  3. Sentinel VOXL2 Microhard not running
38 Posts 3 Posters 10.2k Views 1 Watching
    @wilkinsaf Interesting, give voxl-static-ip a try and see if it helps. I have yet to integrate that directly into voxl-modem. We have a systemd service setup for it, so I would go ahead and modify /usr/bin/voxl-static-ip and then enable it's service systemctl enable voxl-static-ip
    wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    @tom I did, but i had to add in a huge sleeper and have it After=voxl-modem.service
    since the voxl-modem is a python script (thank you for that) I am just doing some caveman debugging. will post progress
      @wilkinsaf voxl-static-ip is pretty "dumb" as it doesn't check to see if the interface is actually up before trying to modify the IP so that's probably the reason why you need the big sleep, but I'm sure you figured that out already.
      wilkinsafW 1 Reply Last reply
        wilkinsafW Offline
        wilkinsafW Offline
        wilkinsaf
        @tom Yeah. I think I figured it out
        My uname has "m0054". It uses eth0 as interface instead of usb0. i dont see code for setting the ip for eth0. What is weird is that I also see usb0 come up as an interface. But I am going to add some code here to hopefully fix that. Will make a branch or something if it is useful for someone else
          @wilkinsaf Do you have any other type of network connection going? WiFi? Ethernet?
          I can try to copy your setup, so you've got a VOXL2 w/ Microhard add-on? anything else important connected? mipi cameras and such wouldn't affect this
            wrote on last edited by tom
            #30
            @wilkinsaf Also a voxl-version would be helpful to see. To give you some background on why this part is a little confusing, on newer builds of Microhard add-ons we had to change out a chip due to supply shortages and so the newer Microhard add-ons will be handled as "usb0" instead of "eth0".
              @wilkinsaf Oh also, while I'm asking you things, the output of the following would be helpful as well:
              dmesg | grep eth0
              dmesg | grep usb0
                wilkinsafW Offline
                wilkinsafW Offline
                wilkinsaf
                No other wifi or ethernet. I am connected with adb.
                VOXL2 with microhard
                cameras: stereo, tracking, hires (although my config only has the tracking and hires turned on rn)
                voxl-version:
                dmesg | grep eth0
                [    3.291467] smsc75xx 1-1.1:1.0 eth0: register 'smsc75xx' at usb-xhci-hcd.0.auto-1.1, smsc75xx USB 2.0 Gigabit Ethernet, 42:cd:53:3c:37:18
                [    5.516283] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
                [    9.465432] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                [    9.475251] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   14.332677] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   14.345964] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   21.188500] smsc75xx 1-1.1:1.0 eth0: link down
                [   22.663119] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   22.682574] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   23.155729] smsc75xx 1-1.1:1.0 eth0: link down
                [   23.168624] smsc75xx 1-1.1:1.0 eth0: link down
                [   25.801191] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   34.154417] smsc75xx 1-1.1:1.0 eth0: link down
                [   35.708201] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                [   35.723892] smsc75xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE1
                dmesg | grep usb0
                    2.202994] register_client_adhoc:Client handle 64 usb0
                [    5.322266] f_cdev_alloc: port_name:at_usb0 (ffffffdd12c44c00) portno:(0)
                [   37.386234] rndis_host 1-1.2:1.0 usb0: register 'rndis_host' at usb-xhci-hcd.0.auto-1.2, RNDIS device, 46:b5:b5:15:45:b0
                  @wilkinsaf Hmm okay very interesting, I'll replicate your setup and see what I can find
                  wilkinsafW 2 Replies Last reply
                    wilkinsafW Offline
                    wilkinsafW Offline
                    wilkinsaf
                    @tom Thanks for your help Tom. I am doing the same on my end. Will post if I find anything interesting
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      I threw some code in there to do the operation, but it's pretty much the same as voxl-static-ip
                      I am just going to go with this patch for right now to continue dev work.
                        @wilkinsaf What does your /etc/network/interfaces file looks like
                          wilkinsafW Offline
                          wilkinsafW Offline
                          wilkinsaf
                          #37
                          @tom said in Sentinel VOXL2 Microhard not running:
                          I am wondering if they could be clashing
                          • wilkinsafW wilkinsaf
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            @wilkinsaf No, took out usb0 entry and it still didnt set the correct ip
