock
        ^Chandling interrupt.
        Interrupt: Stopping pipeline ...
        Execution ended after 0:00:17.998587815
        Setting pipeline to READY ...
        Setting pipeline to NULL ...
        Freeing pipeline ...
        Are there any plugins that I could be missing?
        KrisK 1 Reply Last reply
        • KrisK Kris
          Probing devices...
          No devices found!
          Probing devices...
          Device found:
          	class : Video/Sink
          	properties:
          		udev-probed = false
          		device.api = v4l2
          Probing devices...
          Device found:
          	properties:
          		udev-probed = true
          		device.bus = usb
          		device.api = v4l2
          Device found:
          	properties:
          		udev-probed = true
          		device.bus = usb
          		device.api = v4l2
          Probing devices...
          Device found:
          	properties:
          		alsa.card = 0
          		device.bus = pci
          		device.string = 0
          Device found:
          	properties:
          		device.api = alsa
          		alsa.subdevice = 0
          		alsa.device = 0
          		alsa.card = 0
          		device.bus = pci
          Device found:
          	class : Audio/Sink
          	properties:
          		device.api = alsa
          		alsa.subdevice = 0
          		alsa.device = 0
          		alsa.card = 0
          		device.bus = pci
          Device found:
          	properties:
          		udev-probed = true
          		device.bus = usb
          		device.api = v4l2
          Device found:
          	properties:
          		udev-probed = true
          		device.bus = usb
          		device.api = v4l2
          KrisK Offline
          KrisK Offline
          Kris
          #18
          Keeps failing to find a usable video sink.
          voxl:~$ show-video-device-info.sh
          /dev/video2: e-CAM83_USB 2560:c184
          /dev/video3: e-CAM83_USB 2560:c184
          voxl:~$ gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
          ERROR: Pipeline doesn't want to pause.
          ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video3' for reading and writing.
          /opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-plugins-good/1.10.4-r0/gst-plugins-good-1.10.4/sys/v4l2/v4l2_calls.c(625): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
          system error: Device or resource busy
          voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! videoconvert ! autovideosink
          ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not open device '/dev/video2' for reading and writing.
          voxl:~$
          Output when debug command is used.
          voxl:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video3 ! videoconvert ! autovideosink
          0:00:00.229741613  4689    0xdf500 WARN              autodetect gstautodetect.c:347:gst_auto_detect_find_best:<autovideosink0> warning: Failed to find a usable video sink
          0:00:00.277135238  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: Could not open device '/dev/video3' for reading and writing.
          0:00:00.277213207  4689    0xdf500 WARN                    v4l2 v4l2_calls.c:625:gst_v4l2_open:<v4l2src0> error: system error: Device or resource busy
          • tomT Online
            tomT Online
            @Kris You can't use autovideosink on VOXL because it doesn't have a display
            • KrisK Kris
              voxl:~$
              @Kris Maybe try fakesink instead?
                KrisK Offline
                KrisK Offline
                Kris
                #21
                I have tried both fakesink and playbin.
                Neither of them work either.
                Has anyone gotten gstreamer to successfully work on VOXL1?
                  KrisK Offline
                  KrisK Offline
                  Kris
                  #22
                  I also have another UVC camera, but it only outputs MJPG (compressed) and YUY2 (uncompressed 640x480 30fps) formats.
                  It works for streaming, but I am trying to record the video to the Seeker’s SD card.
                  Is there a way to do this with Gstreamer or a similar program?
                    KrisK Offline
                    KrisK Offline
                    Kris
                    Could this be the reason why no devices are found when I use gst-device-monitor-1.0 Video/Source on the VOXL1?
                    • KrisK Offline
                      KrisK Offline
                      Kris
                      I see that the VOXL1 has the gst-plugins-good.
                      Is it possible to also add the gst-plugins-bad and gst-plugins-ugly?
                      • KrisK Kris
                        @Kris We use GStreamer in our voxl-streamer application. It does work on VOXL1.
                          KrisK Offline
                          KrisK Offline
                          Kris
                          Ok, thank you for the confirmation.
                            KrisK Offline
                            KrisK Offline
                            Kris
                            If possible, could you please provide me with a VOXL1 working pipeline (streaming or recording) using any UVC camera of your choice?
                            • KrisK Kris
                              @Kris That's not how it works on VOXL1. The voxl-uvc-server application places frames into an MPA pipe and the voxl-streamer application (based on gstreamer) reads those frames and processes them for output using RTSP. However, I do believe that I did try command line gst-launch-1.0 style pipelines with UVC cameras in the past and they worked. I don't have an example of one though. You may want to start with one of our supported UVC cameras first and then try to get your particular UVC camera working. I always start with the Logitech C270. We list the specific cameras that we support because each one caused us some issues and required code changes to make it work. We even had to fork the libuvc library in order to make changes to that to get some of the cameras working properly.
                                KrisK Offline
                                KrisK Offline
                                Kris
                                Ok, I understand.
                                Thank you for all your help and support with this issue.
                                I will try one of your tested & supported UVC cameras.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #30
                                  I bought the Logitech C270 and tried testing it with some Gstreamer commands.
                                  So far I have been able to use it on my Linux PC with these commands.
                                  Connected to PC and viewing video;
                                  gst-launch-1.0 -v v4l2src ! video/x-raw,format=YUY2 ! videoconvert ! autovideosink
                                  Connected to PC and recording to PC;
                                  gst-launch-1.0 v4l2src device=/dev/video0 ! image/jpeg,width=640,height=480,framerate=30/1 ! jpegdec ! x264enc ! qtmux ! filesink location=C270.mp4 -e
                                  However, when I connect the C270 to the Seeker I cannot get any of these to work.
                                  I have tried different video devices 0-3 and I have also substituted the autovideosink with fakesink but these changes are still not working.
                                  Could you please show me a Gstreamer example for this Logitech C270 camera that works on the Seeker?
                                  I would like to either stream, record, or stream+record (possibly using tee) the video using gst-launch-1.0.
                                  Thank you
