  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 23.5k Views 3 Watching
    @Kris You can see supported format info here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c#L64
    Another thing to try out is using gstreamer instead of voxl-uvc-server + voxl-streamer with a pipeline similar to the following:
    gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.97 port=8554
    The pipeline may need to be tweaked slightly but it's one I've used before for other UVC cameras that voxl-uvc-server was unhappy with
    KrisK Offline
    KrisK Offline
    Kris
    Sorry to bother you again, but I am not seeing the h264 format supported in the main.c script you provided for the voxl-uvc-server. Is it possible to edit the voxl-uvc-server main.c script to accept h264 format at 1920x1080 @30fps?
    • tomT Online
      tomT Online
      @Kris You can read more about how gstreamer and the gst-launch-1.0 command works here: https://gstreamer.freedesktop.org/documentation/tools/gst-launch.html?gi-language=c
      Yes, you would run that command on VOXL2. That specific command pulls frames from /dev/video22 (the UVC camera), it tells it to expect YUY2 formatted frames (you can change this to your liking) and then it converts it to an RTSP video stream. You could modify the pipeline to instead write to a file instead of streaming.
      There is a ton of documentation on gstreamer out there that can help you out with tailoring the pipeline.
      KrisK 1 Reply Last reply
        KrisK Offline
        KrisK Offline
        Kris
        Ok, thank you for the explanation.
        I will read up on gstreamer and try to figure this out.
        You mentioned that I would run this on VOXL2.
        I dont have a VOXL2. Does this work on VOXL for the Seeker?
        • tomT Online
          tomT Online
          @Kris Apologies, I'm not sure if that will work on VOXL1. Do you have a hires mipi sensor on your VOXL? It would allow you to avoid a lot of trouble
          KrisK 3 Replies Last reply
            KrisK Offline
            KrisK Offline
            Kris
            wrote on last edited by Kris
            #28
            No, I dont have a hires mipi sensor on my VOXL. I am using the TOF, Stereo, and Tracking sensors specifically for indoor flights.
            I am just trying to record frames or video from a connected uvc camera while in flight.
            I am also trying to set one of my stereo cameras as the QVIO instead of the tracking camera. Again this is just for indoor flights. I have also asked about this QVIO setup in this thread, but have not received a response other than pointing to the extrinsics ModalAi page.
              KrisK Offline
              KrisK Offline
              Kris
              #29
              The command you sent me earlier this week did not work on the VOXL platform. I tried variations on both our e-CAM83 and Aruducam IMX335 uvc camera modules.
              Could you please point me to a uvc camera that will work with the voxl-uvc-server?
              Our main goal is to connect a uvc camera to the Seeker and be able to capture frames or video (streaming is not necessary) and send them to an onboard SD card (possibly using voxl-logger.
              Would this Blue Robotics uvc module work? Meaning, is it capable of connecting to the voxl-uvc-server and be able to send frames and/or video to the onboard SD card using voxl-logger on the VOXL1 Seeker Dev Drone?
                KrisK Offline
                KrisK Offline
                Kris
                I have also noticed that when I updated my platform to 0.9 the streamer.conf has changed.
                Now our Arducam IMX335 is not even working (it had no problems streaming before).
                0.9 streamer.conf
                        "input-pipe":   "hires",
                        "bitrate":      1000000,
                        "decimator":    2,
                        "port": 8900,
                        "rotation":     0
                3.8.0-0.7 streamer.conf
                    "conf-version":"1.3",
                    "configuration": "hires",
                    "uvc-generic": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "uvc" },
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 480,
                                "decimator": 1,
                                "bitrate": 1000000 } }
                    "uvc-flir-boson": {
                        "input": {
                            "interface": "mpa",
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 512,
                                "decimator": 2,
                    "uvc-flir-lepton": {
                        "input": {
                            "interface": "mpa",
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 160,
                                "height": 120,
                                "bitrate": 500000 } }
                    "hires": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "hires" },
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 480,
                                "decimator": 2,
                    "hires-logo": {
                        "input": {
                            "interface": "mpa",
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 480,
                                "decimator": 2,
                                "bitrate": 1000000 } },
                        "overlay": {
                            "location": "/etc/modalai/modalai.png",
                            "offset_x": -1,
                            "offset_y": -1 }
                    "stereo": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "stereo" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 960,
                                "decimator": 2,
                    "tracking": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "tracking" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 480,
                                "decimator": 2,
                    "dfs-disparity": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "dfs_disparity" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 480,
                                "decimator": 2,
                    "qvio-overlay": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "qvio_overlay" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 544,
                                "decimator": 2,
                    "tflite-overlay": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "tflite" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 480,
                                "decimator": 2,
                    "hdmi-mpa": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "v4l2" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 360,
                                "decimator": 2,
                    "gphoto2-mpa": {
                        "input": {
                            "interface": "mpa",
                            "mpa-camera": "gphoto2" },
                        "output": {
                            "stream": {
                                "width": 640,
                                "height": 360,
                                "decimator": 2,
                    "video-test": {
                        "input": {
                            "interface": "test",
                            "frame": {
                                "width": 640,
                                "height": 480,
                                "format": "yuv420" } },
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 480,
                                "rate": 30,
                    "uvc-video": {
                        "input": {
                            "interface": "uvc",
                            "device": "/dev/video0" },
                        "output": {
                            "stream": {
                                "rotation": 0,
                                "width": 640,
                                "height": 360,
                                "rate": 15,
                  KrisK Offline
                  KrisK Offline
                  Kris
                  Do you happen to know some Gstreamer commands for the Logitech C270 uvc camera?
                  I am trying to get either a streaming or recording command to work on the Seeker, with no luck so far.
                  • tomT Online
                    tomT Online
                    wrote on last edited by tom
                    #32
                    @Kris I don't have that specific webcam or a VOXL1 but with a different one and a VOXL2, all I have to do is run voxl-uvc-server, see output below:
                    voxl2:/$ voxl-uvc-server
                    loading config file
                    Creating new config file: /etc/modalai/voxl-uvc-server.conf
                    width:                            640
                    height:                           480
                    fps:                              30
                    pipe_name:                        uvc
                    I'm able to pull up the stream using voxl-portal (going to IP of my VOXL2 in browser)
                    Then alternatively I'm able to use this gstreamer command:
                    gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.124 port=8554
                    to pull up the video stream in QGC
                    • tomT Online
                      tomT Online
                        loading config file
                        width:                            640
                        height:                           480
                        fps:                              30
                        pipe_name:                        uvc
                        KrisK Offline
                        KrisK Offline
                        Kris
                        Thank you for your examples.
                        I was asking about the C270 camera because @Eric-Katzfey had mentioned that he starts his camera testings with this model in order to locate where issues are coming from on other camera models.
                        I do appreciate your support.
                        I will continue to try different Gstreamer commands.
                        • tomT Online
                          tomT Online
                          @Kris I understand, your solution will likely be similar to what I posted above
                            KrisK Offline
                            KrisK Offline
                            Kris
                            #36
                            I was able to stream the video from voxl-portal,
                            voxl:~$ voxl-uvc-server -d
                            Enabling debug messages
                            voxl-uvc-server starting
                            Image resolution 640x480, 30 fps chosen
                            UVC initialized
                            Device found
                            Device opened
                            uvc_get_stream_ctrl_format_size succeeded for format YUYV
                            Streaming starting
                            Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
                             * got image 30
                             * got image 60
                             * got image 90
                             * got image 120
                             * got image 150
                            but I cannot get the Gstreamer to work for QGC.
                            Here is my ERROR;
                            voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                            Setting pipeline to PAUSED ...
                            Pipeline is live and does not need PREROLL ...
                            Setting pipeline to PLAYING ...
                            New clock: GstSystemClock
                            ERROR:/opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-omx/1.10.4-r0/gst-omx-1.10.4/omx/gstomxh264enc.c:532:gst_omx_h264_enc_get_caps: code should not be reached
                            Aborted
                            Maybe its a CAPS issue?
                            I had to change x264 to omxh264, and had to completely remove speed-preset=ultrafast tune=zerolatency from the command because it wasnt playing well with VOXL1.
                            • tomT Online
                              tomT Online
                              @Kris Well now that you have voxl-uvc-server working you should be able to use voxl-streamer on top of that to get a stream going
                                KrisK Offline
                                KrisK Offline
                                Kris
                                #38
                                Yes, I am able to get the stream working with the voxl-streamer -i uvc command,
                                but I am trying to get a Gstreamer command working so that I can build a pipeline to record the frames.
                                voxl:~$ voxl-streamer -i uvc
                                ERROR: object missing input-pipe
                                WARNING: Failed to get default pipe name from configuration file
                                ERROR: object missing bitrate
                                WARNING: Failed to get default bitrate from configuration file
                                Camera server Connected
                                Stream available at rtsp://127.0.0.1:8900/live
                                Gstreamer;
                                voxl:~$ show-video-device-info.sh
                                /dev/video2: UVC Camera (046d:0825) 046d:0825
                                voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                                or without width & height;
                                voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                                • KrisK Kris
                                  Gstreamer;
                                  @Kris The intention with the Logitech camera was to use it with voxl-uvc-streamer as Tom pointed out. That way you have a complete working setup and then you can start changing one thing at a time to get to what you want. If you want to switch to a different camera then you can see the differences in the new camera from the Logitech camera and try to debug that way. If you want to add a record feature with GStreamer then you can fork our voxl-streamer code and add the functionality into that. If you want to do it with a gst-launch-1.0 command line pipeline then you are farther away from anything we currently support and it's going to be hard for us to offer much help. I do think that what you are trying to do should be possible.
