  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 22.9k Views 3 Watching
    @Kris Are you sure that your UVC camera is 640x480 resolution?
    KrisK 2 Replies Last reply
      KrisK Offline
      KrisK Offline
      Kris
      Yes, in the debug messages, it says that it is 640x480.
      Is there another way to check the resolution?
        @Kris Yeah that's just the default that voxl-uvc-server uses if not explicitly specified otherwise with the -r flag.
        You can use show-video-device-info.sh and that may provide some clues.
        What is the part number or make and model of the UVC camera you're using? It's possible it's supported image formats don't match up with those supported by voxl-uvc-server
        KrisK 4 Replies Last reply
          KrisK Offline
          KrisK Offline
          Kris
          @tom Ok, Thank you I will try that now.
          Here are some details of my UVC 2.0 camera.
            KrisK Offline
            KrisK Offline
            Kris
            This is all the information I get from show-video-device-info.sh
            voxl:~$ show-video-device-info.sh
            /dev/video2: e-CAM83_USB 2560:c184
            /dev/video3: e-CAM83_USB 2560:c184
            • KrisK Offline
              KrisK Offline
              Kris
              wrote on last edited by Kris
              #13
              Is there any chance I can get 1920 x 1080 @30 fps using h264 in the voxl-uvc-server?
              Or is 640 x 480 the only option in the voxl-uvc-server?
              • KrisK Offline
                KrisK Offline
                Kris
                The rest of the information about my current uvc camera is here.
                • KrisK Offline
                  KrisK Offline
                  Kris
                  Additional information;
                    KrisK Offline
                    KrisK Offline
                    Kris
                    I gave this a try, but no luck.
                    voxl:~$ voxl-uvc-server -d -r 1920x1080 -f 30
                    Enabling debug messages
                    voxl-uvc-server starting
                    Image resolution 1920x1080, 30 fps chosen
                    UVC initialized
                    Device found
                    uvc_open failed
                    UVC exited
                    voxl-uvc-server ending
                      KrisK Offline
                      KrisK Offline
                      Kris
                      /dev/video2: is h264
                      /dev/video3: is MJPG & YUY2
                      • KrisK Offline
                        KrisK Offline
                        Kris
                        voxl:~$ voxl-uvc-server -l
                        *** START DEVICE LIST ***
                        Found device 0
                        Got device descriptor for 2560:c184 (null)
                        Found device 2560:c184
                        uvc_open failed, Return code: I/O error (-1)
                        Found device 0
                        uvc_open failed, Return code: No such device (-4)
                        Found device 0
                        uvc_find_device failed, Return code: No such device (-4)
                        DEVICE CONFIGURATION (2560:c184/00.00.01) ---
                        Status: idle
                        VideoControl:
                        	bcdUVC: 0x0100
                        VideoStreaming(1):
                        	bEndpointAddress: 129
                        	Formats:
                        	FrameFormat(1)
                        		  bits per pixel: 16
                        		  GUID: 4832363400001000800000aa00389b71 (H264)
                        		  default frame: 1
                        		  aspect ratio: 0x0
                        		  interlace flags: 00
                        		  copy protect: 00
                        			FrameDescriptor(1)
                        			  capabilities: 00
                        			  bit rate: 165888000-995328000
                        			  max frame size: 0
                        			  default interval: 1/15
                        			  interval[0]: 1/30
                        			  interval[1]: 1/15
                        			FrameDescriptor(2)
                        			  capabilities: 00
                        			  max frame size: 0
                        			  default interval: 1/30
                        			  interval[0]: 1/30
                        VideoStreaming(2):
                        	bEndpointAddress: 136
                        	Formats:
                        	UncompressedFormat(1)
                        		  bits per pixel: 16
                        		  GUID: 5955593200001000800000aa00389b71 (YUY2)
                        		  default frame: 1
                        		  aspect ratio: 0x0
                        		  interlace flags: 00
                        		  copy protect: 00
                        			FrameDescriptor(1)
                        			  capabilities: 00
                        			  bit rate: 24576000-147456000
                        			  max frame size: 614400
                        			  interval[0]: 1/15
                        	MJPEGFormat(2)
                        		  bits per pixel: 0
                        		  GUID: 4d4a5047000000000000000000000000 (MJPG)
                        		  default frame: 1
                        		  aspect ratio: 0x0
                        		  interlace flags: 00
                        		  copy protect: 00
                        			FrameDescriptor(1)
                        			  capabilities: 00
                        			  interval[0]: 1/30
                        END DEVICE CONFIGURATION
                        *** END DEVICE LIST ***
                          KrisK Offline
                          KrisK Offline
                          Kris
                          May I ask what image formats the voxl-uvc-serversupports?
                          • KrisK Offline
                            KrisK Offline
                            Kris
                            I have a feeling that maybe the problem is deriving from my camera’s GUID Format.
                            Does the voxl-uvc-server accept GUID: 4832363400001000800000aa00389b71
                            for h264 format?
                            How would I go about correcting the guidFormat to match up with the voxl-uvc-server?
                              @Kris You can see supported format info here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c#L64
                              Another thing to try out is using gstreamer instead of voxl-uvc-server + voxl-streamer with a pipeline similar to the following:
                              gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.97 port=8554
                              The pipeline may need to be tweaked slightly but it's one I've used before for other UVC cameras that voxl-uvc-server was unhappy with
                                KrisK Offline
                                KrisK Offline
                                Kris
                                Thank you, I will give this a try.
                                I am trying to use H.264 on this camera.
                                This is the second UVC camera that I’ve purchased because I am trying to log the frames from voxl-logger. From what I understand, H.264 output is the format that can do this.
                                Is there a way to call for only the /dev/video2 to start with the voxl-uvc-server or gstreamer?
                                Does the voxl-uvc-server accept h264 1920x1080 @30fps?
                                  KrisK Offline
                                  KrisK Offline
                                  Kris
                                  Do I paste this in the voxl terminal?
                                  Does this have uvc frame or video capture capabilities?
                                    KrisK Offline
                                    KrisK Offline
                                    Kris
                                    Sorry to bother you again, but I am not seeing the h264 format supported in the main.c script you provided for the voxl-uvc-server. Is it possible to edit the voxl-uvc-server main.c script to accept h264 format at 1920x1080 @30fps?
                                      @Kris You can read more about how gstreamer and the gst-launch-1.0 command works here: https://gstreamer.freedesktop.org/documentation/tools/gst-launch.html?gi-language=c
                                      Yes, you would run that command on VOXL2. That specific command pulls frames from /dev/video22 (the UVC camera), it tells it to expect YUY2 formatted frames (you can change this to your liking) and then it converts it to an RTSP video stream. You could modify the pipeline to instead write to a file instead of streaming.
                                      There is a ton of documentation on gstreamer out there that can help you out with tailoring the pipeline.
                                      KrisK 1 Reply Last reply
                                        KrisK Offline
                                        KrisK Offline
                                        Kris
                                        Ok, thank you for the explanation.
                                        I will read up on gstreamer and try to figure this out.
                                        You mentioned that I would run this on VOXL2.
                                        I dont have a VOXL2. Does this work on VOXL for the Seeker?
                                          @Kris Apologies, I'm not sure if that will work on VOXL1. Do you have a hires mipi sensor on your VOXL? It would allow you to avoid a lot of trouble
                                          KrisK 3 Replies Last reply
