  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 23.5k Views 3 Watching
  • KrisK Offline
    KrisK Offline
    Kris
    The rest of the information about my current uvc camera is here.
    • KrisK Offline
      KrisK Offline
      Kris
      Additional information;
        @Kris Yeah that's just the default that voxl-uvc-server uses if not explicitly specified otherwise with the -r flag.
        You can use show-video-device-info.sh and that may provide some clues.
        What is the part number or make and model of the UVC camera you're using? It's possible it's supported image formats don't match up with those supported by voxl-uvc-server
        KrisK Offline
        KrisK Offline
        Kris
        I gave this a try, but no luck.
        voxl:~$ voxl-uvc-server -d -r 1920x1080 -f 30
        Enabling debug messages
        voxl-uvc-server starting
        Image resolution 1920x1080, 30 fps chosen
        UVC initialized
        Device found
        uvc_open failed
        UVC exited
        voxl-uvc-server ending
          @Kris Are you sure that your UVC camera is 640x480 resolution?
          KrisK Offline
          KrisK Offline
          Kris
          voxl:~$ show-video-device-info.sh
          /dev/video2: e-CAM83_USB 2560:c184
          /dev/video3: e-CAM83_USB 2560:c184
          /dev/video2: is h264
          /dev/video3: is MJPG & YUY2
          • KrisK Offline
            KrisK Offline
            Kris
            voxl:~$ voxl-uvc-server -l
            *** START DEVICE LIST ***
            Found device 0
            Got device descriptor for 2560:c184 (null)
            Found device 2560:c184
            uvc_open failed, Return code: I/O error (-1)
            Found device 0
            uvc_open failed, Return code: No such device (-4)
            Found device 0
            uvc_find_device failed, Return code: No such device (-4)
            DEVICE CONFIGURATION (2560:c184/00.00.01) ---
            Status: idle
            VideoControl:
            	bcdUVC: 0x0100
            VideoStreaming(1):
            	bEndpointAddress: 129
            	Formats:
            	FrameFormat(1)
            		  bits per pixel: 16
            		  GUID: 4832363400001000800000aa00389b71 (H264)
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 00
            			  bit rate: 165888000-995328000
            			  max frame size: 0
            			  default interval: 1/15
            			  interval[0]: 1/30
            			  interval[1]: 1/15
            			FrameDescriptor(2)
            			  capabilities: 00
            			  max frame size: 0
            			  default interval: 1/30
            			  interval[0]: 1/30
            VideoStreaming(2):
            	bEndpointAddress: 136
            	Formats:
            	UncompressedFormat(1)
            		  bits per pixel: 16
            		  GUID: 5955593200001000800000aa00389b71 (YUY2)
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 00
            			  bit rate: 24576000-147456000
            			  max frame size: 614400
            			  interval[0]: 1/15
            	MJPEGFormat(2)
            		  bits per pixel: 0
            		  GUID: 4d4a5047000000000000000000000000 (MJPG)
            		  default frame: 1
            		  aspect ratio: 0x0
            		  interlace flags: 00
            		  copy protect: 00
            			FrameDescriptor(1)
            			  capabilities: 00
            			  interval[0]: 1/30
            END DEVICE CONFIGURATION
            *** END DEVICE LIST ***
              KrisK Offline
              KrisK Offline
              Kris
              May I ask what image formats the voxl-uvc-serversupports?
              • KrisK Offline
                KrisK Offline
                Kris
                I have a feeling that maybe the problem is deriving from my camera’s GUID Format.
                Does the voxl-uvc-server accept GUID: 4832363400001000800000aa00389b71
                for h264 format?
                How would I go about correcting the guidFormat to match up with the voxl-uvc-server?
                • tomT Online
                  tomT Online
                  @Kris You can see supported format info here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c#L64
                  Another thing to try out is using gstreamer instead of voxl-uvc-server + voxl-streamer with a pipeline similar to the following:
                  gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.97 port=8554
                  The pipeline may need to be tweaked slightly but it's one I've used before for other UVC cameras that voxl-uvc-server was unhappy with
                  KrisK 4 Replies Last reply
                    KrisK Offline
                    KrisK Offline
                    Kris
                    Thank you, I will give this a try.
                    I am trying to use H.264 on this camera.
                    This is the second UVC camera that I’ve purchased because I am trying to log the frames from voxl-logger. From what I understand, H.264 output is the format that can do this.
                    Is there a way to call for only the /dev/video2 to start with the voxl-uvc-server or gstreamer?
                    Does the voxl-uvc-server accept h264 1920x1080 @30fps?
                      KrisK Offline
                      KrisK Offline
                      Kris
                      Do I paste this in the voxl terminal?
                      Does this have uvc frame or video capture capabilities?
                        KrisK Offline
                        KrisK Offline
                        Kris
                        Sorry to bother you again, but I am not seeing the h264 format supported in the main.c script you provided for the voxl-uvc-server. Is it possible to edit the voxl-uvc-server main.c script to accept h264 format at 1920x1080 @30fps?
                        • tomT Online
                          tomT Online
                          @Kris You can read more about how gstreamer and the gst-launch-1.0 command works here: https://gstreamer.freedesktop.org/documentation/tools/gst-launch.html?gi-language=c
                          Yes, you would run that command on VOXL2. That specific command pulls frames from /dev/video22 (the UVC camera), it tells it to expect YUY2 formatted frames (you can change this to your liking) and then it converts it to an RTSP video stream. You could modify the pipeline to instead write to a file instead of streaming.
                          There is a ton of documentation on gstreamer out there that can help you out with tailoring the pipeline.
                          KrisK 1 Reply Last reply
                            KrisK Offline
                            KrisK Offline
                            Kris
                            Ok, thank you for the explanation.
                            I will read up on gstreamer and try to figure this out.
                            You mentioned that I would run this on VOXL2.
                            I dont have a VOXL2. Does this work on VOXL for the Seeker?
                            • tomT Online
                              tomT Online
                              @Kris Apologies, I'm not sure if that will work on VOXL1. Do you have a hires mipi sensor on your VOXL? It would allow you to avoid a lot of trouble
                              KrisK 3 Replies Last reply
                                KrisK Offline
                                KrisK Offline
                                Kris
                                wrote on last edited by Kris
                                #28
                                No, I dont have a hires mipi sensor on my VOXL. I am using the TOF, Stereo, and Tracking sensors specifically for indoor flights.
                                I am just trying to record frames or video from a connected uvc camera while in flight.
                                I am also trying to set one of my stereo cameras as the QVIO instead of the tracking camera. Again this is just for indoor flights. I have also asked about this QVIO setup in this thread, but have not received a response other than pointing to the extrinsics ModalAi page.
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  #29
                                  The command you sent me earlier this week did not work on the VOXL platform. I tried variations on both our e-CAM83 and Aruducam IMX335 uvc camera modules.
                                  Could you please point me to a uvc camera that will work with the voxl-uvc-server?
                                  Our main goal is to connect a uvc camera to the Seeker and be able to capture frames or video (streaming is not necessary) and send them to an onboard SD card (possibly using voxl-logger.
                                  Would this Blue Robotics uvc module work? Meaning, is it capable of connecting to the voxl-uvc-server and be able to send frames and/or video to the onboard SD card using voxl-logger on the VOXL1 Seeker Dev Drone?
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    I have also noticed that when I updated my platform to 0.9 the streamer.conf has changed.
                                    Now our Arducam IMX335 is not even working (it had no problems streaming before).
                                    0.9 streamer.conf
                                            "input-pipe":   "hires",
                                            "bitrate":      1000000,
                                            "decimator":    2,
                                            "port": 8900,
                                            "rotation":     0
                                    3.8.0-0.7 streamer.conf
                                        "conf-version":"1.3",
                                        "configuration": "hires",
                                        "uvc-generic": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "uvc" },
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 1,
                                                    "bitrate": 1000000 } }
                                        "uvc-flir-boson": {
                                            "input": {
                                                "interface": "mpa",
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 512,
                                                    "decimator": 2,
                                        "uvc-flir-lepton": {
                                            "input": {
                                                "interface": "mpa",
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 160,
                                                    "height": 120,
                                                    "bitrate": 500000 } }
                                        "hires": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "hires" },
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 2,
                                        "hires-logo": {
                                            "input": {
                                                "interface": "mpa",
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 2,
                                                    "bitrate": 1000000 } },
                                            "overlay": {
                                                "location": "/etc/modalai/modalai.png",
                                                "offset_x": -1,
                                                "offset_y": -1 }
                                        "stereo": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "stereo" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 960,
                                                    "decimator": 2,
                                        "tracking": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "tracking" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 2,
                                        "dfs-disparity": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "dfs_disparity" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 2,
                                        "qvio-overlay": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "qvio_overlay" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 544,
                                                    "decimator": 2,
                                        "tflite-overlay": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "tflite" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 480,
                                                    "decimator": 2,
                                        "hdmi-mpa": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "v4l2" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 360,
                                                    "decimator": 2,
                                        "gphoto2-mpa": {
                                            "input": {
                                                "interface": "mpa",
                                                "mpa-camera": "gphoto2" },
                                            "output": {
                                                "stream": {
                                                    "width": 640,
                                                    "height": 360,
                                                    "decimator": 2,
                                        "video-test": {
                                            "input": {
                                                "interface": "test",
                                                "frame": {
                                                    "width": 640,
                                                    "height": 480,
                                                    "format": "yuv420" } },
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 480,
                                                    "rate": 30,
                                        "uvc-video": {
                                            "input": {
                                                "interface": "uvc",
                                                "device": "/dev/video0" },
                                            "output": {
                                                "stream": {
                                                    "rotation": 0,
                                                    "width": 640,
                                                    "height": 360,
                                                    "rate": 15,
                                      KrisK Offline
                                      KrisK Offline
                                      Kris
                                      Do you happen to know some Gstreamer commands for the Logitech C270 uvc camera?
                                      I am trying to get either a streaming or recording command to work on the Seeker, with no luck so far.
                                      • tomT Online
                                        tomT Online
                                        wrote on last edited by tom
                                        #32
                                        @Kris I don't have that specific webcam or a VOXL1 but with a different one and a VOXL2, all I have to do is run voxl-uvc-server, see output below:
                                        voxl2:/$ voxl-uvc-server
                                        loading config file
                                        Creating new config file: /etc/modalai/voxl-uvc-server.conf
                                        width:                            640
                                        height:                           480
                                        fps:                              30
                                        pipe_name:                        uvc
                                        I'm able to pull up the stream using voxl-portal (going to IP of my VOXL2 in browser)
                                        Then alternatively I'm able to use this gstreamer command:
                                        gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.124 port=8554
                                        to pull up the video stream in QGC
                                        • tomT Online
                                          tomT Online
