  3. FLIR LEPTON 3.5 Thermal camera with VOXL 2
39 Posts 5 Posters 11.3k Views 4 Watching
  • J jared
    @Jetson-Nano did you ever figure out a solution to this? I'm getting similar imagery. Is this an FFC issue? Running the same breakout board on a raspberry pi produces completely normal imagery.
    K Offline
    K Offline
    KLindgren
    To close the loop here: we solved our issue of seeing lines by providing power to the lepton via one of the 3.3V pins on the voxl2 mini instead of relying on the power pin of J10 on the sparrow board.
    VinnyV 1 Reply Last reply
    • K KLindgren
      Hi @KLindgren
      You raise a concern and something I will run by the team, but if you are powering the M0187 at 3.3V directly, you are violating the FLIR specs for the Lepton and our system design constraints.
      How are you connecting M0187 to M0188? Maybe your cable is introducing some extra losses giving you a lower than 2.8V supply?
      K 1 Reply Last reply
      • VinnyV Vinny
        Hi @KLindgren
        K Offline
        K Offline
        KLindgren
        @Vinny apologies, I should have clarified we're using this PureThermal breakout board which regulates VIN from 3.3-5V
        VinnyV Jetson NanoJ 2 Replies Last reply
        • K KLindgren
          @KLindgren
          OK, M0188 will not work with anything other than our M0187.
          Thanks for clarifying.
          J 1 Reply Last reply
          • VinnyV Vinny
            @KLindgren
            J Offline
            J Offline
            jared
            @Vinny said in FLIR LEPTON 3.5 Thermal camera with VOXL 2:
            M0187
            Hi @Vinny - I'm guessing the M0187 is your FLIR breakout board? Do you sell these?
            • J jared
              M0187
              Hi @jared
              Presently they are integrated within certain drones...
              https://docs.modalai.com/stinger-vision-datasheet/
              I can poke the team to see if we can get it listed separately in the near future.
              • K KLindgren
                Jetson NanoJ Offline
                Jetson Nano
                Veteran
                #24
                @KLindgren I am also using the same board but my video stream is with high disturbances, i have posted a image above in the chat. could you please share the image from your camera so that i could figure out what is wrong with my setup. Also the details of your setup, it would be of great help.
                • Jetson NanoJ Jetson Nano
                  K Offline
                  K Offline
                  KLindgren
                  @Jetson-Nano our images looked the same as yours when providing power to the PureThermal from the sparrow board (m0188) but using a 3.3V from the voxl2 mini fixed the issue and gives us this imagery.
                  We are using power from the voxl2 mini's J19 and currently working on running 2 leptons with an RGB using the sparrow board.
                  • K KLindgren
                    Jetson Nano
                    Veteran
                    @KLindgren thank you for reverting back. From which port are you taking the 3.3 V also how did you complete the circuit, the image you provide is confusing with respect to the connections, it would be great if you would provide further details.
                    • VinnyV Vinny
                      Hi @jared
                      J Offline
                      J Offline
                      jared
                      Thanks @Vinny
                        K Offline
                        K Offline
                        KLindgren
                        wrote on last edited by KLindgren
                        #28
                        @Jetson-Nano Our 2 Leptons are connected as described in this image - though we're using PureThermal boards instead of M0187s for the Leptons. The 3.3V VIN is provided from the VOXL's J19 port via this cable and a "Y" split jumper we've soldered together.
                        • VinnyV Vinny
                          Hi @Jetson-Nano
                          Sch updates look correct. I'd still add a pull-up on the Lepton Reset to help control it during initial power-ON before the IO expander is configured.
                          To help further debug your existing setup, I'd need more tangible info such as pictures with all your cables, etc. Do you have a DMM handy showing the voltages of 1.2V and 2.8V, and an O-scope for the 25MHz?
                          Can you also post a pic of your board without components installed (so I can review the layout as best as possible)?
                          It's hard to give much further guidance without actual hardware in my hands.
                          Jetson Nano
                          Veteran
                          Hi @Vinny, @Alex-Kushleyev,
                          Thank you once again for your valuable feedback on the schematics, and apologies for the delayed response.
                          I’ve now completed the PCB layout based on the updated schematics and newly selected components, as per your suggestions. I would greatly appreciate it if you could take a moment to review the layout and share your feedback—particularly on whether it meets the required configuration or if any modifications are recommended.
                          The following have been included in the shared Drive link:
                          Screenshots of all four layers
                          3D views of both the top and bottom sides of the board
                          🔗 Drive link: https://drive.google.com/file/d/1czCx-N8ws3CelpKTV1VRBTzFZLcd-odx/view?usp=drive_link
                          Looking forward to your insights.
                          Thank you again for your continued support and guidance.
                          VinnyV 2 Replies Last reply
                            Hi @Jetson-Nano
                            I've been on vacation and just catching up. It will be a few days before I can get to this.
                            Thanks for your patience.
                              Hi @Jetson-Nano
                              I do not have access to the link you have above.
                              Please reach out to us using the contact form https://www.modalai.com/pages/contact-us and we can get a more detailed review scheduled using your native cad tools which is more effective for us.
                              Just mention in the form you wish to reach Vinny and then in the response from our team, you can reply with your data and they will forward it to me.
                              • VinnyV Vinny
                                Hi @Jetson-Nano
                                Jetson Nano
                                Veteran
                                @Vinny
                                Thank you for the update — I hope you had a great vacation!
                                As you mentioned, I’ve submitted an inquiry through your contact form. Once I receive a response from your team, I’ll follow up with the necessary details and additional data as needed.
                                Thank you for your continued support.
                                  @Vinny
                                  Hi @Jetson-Nano
                                  I received your data package and will review it this evening.
                                  • VinnyV Vinny
                                    Hi @Jetson-Nano
                                    Hi @Jetson-Nano I have reviewed your schematic again and your layout files.
                                    I cannot see any reason why your design will not work.
                                    The only suggestion I have is to increase your capacitors here to 1uF:
                                    But, otherwise, your layout is OK (some improvements can be made, but nothing is detrimental):
                                    • Pin 1 correct on connector, socket, LDO, other ICs
                                    • Vias are picking up planes correctly
                                    • Voids where expected
                                    • Generous copper trace thickness
                                    The one issue I think I might have found is your reference designators do not match the schematic between the layout. So, I'm wondering if you are installing parts from the BOM in incorrect locations...
                                    For example, the cap on the output of the LDO is "C6" in the layout, but "C7" in your schematic:
                                    And, your resistors are also not in sync. R1 and R2 in the layout are for the Ic2 expander, but in the SCH, it is for your FLIR module and not R5/R6 as in the SCH:
                                    and there are a few other examples. So, I just think perhaps your layout reference designators are not synced to your design.
                                    J1 should be J2, and R3/R4 on the layout does not exist on the SCH.
                                    So, maybe this is where your issue is. I'd recheck the annotation between SCH and Layout, and be sure you are installing all the correct parts in the correct places.
                                    Hope this helped!
                                    Keep us posted.
                                    • VinnyV Vinny
                                      Hope this helped!
                                      Keep us posted.
                                      Jetson Nano
                                      Veteran
                                      Hello @Vinny,
                                      Hi Vinny,
                                      Thank you again for your valuable feedback on the schematics and layout.
                                      Apologies for not sending the updated files — the issues you pointed out were caused by that omission. I have now incorporated your suggestions and attached the updated schematics for your reference. I will also update the capacitor values to 1 µF as discussed.
                                      Could you please review the attached schematics and let me know if any further changes are required?
                                      Thanks very much for your continued support.
                                        Hello @Vinny,
                                        Hi Vinny,
                                        HI @Jetson-Nano
                                        Your welcome. Apologies I cannot find anything blatantly wrong with your design at the document and layout level.
                                        If your PCB still does not work after all these reviews and positive affirmations, then you may very well have a fabrication issue with your PCB.
                                        The only way to verify that is to try your own net-by-net buzz-out using a DMM to ensure your netlist matches the expected schematic. If that all matches up, then you may be suffering from poor assembly/soldering. The socket for the lepton does require a reflow oven/line and cannot be hand soldered, unless you have an IR tray/heater and a way to deposit solder paste on the pads.
                                        Any further debugging I could offer would require physical samples of the hardware to validate everything.
                                        Hope that info helps!
                                        • VinnyV Vinny
                                          HI @Jetson-Nano
                                          Jetson Nano
                                          Veteran
                                          @Vinny
                                          Thank you so much for your feedback — it’s very valuable to us. I will definitely review and address the suggestions you have mentioned.
