  3. Sentinel VOXL2 Microhard not running
38 Posts 3 Posters 9.3k Views 1 Watching
  • R Offline
    R Offline
    rohitpillai
    Oh cool! Is there anything I can do to help from my side to figure this out?
      wrote on last edited by tom
      #17
      @rohitpillai I will let you know if I need anything from you. I'm screwing around with the voxl-modem source code right now to try to figure out how to fix the issue. I think I've already found a couple things that could resolve it.
      I'll update once I get it going, I may generate a new voxl-modem deb package for you to try out
      • R Offline
        R Offline
        rohitpillai
        Sounds good!
          @rohitpillai I believe I have fixed the issue. voxl-modem was jumping ahead and assuming that the modem had enumerated before it had which would cause some of the commands to never be run.
          I have generated a new dev package for you to try out, the download link is:
          404 Not Found
          favicon
          (voxl-packages.modalai.com)
          You can take a look at the source code changes here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/commit/0cc330f8fcd6cafc97b80412dfe9994b8389e90b
          In order to try this package out, do the following:
          • download the voxl-modem_0.15.2-202206291955_arm64.deb package using the above link
          • push the package to your VOXL2 in the directory you'd like (I'll use /data) using:
          adb push voxl-modem_0.15.2-202206291955_arm64.deb /data
          • Force remove the voxl-modem package on board:
          adb shell
          dpkg --purge --force-all voxl-modem
          • Install the new dev package:
          cd /data
          dpkg -i voxl-modem_0.15.2-202206291955_arm64.deb
          • Re-run voxl-configure-modem and choose the IP to your liking
          Verify that the network interface comes up and the IP is what you expect with ifconfig
          Try a couple reboots to confirm that the expected behavior is consistent.
          Let me know if you need any clarity on the above and let me know the outcome of your tests.
          The usb0 network interface won't come up immediately after reboot (may take 10-15 seconds) for it to enumerate
          • R Offline
            R Offline
            rohitpillai
            After a couple of reboots I am getting the same behaviour. It works as it should now! Thanks!
              @rohitpillai Woot! Thank you for all of your help! I will go ahead and merge this into master so that it will make it into the next release.
              wilkinsafW 1 Reply Last reply
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                @tom Hey Tom,
                I am noticing this issue of microhard not having a static ip on my system as well.
                It appears I am on a later version than the one in the post. Is the voxl-static-ip service now the preferred way to have a static ip?
                • wilkinsafW wilkinsaf
                  @tom Hey Tom,
                  wilkinsafW Offline
                  wilkinsafW Offline
                  wilkinsaf
                  @wilkinsaf Code is still there
                    wilkinsafW Offline
                    wilkinsafW Offline
                    wilkinsaf
                    @wilkinsaf But ip still is not what is in the config file
                    ip address: 1e15d9f5-c3a7-4e66-83d3-d6f88ab6cd7d-image.png
                    config file:
                      @wilkinsaf Interesting, give voxl-static-ip a try and see if it helps. I have yet to integrate that directly into voxl-modem. We have a systemd service setup for it, so I would go ahead and modify /usr/bin/voxl-static-ip and then enable it's service systemctl enable voxl-static-ip
                        wilkinsafW Offline
                        wilkinsafW Offline
                        wilkinsaf
                        @tom I did, but i had to add in a huge sleeper and have it After=voxl-modem.service
                        since the voxl-modem is a python script (thank you for that) I am just doing some caveman debugging. will post progress
                          @wilkinsaf voxl-static-ip is pretty "dumb" as it doesn't check to see if the interface is actually up before trying to modify the IP so that's probably the reason why you need the big sleep, but I'm sure you figured that out already.
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @tom Yeah. I think I figured it out
                            My uname has "m0054". It uses eth0 as interface instead of usb0. i dont see code for setting the ip for eth0. What is weird is that I also see usb0 come up as an interface. But I am going to add some code here to hopefully fix that. Will make a branch or something if it is useful for someone else
                              @wilkinsaf Do you have any other type of network connection going? WiFi? Ethernet?
                              I can try to copy your setup, so you've got a VOXL2 w/ Microhard add-on? anything else important connected? mipi cameras and such wouldn't affect this
                                #30
                                @wilkinsaf Also a voxl-version would be helpful to see. To give you some background on why this part is a little confusing, on newer builds of Microhard add-ons we had to change out a chip due to supply shortages and so the newer Microhard add-ons will be handled as "usb0" instead of "eth0".
                                  @wilkinsaf Oh also, while I'm asking you things, the output of the following would be helpful as well:
                                  dmesg | grep eth0
                                  dmesg | grep usb0
                                    wilkinsafW Offline
                                    wilkinsafW Offline
                                    wilkinsaf
                                    No other wifi or ethernet. I am connected with adb.
                                    VOXL2 with microhard
                                    cameras: stereo, tracking, hires (although my config only has the tracking and hires turned on rn)
                                    voxl-version:
                                    dmesg | grep eth0
                                    [    3.291467] smsc75xx 1-1.1:1.0 eth0: register 'smsc75xx' at usb-xhci-hcd.0.auto-1.1, smsc75xx USB 2.0 Gigabit Ethernet, 42:cd:53:3c:37:18
                                    [    5.516283] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                                    [    9.465432] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                                    [    9.475251] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   14.332677] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   14.345964] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   21.188500] smsc75xx 1-1.1:1.0 eth0: link down
                                    [   22.663119] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   22.682574] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   23.155729] smsc75xx 1-1.1:1.0 eth0: link down
                                    [   23.168624] smsc75xx 1-1.1:1.0 eth0: link down
                                    [   25.801191] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   34.154417] smsc75xx 1-1.1:1.0 eth0: link down
                                    [   35.708201] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    [   35.723892] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                                    dmesg | grep usb0
                                        2.202994] register_client_adhoc:Client handle 64 usb0
                                    [    5.322266] f_cdev_alloc: port_name:at_usb0 (ffffffdd12c44c00) portno:(0)
                                    [   37.386234] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.0.auto-1.2, RNDIS device, 46:b5:b5:15:45:b0
                                      @wilkinsaf Hmm okay very interesting, I'll replicate your setup and see what I can find
                                      wilkinsafW 2 Replies Last reply
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        @tom Thanks for your help Tom. I am doing the same on my end. Will post if I find anything interesting
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          I threw some code in there to do the operation, but it's pretty much the same as voxl-static-ip
                                          I am just going to go with this patch for right now to continue dev work.
