  3. uvc_get_stream_ctrl_format_size failed
39 Posts 3 Posters 23.5k Views 3 Watching
  • tomT Online
    tomT Online
    @Kris Apologies, I'm not sure if that will work on VOXL1. Do you have a hires mipi sensor on your VOXL? It would allow you to avoid a lot of trouble
    KrisK 3 Replies Last reply
      KrisK Offline
      KrisK Offline
      Kris
      wrote on last edited by Kris
      #28
      No, I dont have a hires mipi sensor on my VOXL. I am using the TOF, Stereo, and Tracking sensors specifically for indoor flights.
      I am just trying to record frames or video from a connected uvc camera while in flight.
      I am also trying to set one of my stereo cameras as the QVIO instead of the tracking camera. Again this is just for indoor flights. I have also asked about this QVIO setup in this thread, but have not received a response other than pointing to the extrinsics ModalAi page.
        KrisK Offline
        KrisK Offline
        Kris
        #29
        The command you sent me earlier this week did not work on the VOXL platform. I tried variations on both our e-CAM83 and Aruducam IMX335 uvc camera modules.
        Could you please point me to a uvc camera that will work with the voxl-uvc-server?
        Our main goal is to connect a uvc camera to the Seeker and be able to capture frames or video (streaming is not necessary) and send them to an onboard SD card (possibly using voxl-logger.
        Would this Blue Robotics uvc module work? Meaning, is it capable of connecting to the voxl-uvc-server and be able to send frames and/or video to the onboard SD card using voxl-logger on the VOXL1 Seeker Dev Drone?
          KrisK Offline
          KrisK Offline
          Kris
          I have also noticed that when I updated my platform to 0.9 the streamer.conf has changed.
          Now our Arducam IMX335 is not even working (it had no problems streaming before).
          0.9 streamer.conf
                  "input-pipe":   "hires",
                  "bitrate":      1000000,
                  "decimator":    2,
                  "port": 8900,
                  "rotation":     0
          3.8.0-0.7 streamer.conf
              "conf-version":"1.3",
              "configuration": "hires",
              "uvc-generic": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "uvc" },
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 480,
                          "decimator": 1,
                          "bitrate": 1000000 } }
              "uvc-flir-boson": {
                  "input": {
                      "interface": "mpa",
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 512,
                          "decimator": 2,
              "uvc-flir-lepton": {
                  "input": {
                      "interface": "mpa",
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 160,
                          "height": 120,
                          "bitrate": 500000 } }
              "hires": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "hires" },
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 480,
                          "decimator": 2,
              "hires-logo": {
                  "input": {
                      "interface": "mpa",
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 480,
                          "decimator": 2,
                          "bitrate": 1000000 } },
                  "overlay": {
                      "location": "/etc/modalai/modalai.png",
                      "offset_x": -1,
                      "offset_y": -1 }
              "stereo": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "stereo" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 960,
                          "decimator": 2,
              "tracking": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "tracking" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 480,
                          "decimator": 2,
              "dfs-disparity": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "dfs_disparity" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 480,
                          "decimator": 2,
              "qvio-overlay": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "qvio_overlay" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 544,
                          "decimator": 2,
              "tflite-overlay": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "tflite" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 480,
                          "decimator": 2,
              "hdmi-mpa": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "v4l2" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 360,
                          "decimator": 2,
              "gphoto2-mpa": {
                  "input": {
                      "interface": "mpa",
                      "mpa-camera": "gphoto2" },
                  "output": {
                      "stream": {
                          "width": 640,
                          "height": 360,
                          "decimator": 2,
              "video-test": {
                  "input": {
                      "interface": "test",
                      "frame": {
                          "width": 640,
                          "height": 480,
                          "format": "yuv420" } },
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 480,
                          "rate": 30,
              "uvc-video": {
                  "input": {
                      "interface": "uvc",
                      "device": "/dev/video0" },
                  "output": {
                      "stream": {
                          "rotation": 0,
                          "width": 640,
                          "height": 360,
                          "rate": 15,
            @Kris You can see supported format info here: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-uvc-server/-/blob/master/src/main.c#L64
            Another thing to try out is using gstreamer instead of voxl-uvc-server + voxl-streamer with a pipeline similar to the following:
            gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.97 port=8554
            The pipeline may need to be tweaked slightly but it's one I've used before for other UVC cameras that voxl-uvc-server was unhappy with
            KrisK Offline
            KrisK Offline
            Kris
            Do you happen to know some Gstreamer commands for the Logitech C270 uvc camera?
            I am trying to get either a streaming or recording command to work on the Seeker, with no luck so far.
            • tomT Online
              tomT Online
              wrote on last edited by tom
              #32
              @Kris I don't have that specific webcam or a VOXL1 but with a different one and a VOXL2, all I have to do is run voxl-uvc-server, see output below:
              voxl2:/$ voxl-uvc-server
              loading config file
              Creating new config file: /etc/modalai/voxl-uvc-server.conf
              width:                            640
              height:                           480
              fps:                              30
              pipe_name:                        uvc
              I'm able to pull up the stream using voxl-portal (going to IP of my VOXL2 in browser)
              Then alternatively I'm able to use this gstreamer command:
              gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! x264enc speed-preset=ultrafast tune=zerolatency ! rtph264pay name=pay0 ! udpsink host=192.168.1.124 port=8554
              to pull up the video stream in QGC
              KrisK 1 Reply Last reply
              • tomT Online
                tomT Online
                  loading config file
                  width:                            640
                  height:                           480
                  fps:                              30
                  pipe_name:                        uvc
                  KrisK Offline
                  KrisK Offline
                  Kris
                  Thank you for your examples.
                  I was asking about the C270 camera because @Eric-Katzfey had mentioned that he starts his camera testings with this model in order to locate where issues are coming from on other camera models.
                  I do appreciate your support.
                  I will continue to try different Gstreamer commands.
                  • tomT Online
                    tomT Online
                    @Kris I understand, your solution will likely be similar to what I posted above
                      KrisK Offline
                      KrisK Offline
                      Kris
                      #36
                      I was able to stream the video from voxl-portal,
                      voxl:~$ voxl-uvc-server -d
                      Enabling debug messages
                      voxl-uvc-server starting
                      Image resolution 640x480, 30 fps chosen
                      UVC initialized
                      Device found
                      Device opened
                      uvc_get_stream_ctrl_format_size succeeded for format YUYV
                      Streaming starting
                      Got frame callback! frame_format = 3, width = 640, height = 480, length = 614400, ptr = (nil)
                       * got image 30
                       * got image 60
                       * got image 90
                       * got image 120
                       * got image 150
                      but I cannot get the Gstreamer to work for QGC.
                      Here is my ERROR;
                      voxl:~$ gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                      Setting pipeline to PAUSED ...
                      Pipeline is live and does not need PREROLL ...
                      Setting pipeline to PLAYING ...
                      New clock: GstSystemClock
                      ERROR:/opt/workspace/build/apq8096-le-1-0-1_ap_standard_oem.git/apps_proc/poky/build/tmp-glibc/work/armv7a-vfp-neon-oemllib32-linux-gnueabi/lib32-gstreamer1.0-omx/1.10.4-r0/gst-omx-1.10.4/omx/gstomxh264enc.c:532:gst_omx_h264_enc_get_caps: code should not be reached
                      Aborted
                      Maybe its a CAPS issue?
                      I had to change x264 to omxh264, and had to completely remove speed-preset=ultrafast tune=zerolatency from the command because it wasnt playing well with VOXL1.
                      • tomT Online
                        tomT Online
                        @Kris Well now that you have voxl-uvc-server working you should be able to use voxl-streamer on top of that to get a stream going
                          KrisK Offline
                          KrisK Offline
                          Kris
                          #38
                          Yes, I am able to get the stream working with the voxl-streamer -i uvc command,
                          but I am trying to get a Gstreamer command working so that I can build a pipeline to record the frames.
                          voxl:~$ voxl-streamer -i uvc
                          ERROR: object missing input-pipe
                          WARNING: Failed to get default pipe name from configuration file
                          ERROR: object missing bitrate
                          WARNING: Failed to get default bitrate from configuration file
                          Camera server Connected
                          Stream available at rtsp://127.0.0.1:8900/live
                          Gstreamer;
                          voxl:~$ show-video-device-info.sh
                          /dev/video2: UVC Camera (046d:0825) 046d:0825
                          voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,width=640,height=480,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                          or without width & height;
                          voxl:~$ sudo gst-launch-1.0 v4l2src device=/dev/video2 ! video/x-raw,format=YUY2 ! videoconvert ! omxh264enc ! rtph264pay name=pay0 ! udpsink host=192.168.110.152 port=8554
                          • KrisK Kris
                            Gstreamer;
                            @Kris The intention with the Logitech camera was to use it with voxl-uvc-streamer as Tom pointed out. That way you have a complete working setup and then you can start changing one thing at a time to get to what you want. If you want to switch to a different camera then you can see the differences in the new camera from the Logitech camera and try to debug that way. If you want to add a record feature with GStreamer then you can fork our voxl-streamer code and add the functionality into that. If you want to do it with a gst-launch-1.0 command line pipeline then you are farther away from anything we currently support and it's going to be hard for us to offer much help. I do think that what you are trying to do should be possible.
