    Docker daemon fails to start on voxl
    Software Development
    11
    40
    13778
    • A
      Alex123
      RE: https://forum.modalai.com/topic/37/docker-daemon-fails-to-start-voxl
      I'm also facing the same issue.
      yocto:/# voxl-docker -i roskinetic-xenial:opencv
      Cannot connect to the Docker daemon. Is the docker daemon running on this host?
      yocto:/#
      yocto:/#
      yocto:/# docker images
      yocto:/#
      yocto:/#
      yocto:/# df -h
      Filesystem Size Used Avail Use% Mounted on
      /dev/root 2.8G 2.2G 581M 79% /
      devtmpfs 1.8G 0 1.8G 0% /dev
      tmpfs 1.9G 0 1.9G 0% /dev/shm
      tmpfs 1.9G 17M 1.9G 1% /run
      tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
      tmpfs 1.9G 4.0K 1.9G 1% /var/volatile
      /dev/mmcblk0p1 7.4G 204M 7.2G 3% /mnt/sdcard
      /dev/sda2 2.2M 80K 2.0M 4% /persist
      /dev/sde12 12M 4.1M 7.4M 36% /dsp
      /dev/sde11 95M 33M 63M 35% /firmware
      /dev/sda3 58M 40K 57M 1% /cache
      /dev/sda9 15G 13G 2.4G 85% /data
      yocto:/#
      As you can see, /data partition has all the data and docker images.
      What can be a solution for this?
      • modaltbM
        modaltb ModalAI Team
        What do you see after running voxl-configure-docker.sh ?
        Should be something like:
        yocto:/# voxl-configure-docker-support.sh
        Stopping original docker service
        Enabling our own services docker-start & docker-prepare
        starting docker-start.service
        loading hello-world docker image
        successfully loaded hello-world
        starting docker-prepare service
        done configuring voxl-docker-support
        José QuintanillaJ 1 Reply Last reply Reply Quote 0
        • A
          Alex123
          yocto:/#
          • A
            Alex123
            yocto:/# systemctl status docker
            ● docker.service - Docker Application Container Engine
            Loaded: loaded (/lib/systemd/system/docker.service; disabled; vendor preset: enabled)
            Active: failed (Result: exit-code) since Mon 2021-01-11 06:31:53 UTC; 1min 53s ago
            Docs: http://docs.docker.com
            Main PID: 4675 (code=exited, status=2)
            Jan 11 06:31:53 apq8096 systemd[1]: Started Docker Application Container Engine.
            Jan 11 06:31:53 apq8096 docker[4675]: flag provided but not defined: --raw-logs
            Jan 11 06:31:53 apq8096 docker[4675]: See '/usr/bin/docker daemon --help'.
            Jan 11 06:31:53 apq8096 systemd[1]: docker.service: Main process exited, co...NT
            Jan 11 06:31:53 apq8096 systemd[1]: docker.service: Unit entered failed state.
            Jan 11 06:31:53 apq8096 systemd[1]: docker.service: Failed with result 'exi...'.
            Jan 11 06:31:57 apq8096 systemd[1]: Stopped Docker Application Container Engine.
            Jan 11 06:33:06 apq8096 systemd[1]: Stopped Docker Application Container Engine.
            Hint: Some lines were ellipsized, use -l to show in full.
            • A
              Alex123
              • A
                Alex123
                As I'm working on this issue, I noticed the following.
                yocto:/# ifconfig
                lo Link encap:Local Loopback
                inet addr:127.0.0.1 Mask:255.0.0.0
                UP LOOPBACK RUNNING MTU:65536 Metric:1
                RX packets:32 errors:0 dropped:0 overruns:0 frame:0
                TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:0
                RX bytes:2224 (2.1 KiB) TX bytes:2224 (2.1 KiB)
                wlan0 Link encap:Ethernet HWaddr :::::
                inet addr:192.168..** Bcast:192.168..*** Mask:...
                inet6 addr: ::
                :::**/** Scope:Link
                UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
                RX packets:467 errors:0 dropped:0 overruns:0 frame:0
                TX packets:88 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:3000
                RX bytes:40293 (39.3 KiB) TX bytes:10317 (10.0 KiB)
                https://stackoverflow.com/questions/64028448/error-during-connect-get-http-2fvar2frun2fdocker-sock-v1-40-containers-jso
                It's not showing any IP address for docker0.
                How to configure the IP address that will listen to docker daemon on voxl-core board?
                • K
                  kiprock
                  Hey @Alex123 were you able to resolve this? I'm having the same issue.
                  • Chad SweetC
                    Chad Sweet ModalAI Team
                    Are you following the docs here?
                    The voxl-docker command is for developing in a Docker on a PC, it should not be run on VOXL.
                    The tutorial steps to run on target are:
                    yocto:/# docker run hello-world
                    If you have run the PC scripts on VOXL, not really sure what would happen
                    K 1 Reply Last reply Reply Quote 0
                    • K
                      kiprock @Chad Sweet
                      @Chad-Sweet Thanks for the fast response!
                      yocto:~# voxl-configure-docker-support.sh
                      yocto:~#  systemctl status docker
                         Active: inactive (dead)
                      May 13 15:46:33 apq8096 systemd[1]: Stopped Docker Application Container Engine.
                      yocto:~#
                      yocto:~#  systemctl start docker
                         Active: failed (Result: exit-code) since Thu 2021-05-13 15:48:03 UTC; 2s ago
                        Process: 3678 ExecStart=/usr/bin/docker daemon -H fd:// --raw-logs (code=exited, status=2)
                       Main PID: 3678 (code=exited, status=2)
                      May 13 15:48:03 apq8096 systemd[1]: Started Docker Application Container Engine.
                      May 13 15:48:03 apq8096 docker[3678]: flag provided but not defined: --raw-logs
                      May 13 15:48:03 apq8096 docker[3678]: See '/usr/bin/docker daemon --help'.
                      May 13 15:48:03 apq8096 systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
                      May 13 15:48:03 apq8096 systemd[1]: docker.service: Unit entered failed state.
                      May 13 15:48:03 apq8096 systemd[1]: docker.service: Failed with result 'exit-code'.
                      yocto:~# docker images
                      An error occurred trying to connect: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.21/images/json: read unix @->/var/run/docker.sock: read: connection reset by peer
                      • Chad SweetC
                        Not really sure what state your system is in. This github issue shows it could be related to disk space or needs a reboot. Did you install other Dockers on the image? They are very large and maybe all of the space is consumed
                        https://github.com/docker/for-linux/issues/435
                        • K
                          kiprock
                          Just looking at your script, I realized that modal has it's own docker services.. so perhaps this provides a little more info: I have created a few images from the kinetic image
                          yocto:~# systemctl disable docker.service
                          yocto:~# systemctl enable docker-start.service
                          yocto:~# systemctl enable docker-prepare.service
                          yocto:~# systemctl status docker-prepare.service
                          ● docker-prepare.service
                             Loaded: loaded (/etc/systemd/system/docker-prepare.service; enabled; vendor preset: enabled)
                             Active: failed (Result: exit-code) since Thu 1970-01-01 00:00:24 UTC; 51 years 4 months ago
                           Main PID: 2352 (code=exited, status=1/FAILURE)
                          Jan 01 00:00:20 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
                          Jan 01 00:00:21 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
                          Jan 01 00:00:22 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
                          Jan 01 00:00:23 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
                          Jan 01 00:00:24 apq8096 docker-prepare.sh[2352]: /usr/bin/docker-prepare.sh: line 17: /sys/fs/cgroup/cpuset/syst...ctory
                          Jan 01 00:00:24 apq8096 docker-prepare.sh[2352]: failed to see cpuset appear after 15 seconds
                          Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Main process exited, code=exited, status=1/FAILURE
                          Jan 01 00:00:24 apq8096 systemd[1]: Failed to start docker-prepare.service.
                          Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Unit entered failed state.
                          Jan 01 00:00:24 apq8096 systemd[1]: docker-prepare.service: Failed with result 'exit-code'.
                          yocto:~#
                          yocto:~#
                          yocto:~# systemctl status docker-start.service
                          ● docker-start.service
                             Loaded: loaded (/etc/systemd/system/docker-start.service; enabled; vendor preset: enabled)
                             Active: failed (Result: exit-code) since Thu 2021-05-13 15:57:11 UTC; 3min 11s ago
                           Main PID: 3873 (code=exited, status=1/FAILURE)
                          May 13 15:57:11 apq8096 systemd[1]: Started docker-start.service.
                          May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.453820000Z" level=info msg="API listen on /var/....sock"
                          May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.477567000Z" level=info msg="[graphdriver] using...lay\""
                          May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.527540000Z" level=info msg="Firewalld running: false"
                          May 13 15:57:11 apq8096 docker[3873]: time="2021-05-13T15:57:11.595538000Z" level=fatal msg="Error starting dae...oints"
                          May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Main process exited, code=exited, status=1/FAILURE
                          May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Unit entered failed state.
                          May 13 15:57:11 apq8096 systemd[1]: docker-start.service: Failed with result 'exit-code'.
                          yocto:~#
                          yocto:~# df
                          Filesystem     1K-blocks    Used Available Use% Mounted on
                          /dev/root        2837860 1890496    930980  68% /
                          devtmpfs         1861956       0   1861956   0% /dev
                          tmpfs            1930660       0   1930660   0% /dev/shm
                          tmpfs            1930660   17136   1913524   1% /run
                          tmpfs            1930660       0   1930660   0% /sys/fs/cgroup
                          tmpfs            1930660       4   1930656   1% /var/volatile
                          /dev/sda2           2168      80      1964   4% /persist
                          /dev/sde12         12016    4184      7508  36% /dsp
                          /dev/sda3          58888      40     57568   1% /cache
                          /dev/sde11         97232   33616     63616  35% /firmware
                          /dev/sda9       15248568 7060916   8171268  47% /data
                          tmpfs             386132       0    386132   0% /run/user/0
                          • K
                            kiprock
                            I had a battery go pretty low and the system crashed while running mavros in docker last night, after reboot, docker deamon is not responding and I cannot see any images.
                              Eric Katzfey ModalAI Team
                              @kiprock I would reflash the system, setup your IP connection, configure Docker and just verify that it works as expected.
                              • K
                                kiprock
                                just looking at the logs, the docker deamon fails here:
                                level=fatal msg="Error starting daemon: Error initializing network controller: could not delete the default bridge network: network bridge has active endpoints"
                                Most forums suggest removing the docker network folder: rm -r /var/lib/docker/network
                                I did this but still having issues. Just curious if the modalAI setup stores docker files somewhere else?
                                  @kiprock Everything is stored on /data. But again, I would reflash and start over just to verify Docker operation.
                                  • K
                                    kiprock
                                    rm /data/network/files/local-kv.db
                                    did the trick. Thanks for providing that missing piece of data!
                                    LucasWL 1 Reply Last reply Reply Quote 2
                                    • S
                                      shlee853 @kiprock
                                      @kiprock Hi I have a exactly same issue.
                                      I flashed image and reset factory configuration on my VOXL, but, It has still issue.
                                      Did you resolve this problem?
                                      • K
                                        kiprock
                                        @Eric-Katzfey if you cannot start docker images, you can try the command above to clear them. Good luck.
                                        Eric KatzfeyE S 2 Replies Last reply Reply Quote 0
                                          Eric Katzfey ModalAI Team @kiprock
                                          Thanks, but I think you meant to ping @shlee853
                                          • S
                                            shlee853 @kiprock
                                            @kiprock thank you for your reply
                                            I’ll try it
