  3. Sentinel VOXL2 Microhard not running
38 Posts 3 Posters 9.5k Views 1 Watching
    @rohitpillai As a test, can you do the following?:
    • disable the voxl-modem service with systemctl disable voxl-modem
    • reboot your drone
    • adb back on
    • run voxl-modem-start.sh manually
    • post the output and resulting ifconfig here
    • R Offline
      R Offline
      rohitpillai
      Where is the voxl-modem-start.sh file located?
        @rohitpillai It's in /usr/bin so you should be able to run it from wherever
        • R Offline
          R Offline
          rohitpillai
          Here is the output.
            @rohitpillai Let's see what package versions you have installed, can you run voxl-version?
            • R Offline
              R Offline
              rohitpillai
              Here you go!
                @rohitpillai Okay that looks to be the latest, let me mimic your setup and see if I can figure out the issue. Thank you for being patient!
                In the meantime, a couple other things to check:
                What does your /etc/network/interfaces file look like?
                And does anything change if you do the following:
                ifconfig usb0 down and ifconfig usb0 up
                • R Offline
                  R Offline
                  rohitpillai
                  Here is the output for the network-interfaces file
                  Output for ifconfig usb0 down
                  Output for ifconfig usb0 up gives the same output as ifconfig from previous message.
                    wrote on last edited by tom
                    #12
                    @rohitpillai Try ifconfig usb0 up not eth0 also try adding a sudo
                    • R Offline
                      R Offline
                      rohitpillai
                      Here is the output -
                      If I try to SSH using this IP address, it takes me to this and not VOXL2 -
                      On the other drones it is usually eth0 for the Microhard connection. Why is it defaulting to usb0?
                      • R Offline
                        R Offline
                        rohitpillai
                        Okay typing in bash takes me to VOXL2. However, it is not setting the static IP address that I want it to set, which is 192.168.168.60
                          @rohitpillai I'm still playing around to figure out exactly what is going wrong but here are a couple answers:
                          That SSH session is the VOXL2, SSH just doesn't put you in the bash shell by default, if you run bash it should give you the expected voxl terminal you're used to.
                          The reason why it is showing up as usb0 and not eth0 is because the Microhard add-on board you're using is a newer flavor than the others "M0048-2" vs "M0048-1" (the silk screen may not reflect that correctly). This newer flavor removes the LAN7500 chip and uses a slightly different driver to enable comms between the chips.
                          This functionality is new to voxl-modem as well which is why you're running into this bug, you're one of the first people to actually have one of these new boards in hand.
                          • R Offline
                            R Offline
                            rohitpillai
                            Oh cool! Is there anything I can do to help from my side to figure this out?
                              #17
                              @rohitpillai I will let you know if I need anything from you. I'm screwing around with the voxl-modem source code right now to try to figure out how to fix the issue. I think I've already found a couple things that could resolve it.
                              I'll update once I get it going, I may generate a new voxl-modem deb package for you to try out
                              • R Offline
                                R Offline
                                rohitpillai
                                Sounds good!
                                  @rohitpillai I believe I have fixed the issue. voxl-modem was jumping ahead and assuming that the modem had enumerated before it had which would cause some of the commands to never be run.
                                  I have generated a new dev package for you to try out, the download link is:
                                  404 Not Found
                                  favicon
                                  (voxl-packages.modalai.com)
                                  You can take a look at the source code changes here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-modem/-/commit/0cc330f8fcd6cafc97b80412dfe9994b8389e90b
                                  In order to try this package out, do the following:
                                  • download the voxl-modem_0.15.2-202206291955_arm64.deb package using the above link
                                  • push the package to your VOXL2 in the directory you'd like (I'll use /data) using:
                                  adb push voxl-modem_0.15.2-202206291955_arm64.deb /data
                                  • Force remove the voxl-modem package on board:
                                  adb shell
                                  dpkg --purge --force-all voxl-modem
                                  • Install the new dev package:
                                  cd /data
                                  dpkg -i voxl-modem_0.15.2-202206291955_arm64.deb
                                  • Re-run voxl-configure-modem and choose the IP to your liking
                                  Verify that the network interface comes up and the IP is what you expect with ifconfig
                                  Try a couple reboots to confirm that the expected behavior is consistent.
                                  Let me know if you need any clarity on the above and let me know the outcome of your tests.
                                  The usb0 network interface won't come up immediately after reboot (may take 10-15 seconds) for it to enumerate
                                  • R Offline
                                    R Offline
                                    rohitpillai
                                    After a couple of reboots I am getting the same behaviour. It works as it should now! Thanks!
                                      @rohitpillai Woot! Thank you for all of your help! I will go ahead and merge this into master so that it will make it into the next release.
                                      wilkinsafW 1 Reply Last reply
                                        wilkinsafW Offline
                                        wilkinsafW Offline
                                        wilkinsaf
                                        @tom Hey Tom,
                                        I am noticing this issue of microhard not having a static ip on my system as well.
                                        It appears I am on a later version than the one in the post. Is the voxl-static-ip service now the preferred way to have a static ip?
                                        • wilkinsafW wilkinsaf
                                          @tom Hey Tom,
                                          wilkinsafW Offline
                                          wilkinsafW Offline
                                          wilkinsaf
                                          @wilkinsaf Code is still there
