Sentinel VOXL2 Microhard not running
Here is the output. -
Here you go! -
@rohitpillai Okay that looks to be the latest, let me mimic your setup and see if I can figure out the issue. Thank you for being patient!
In the meantime, a couple other things to check:
What does your
/etc/network/interfacesfile look like?And does anything change if you do the following:
ifconfig usb0 downandifconfig usb0 up -
Here is the output for the network-interfaces file
Output for
ifconfig usb0 down
Output for
ifconfig usb0 upgives the same output asifconfigfrom previous message. -
Here is the output -
If I try to SSH using this IP address, it takes me to this and not VOXL2 -
On the other drones it is usually
eth0for the Microhard connection. Why is it defaulting to usb0? -
Okay typing in bash takes me to VOXL2. However, it is not setting the static IP address that I want it to set, which is 192.168.168.60
@rohitpillai I'm still playing around to figure out exactly what is going wrong but here are a couple answers:
That SSH session is the VOXL2, SSH just doesn't put you in the
bashshell by default, if you runbashit should give you the expectedvoxlterminal you're used to.The reason why it is showing up as
usb0and noteth0is because the Microhard add-on board you're using is a newer flavor than the others "M0048-2" vs "M0048-1" (the silk screen may not reflect that correctly). This newer flavor removes the LAN7500 chip and uses a slightly different driver to enable comms between the chips.This functionality is new to
voxl-modemas well which is why you're running into this bug, you're one of the first people to actually have one of these new boards in hand. -
Oh cool! Is there anything I can do to help from my side to figure this out?
@rohitpillai I will let you know if I need anything from you. I'm screwing around with the
voxl-modemsource code right now to try to figure out how to fix the issue. I think I've already found a couple things that could resolve it.I'll update once I get it going, I may generate a new
voxl-modemdeb package for you to try out -
Sounds good!
@rohitpillai I believe I have fixed the issue.
voxl-modemwas jumping ahead and assuming that the modem had enumerated before it had which would cause some of the commands to never be run.I have generated a new dev package for you to try out, the download link is:
You can take a look at the source code changes here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/commit/0cc330f8fcd6cafc97b80412dfe9994b8389e90b
In order to try this package out, do the following:
- download the
voxl-modem_0.15.2-202206291955_arm64.debpackage using the above link - push the package to your VOXL2 in the directory you'd like (I'll use /data) using:
adb push voxl-modem_0.15.2-202206291955_arm64.deb /data- Force remove the
voxl-modempackage on board:
adb shell dpkg --purge --force-all voxl-modem- Install the new dev package:
cd /data dpkg -i voxl-modem_0.15.2-202206291955_arm64.deb- Re-run
voxl-configure-modemand choose the IP to your liking
Verify that the network interface comes up and the IP is what you expect with
ifconfigTry a couple reboots to confirm that the expected behavior is consistent.
Let me know if you need any clarity on the above and let me know the outcome of your tests.
The
usb0network interface won't come up immediately after reboot (may take 10-15 seconds) for it to enumerate - download the
After a couple of reboots I am getting the same behaviour. It works as it should now! Thanks!
@rohitpillai Woot! Thank you for all of your help! I will go ahead and merge this into master so that it will make it into the next release.
@tom Hey Tom,
I am noticing this issue of microhard not having a static ip on my system as well.
It appears I am on a later version than the one in the post. Is the voxl-static-ip service now the preferred way to have a static ip?
@tom Hey Tom,
@wilkinsaf Code is still there
@wilkinsaf Interesting, give
voxl-static-ipa try and see if it helps. I have yet to integrate that directly into voxl-modem. We have a systemd service setup for it, so I would go ahead and modify/usr/bin/voxl-static-ipand then enable it's servicesystemctl enable voxl-static-ip -
