  3. FLIR LEPTON 3.5 Thermal camera with VOXL 2
39 Posts 5 Posters 12.1k Views 4 Watching
  • VinnyV Vinny
    Hi @Jetson-Nano
    Happy to continue helping.
    Regarding your updated design first:
    "I2C Bus Configuration: Regarding the I2C bus, should the I2C lines be connected in parallel to both the Lepton Module and the I2C GPIO expander?"
    -- Yes.
    "Lepton Reset/Power Down Pins: Concerning the Lepton Module's RESET_N and POWER_DOWN_N pins, should the existing resistor-capacitor (RC) network connected to the RESET_N pin be retained, or can it be omitted?"
    -- We do not have any RC delay on the reset line since it is all GPIO controlled.
    "I2C GPIO Expander INT Pin: For the I2C GPIO expander, is it permissible to leave the INT (Interrupt) pin unconnected, or does it require termination?"
    -- It is an output and we do not use it, so N.C. is fine
    I2C GPIO Expander Software Configuration: From a software perspective, is the I2C GPIO expander a plug-and-play component, or does it require specific configuration?
    -- It is supported at that HW address by default with voxl-lepton-server (I think that it what is called, Alex can correct me if I'm mistaken)
    However, your updated SCH has a couple errors:
    • Your LDO input and output caps are not correctly done. They are in series, not shunts to GND as required:0f7551cf-b798-4665-9673-a4df6182c21b-image.png
    • The Pull-down R on the GPIO expander is not correct. The ADDR pin will always be HIGH due to the direct connection to 2.8V, but our default is LOW (see the snippet from above): f6ee80a1-e5fa-4635-b3dd-93c5ca85e501-image.png
    • Also, the GPIO expander is meant to drive the RESET input of the Lepton, not the PWR_DWN input: eb4012fd-2528-4879-a1f6-d235568faa6e-image.png
    Now, as to your existing board not powering on, I have a clue for you...
    Our very first lepton board we failed to notice the pin 1 hole in the Molex socket, and that is important since it sets a keying for the Lepton module. If the module is inserted incorrectly (90 or 180 off) it will clearly not power up. Pay close attention to the hole in the socket for pin 1 and two vs one slots in the socket which set the orientation.
    Keep us posted and hope this helped.
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    @Vinny @Alex-Kushleyev
    Thank you for your valuable feedback on the previous version of the schematic. Based on your recommendations, I have revised the design accordingly.
    Please find the updated schematic attached below for your review
    In addition to the design changes, I have also revisited the hardware setup to verify the power delivery, the Lepton module is still not powering up—there is no shutter sound or I²C response. At this point, I have exhausted the immediate troubleshooting steps and would greatly appreciate your guidance on further debugging strategies.
    Could you please review the updated schematic and suggest any additional tests or possible points of failure that may have been overlooked?
    Thank you again for your support and expertise.
    VinnyV 1 Reply Last reply
    • Jetson NanoJ Jetson Nano
      Hi @Jetson-Nano
      Sch updates look correct. I'd still add a pull-up on the Lepton Reset to help control it during initial power-ON before the IO expander is configured.
      To help further debug your existing setup, I'd need more tangible info such as pictures with all your cables, etc. Do you have a DMM handy showing the voltages of 1.2V and 2.8V, and an O-scope for the 25MHz?
      Can you also post a pic of your board without components installed (so I can review the layout as best as possible)?
      It's hard to give much further guidance without actual hardware in my hands.
        @Alex-Kushleyev @Eric-Katzfey @modaltb
        guys any help with solving this issue.
        this the video feed I am getting.
        589968ed-ccc6-443d-a925-a6f7f0aa41f8-Screenshot from 2025-06-25 19-11-15.png
        voxl2:~$ voxl-lepton-server
        spi_bus:         0
        spi_speed:       16000000
        en_i2c:          1
        i2c_bus:         4
        shutter_mode:    manual
        flow_shutter_s:  20
        closePeriodInFramesInAir:         0
        openPeriodInFramesInAir:          1
        desiredFfcPeriodMsInAir:          360000
        desiredFfcTempDeltaCentiDegInAir: 600
        assign_cpu_num:  7
        en_timing_msg:   0
        en_rotate:       1
        existing instance of voxl-lepton-server found, attempting to stop it
        thread is now locked to the following cores: 7
        attempting to init the io expander
        Attempting intitialization for M0188 (TCA9543A)
        ERROR: in voxl_i2c_read_bytes, failed to write to bus
        io_expander_init, failed to read TCA9543APWR control register
        If you are not using an M0188 lepton board then this is expected
        Attempting intitialization for M0187 (PI4IO)
        io_expander_init, failed to read from io expander
        If you are not using an M0187 lepton board then this is expected
        attempting to open I2C CCI
        trying address 0x2a
        successfully opened I2C port
        Successfully connected to I2C CCI
        waiting for first frame from lepton to create MPA pipes
        creating MPA server pipes
        enabling MPA control interface
        client "voxl-portal78592109" connected to channel 0  with client id 0
        client "voxl-portal64940239" connected to channel 1  with client id 0
        J Offline
        J Offline
        jared
        wrote on last edited by jared
        #17
        @Jetson-Nano did you ever figure out a solution to this? I'm getting similar imagery. Is this an FFC issue? Running the same breakout board on a raspberry pi produces completely normal imagery.
        K 1 Reply Last reply
        • J jared
          K Offline
          K Offline
          KLindgren
          To close the loop here: we solved our issue of seeing lines by providing power to the lepton via one of the 3.3V pins on the voxl2 mini instead of relying on the power pin of J10 on the sparrow board.
          • K KLindgren
            Hi @KLindgren
            You raise a concern and something I will run by the team, but if you are powering the M0187 at 3.3V directly, you are violating the FLIR specs for the Lepton and our system design constraints.
            How are you connecting M0187 to M0188? Maybe your cable is introducing some extra losses giving you a lower than 2.8V supply?
            • VinnyV Vinny
              Hi @KLindgren
              K Offline
              K Offline
              KLindgren
              @Vinny apologies, I should have clarified we're using this PureThermal breakout board which regulates VIN from 3.3-5V
              VinnyV Jetson NanoJ 2 Replies Last reply
              • K KLindgren
                @KLindgren
                OK, M0188 will not work with anything other than our M0187.
                Thanks for clarifying.
                • VinnyV Vinny
                  @KLindgren
                  J Offline
                  J Offline
                  jared
                  @Vinny said in FLIR LEPTON 3.5 Thermal camera with VOXL 2:
                  M0187
                  Hi @Vinny - I'm guessing the M0187 is your FLIR breakout board? Do you sell these?
                  • J jared
                    M0187
                    Hi @jared
                    Presently they are integrated within certain drones...
                    https://docs.modalai.com/stinger-vision-datasheet/
                    I can poke the team to see if we can get it listed separately in the near future.
                    • K KLindgren
                      Jetson Nano
                      Veteran
                      #24
                      @KLindgren I am also using the same board but my video stream is with high disturbances, i have posted a image above in the chat. could you please share the image from your camera so that i could figure out what is wrong with my setup. Also the details of your setup, it would be of great help.
                        K Offline
                        K Offline
                        KLindgren
                        @Jetson-Nano our images looked the same as yours when providing power to the PureThermal from the sparrow board (m0188) but using a 3.3V from the voxl2 mini fixed the issue and gives us this imagery.
                        We are using power from the voxl2 mini's J19 and currently working on running 2 leptons with an RGB using the sparrow board.
                        • K KLindgren
                          Jetson Nano
                          Veteran
                          @KLindgren thank you for reverting back. From which port are you taking the 3.3 V also how did you complete the circuit, the image you provide is confusing with respect to the connections, it would be great if you would provide further details.
                          • VinnyV Vinny
                            Hi @jared
                            J Offline
                            J Offline
                            jared
                            Thanks @Vinny
                              K Offline
                              K Offline
                              KLindgren
                              wrote on last edited by KLindgren
                              #28
                              @Jetson-Nano Our 2 Leptons are connected as described in this image - though we're using PureThermal boards instead of M0187s for the Leptons. The 3.3V VIN is provided from the VOXL's J19 port via this cable and a "Y" split jumper we've soldered together.
                              • VinnyV Vinny
                                Hi @Jetson-Nano
                                Jetson Nano
                                Veteran
                                Hi @Vinny, @Alex-Kushleyev,
                                Thank you once again for your valuable feedback on the schematics, and apologies for the delayed response.
                                I’ve now completed the PCB layout based on the updated schematics and newly selected components, as per your suggestions. I would greatly appreciate it if you could take a moment to review the layout and share your feedback—particularly on whether it meets the required configuration or if any modifications are recommended.
                                The following have been included in the shared Drive link:
                                Screenshots of all four layers
                                3D views of both the top and bottom sides of the board
                                🔗 Drive link: https://drive.google.com/file/d/1czCx-N8ws3CelpKTV1VRBTzFZLcd-odx/view?usp=drive_link
                                Looking forward to your insights.
                                Thank you again for your continued support and guidance.
                                VinnyV 2 Replies Last reply
                                  Hi @Jetson-Nano
                                  I've been on vacation and just catching up. It will be a few days before I can get to this.
                                  Thanks for your patience.
                                    Hi @Jetson-Nano
                                    I do not have access to the link you have above.
                                    Please reach out to us using the contact form https://www.modalai.com/pages/contact-us and we can get a more detailed review scheduled using your native cad tools which is more effective for us.
                                    Just mention in the form you wish to reach Vinny and then in the response from our team, you can reply with your data and they will forward it to me.
                                    • VinnyV Vinny
                                      Hi @Jetson-Nano
                                      Jetson Nano
                                      Veteran
                                      @Vinny
                                      Thank you for the update — I hope you had a great vacation!
                                      As you mentioned, I’ve submitted an inquiry through your contact form. Once I receive a response from your team, I’ll follow up with the necessary details and additional data as needed.
                                      Thank you for your continued support.
                                        @Vinny
                                        Hi @Jetson-Nano
                                        I received your data package and will review it this evening.
                                        • VinnyV Vinny
                                          Hi @Jetson-Nano
                                          Hi @Jetson-Nano I have reviewed your schematic again and your layout files.
                                          I cannot see any reason why your design will not work.
                                          The only suggestion I have is to increase your capacitors here to 1uF:
                                          But, otherwise, your layout is OK (some improvements can be made, but nothing is detrimental):
                                          • Pin 1 correct on connector, socket, LDO, other ICs
                                          • Vias are picking up planes correctly
                                          • Voids where expected
                                          • Generous copper trace thickness
                                          The one issue I think I might have found is your reference designators do not match the schematic between the layout. So, I'm wondering if you are installing parts from the BOM in incorrect locations...
                                          For example, the cap on the output of the LDO is "C6" in the layout, but "C7" in your schematic:
                                          And, your resistors are also not in sync. R1 and R2 in the layout are for the Ic2 expander, but in the SCH, it is for your FLIR module and not R5/R6 as in the SCH:
                                          and there are a few other examples. So, I just think perhaps your layout reference designators are not synced to your design.
                                          J1 should be J2, and R3/R4 on the layout does not exist on the SCH.
                                          So, maybe this is where your issue is. I'd recheck the annotation between SCH and Layout, and be sure you are installing all the correct parts in the correct places.
                                          Hope this helped!
                                          Keep us posted.
