  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 23.5k Views 3 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    I have a feeling that maybe the problem is deriving from my camera’s GUID Format.
    Does the voxl-uvc-server accept GUID: 4832363400001000800000aa00389b71
    for h264 format?
    How would I go about correcting the guidFormat to match up with the voxl-uvc-server?
    • tomT Online
      tomT Online
      @Kris You can see supported format info here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c#L64
      Another thing to try out is using gstreamer instead of voxl-uvc-server + voxl-streamer with a pipeline similar to the following:
      gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.97 port=8554
      The pipeline may need to be tweaked slightly but it's one I've used before for other UVC cameras that voxl-uvc-server was unhappy with
      KrisK 4 Replies Last reply
        KrisK Offline
        KrisK Offline
        Kris
        Thank you, I will give this a try.
        I am trying to use H.264 on this camera.
        This is the second UVC camera that I’ve purchased because I am trying to log the frames from voxl-logger. From what I understand, H.264 output is the format that can do this.
        Is there a way to call for only the /dev/video2 to start with the voxl-uvc-server or gstreamer?
        Does the voxl-uvc-server accept h264 1920x1080 @30fps?
          KrisK Offline
          KrisK Offline
          Kris
          Do I paste this in the voxl terminal?
          Does this have uvc frame or video capture capabilities?
            KrisK Offline
            KrisK Offline
            Kris
            Sorry to bother you again, but I am not seeing the h264 format supported in the main.c script you provided for the voxl-uvc-server. Is it possible to edit the voxl-uvc-server main.c script to accept h264 format at 1920x1080 @30fps?
            • tomT Online
              tomT Online
              @Kris You can read more about how gstreamer and the gst-launch-1.0 command works here: https://gstreamer.freedesktop.org/documentation/tools/gst-launch.html?gi-language=c
              Yes, you would run that command on VOXL2. That specific command pulls frames from /dev/video22 (the UVC camera), it tells it to expect YUY2 formatted frames (you can change this to your liking) and then it converts it to an RTSP video stream. You could modify the pipeline to instead write to a file instead of streaming.
              There is a ton of documentation on gstreamer out there that can help you out with tailoring the pipeline.
              KrisK 1 Reply Last reply
                KrisK Offline
                KrisK Offline
                Kris
                Ok, thank you for the explanation.
                I will read up on gstreamer and try to figure this out.
                You mentioned that I would run this on VOXL2.
                I dont have a VOXL2. Does this work on VOXL for the Seeker?
                • tomT Online
                  tomT Online
                  @Kris Apologies, I'm not sure if that will work on VOXL1. Do you have a hires mipi sensor on your VOXL? It would allow you to avoid a lot of trouble
                  KrisK 3 Replies Last reply
                    KrisK Offline
                    KrisK Offline
                    Kris
                    wrote on last edited by Kris
                    #28
                    No, I dont have a hires mipi sensor on my VOXL. I am using the TOF, Stereo, and Tracking sensors specifically for indoor flights.
                    I am just trying to record frames or video from a connected uvc camera while in flight.
                    I am also trying to set one of my stereo cameras as the QVIO instead of the tracking camera. Again this is just for indoor flights. I have also asked about this QVIO setup in this thread, but have not received a response other than pointing to the extrinsics ModalAi page.
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #29
                      The command you sent me earlier this week did not work on the VOXL platform. I tried variations on both our e-CAM83 and Aruducam IMX335 uvc camera modules.
                      Could you please point me to a uvc camera that will work with the voxl-uvc-server?
                      Our main goal is to connect a uvc camera to the Seeker and be able to capture frames or video (streaming is not necessary) and send them to an onboard SD card (possibly using voxl-logger.
                      Would this Blue Robotics uvc module work? Meaning, is it capable of connecting to the voxl-uvc-server and be able to send frames and/or video to the onboard SD card using voxl-logger on the VOXL1 Seeker Dev Drone?
                        KrisK Offline
                        KrisK Offline
                        Kris
                        I have also noticed that when I updated my platform to 0.9 the streamer.conf has changed.
                        Now our Arducam IMX335 is not even working (it had no problems streaming before).
                        0.9 streamer.conf
                                "input-pipe":   "hires",
                                "bitrate":      1000000,
                                "decimator":    2,
                                "port": 8900,
                                "rotation":     0
                        3.8.0-0.7 streamer.conf
                            "conf-version":"1.3",
                            "configuration": "hires",
                            "uvc-generic": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "uvc" },
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 1,
                                        "bitrate": 1000000 } }
                            "uvc-flir-boson": {
                                "input": {
                                    "interface": "mpa",
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 512,
                                        "decimator": 2,
                            "uvc-flir-lepton": {
                                "input": {
                                    "interface": "mpa",
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 160,
                                        "height": 120,
                                        "bitrate": 500000 } }
                            "hires": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "hires" },
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 2,
                            "hires-logo": {
                                "input": {
                                    "interface": "mpa",
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 2,
                                        "bitrate": 1000000 } },
                                "overlay": {
                                    "location": "/etc/modalai/modalai.png",
                                    "offset_x": -1,
                                    "offset_y": -1 }
                            "stereo": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "stereo" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 960,
                                        "decimator": 2,
                            "tracking": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "tracking" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 2,
                            "dfs-disparity": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "dfs_disparity" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 2,
                            "qvio-overlay": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "qvio_overlay" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 544,
                                        "decimator": 2,
                            "tflite-overlay": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "tflite" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 480,
                                        "decimator": 2,
                            "hdmi-mpa": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "v4l2" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 360,
                                        "decimator": 2,
                            "gphoto2-mpa": {
                                "input": {
                                    "interface": "mpa",
                                    "mpa-camera": "gphoto2" },
                                "output": {
                                    "stream": {
                                        "width": 640,
                                        "height": 360,
                                        "decimator": 2,
                            "video-test": {
                                "input": {
                                    "interface": "test",
                                    "frame": {
                                        "width": 640,
                                        "height": 480,
                                        "format": "yuv420" } },
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 480,
                                        "rate": 30,
                            "uvc-video": {
                                "input": {
                                    "interface": "uvc",
                                    "device": "/dev/video0" },
                                "output": {
                                    "stream": {
                                        "rotation": 0,
                                        "width": 640,
                                        "height": 360,
                                        "rate": 15,
                          KrisK Offline
                          KrisK Offline
                          Kris
                          Do you happen to know some Gstreamer commands for the Logitech C270 uvc camera?
                          I am trying to get either a streaming or recording command to work on the Seeker, with no luck so far.
                          • tomT Online
                            tomT Online
                            wrote on last edited by tom
                            #32
                            @Kris I don't have that specific webcam or a VOXL1 but with a different one and a VOXL2, all I have to do is run voxl-uvc-server, see output below:
                            voxl2:/$ voxl-uvc-server
                            loading config file
                            Creating new config file: /etc/modalai/voxl-uvc-server.conf
                            width:                            640
                            height:                           480
                            fps:                              30
                            pipe_name:                        uvc
                            I'm able to pull up the stream using voxl-portal (going to IP of my VOXL2 in browser)
                            Then alternatively I'm able to use this gstreamer command:
                            gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.124 port=8554
                            to pull up the video stream in QGC
                            • tomT Online
                              tomT Online
                                loading config file
                                width:                            640
                                height:                           480
                                fps:                              30
                                pipe_name:                        uvc
                                KrisK Offline
                                KrisK Offline
                                Kris
                                Thank you for your examples.
                                I was asking about the C270 camera because @Eric-Katzfey had mentioned that he starts his camera testings with this model in order to locate where issues are coming from on other camera models.
                                I do appreciate your support.
                                I will continue to try different Gstreamer commands.
                                • tomT Online
                                  tomT Online
                                  @Kris I understand, your solution will likely be similar to what I posted above
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    #36
                                    I was able to stream the video from voxl-portal,
                                    voxl:~$ voxl-uvc-server -d
                                    Enabling debug messages
                                    voxl-uvc-server starting
                                    Image resolution 640x480, 30 fps chosen
                                    UVC initialized
                                    Device found
                                    Device opened
                                    uvc_get_stream_ctrl_format_size succeeded for format YUYV
                                    Streaming starting
                                    Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
                                     * got image 30
                                     * got image 60
                                     * got image 90
                                     * got image 120
                                     * got image 150
                                    but I cannot get the Gstreamer to work for QGC.
                                    Here is my ERROR;
                                    voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                                    Setting pipeline to PAUSED ...
                                    Pipeline is live and does not need PREROLL ...
                                    Setting pipeline to PLAYING ...
                                    New clock: GstSystemClock
                                    ERROR:/opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-omx/1.10.4-r0/gst-omx-1.10.4/omx/gstomxh264enc.c:532:gst_omx_h264_enc_get_caps: code should not be reached
                                    Aborted
                                    Maybe its a CAPS issue?
                                    I had to change x264 to omxh264, and had to completely remove speed-preset=ultrafast tune=zerolatency from the command because it wasnt playing well with VOXL1.
                                    • tomT Online
                                      tomT Online
                                      @Kris Well now that you have voxl-uvc-server working you should be able to use voxl-streamer on top of that to get a stream going
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        #38
                                        Yes, I am able to get the stream working with the voxl-streamer -i uvc command,
                                        but I am trying to get a Gstreamer command working so that I can build a pipeline to record the frames.
                                        voxl:~$ voxl-streamer -i uvc
                                        ERROR: object missing input-pipe
                                        WARNING: Failed to get default pipe name from configuration file
                                        ERROR: object missing bitrate
                                        WARNING: Failed to get default bitrate from configuration file
                                        Camera server Connected
                                        Stream available at rtsp://127.0.0.1:8900/live
                                        Gstreamer;
                                        voxl:~$ show-video-device-info.sh
                                        /dev/video2: UVC Camera (046d:0825) 046d:0825
                                        voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                                        or without width & height;
                                        voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                                        • KrisK Kris
                                          Gstreamer;
                                          @Kris The intention with the Logitech camera was to use it with voxl-uvc-streamer as Tom pointed out. That way you have a complete working setup and then you can start changing one thing at a time to get to what you want. If you want to switch to a different camera then you can see the differences in the new camera from the Logitech camera and try to debug that way. If you want to add a record feature with GStreamer then you can fork our voxl-streamer code and add the functionality into that. If you want to do it with a gst-launch-1.0 command line pipeline then you are farther away from anything we currently support and it's going to be hard for us to offer much help. I do think that what you are trying to do should be possible.
