  3. voxl-mapper/planner for a Seeker drone
25 Posts 2 Posters 7.0k Views 1 Watching
  • P Pooyan
    @tom I am just putting the versioning as well, in case there is anything you wanted to see:
    @Pooyan We can really only offer support with the latest SDK, you can read through the SDK 0.9 docs here if you'd like to see our old docs: https://docs.modalai.com/voxl-sdk-0_9/
    This is the voxl-mapper section based on SDK 0.9.5 https://docs.modalai.com/voxl-mapper-0_9/
    P 2 Replies Last reply
      P Offline
      P Offline
      Pooyan
      @tom Thank you so much for the reply and information. I understand that for sure.
        P Offline
        P Offline
        Pooyan
        @tom Now I have upgrade SDK to 1.1.2, and did everything again through this link:
        https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/tree/master?ref_type=heads
        The thing is that the voxl-mapper is Enabled but not running and when I am trying the voxl-mapper command, I get the following error:
        I would appreciate it if you could give me some hint on this.
        Thank you so much.
        P 1 Reply Last reply
        • P Pooyan
          Thank you so much.
          P Offline
          P Offline
          Pooyan
          @Pooyan there was an internet connection issue and after that I used "opkg update && opkg upgrade", and then "opkg install voxl-portal voxl-mapper " for installing mapper again and now this problem is solved.
            @Pooyan Okay you can't mix and match packages like that. voxl-camera-server from dev can't be used with SDK 0.9.5.
            You need to use SDK 1.1.2 and use the packages as they come, not pull in others, it won't work
            P Offline
            P Offline
            Pooyan
            wrote on last edited by Pooyan
            #14
            @tom Hello again,
            The SDK was updated to 1.2.0 and it was because of putting the configure-opkg on dev as it was said in the GitLab voxl-mapper link. I went through every steps in the following link again. Do you have any idea about what I can do?
            as you can see, when I run the "voxl-mapper", I get the following errors and it keeps repeating.
            Thank you so much for your help.
            • P Pooyan
              @tom Hello again,
              P Offline
              P Offline
              Pooyan
              @tom Again I changed the version to 1.1.2 and got the same issue about loading shared libraries: libvoxblox.so. So I want to explain more what I do in case you could help me better.
              I have included the screenshot as well.
              When I push the built mapper to voxl I get the following error as well. I wanted to show that to you as well:
              The codes I use to do that are as follow:
              git clone https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper.git
              ./install_build_deps.sh APQ8096 dev
              ./build.sh apq8096
              ./make_package.sh ipk
              ./deploy_to_voxl.sh
              I would appreciate it if you could give me any hints on this.
              • P Pooyan
                ./build.sh apq8096
                ./deploy_to_voxl.sh
                @Pooyan After a fresh flash using the release and ./install.sh if you adb on and run opkg install voxl-mapper and then run voxl-mapper what happens?
                  P Offline
                  P Offline
                  Pooyan
                  @tom I have just flashed it again and before anything else I did opkg install voxl-mapper and I got this:
                  I did it when the seeker is connected to the internet and the adb cable is connected, and I got this:
                  Still I didn't even install the FC2 through QGC or doing anything else.
                  • P Pooyan
                    @Pooyan Oh sorry, on voxl run opkg install /data/voxl-suite-offline-packages/voxl-mapper*.ipk
                      P Offline
                      P Offline
                      Pooyan
                      @tom thank you for the command. I get this now:
                      • P Pooyan
                        wrote on last edited by tom
                        #20
                        @Pooyan Okay you'll just have to install the dependencies in the same way. I just did this on my voxl1:
                        cd /data/voxl-suite-offline-packages/
                        opkg install voxl-ceres-solver_2\:1.14.0-10.ipk
                        opkg install voxl-nlopt_2.5.0-4.ipk
                        opkg install voxl-voxblox_1.1.5.ipk
                        opkg install voxl-mapper_0.2.0.ipk
                          P Offline
                          P Offline
                          Pooyan
                          @tom Thank you so much. Now it seems that I have it and when I run it I get the following errors:
                          Do I need to upload the FC2? as I didnt do it yet.
                          • P Pooyan
                            @Pooyan Cool you shouldn't have to change anything on the flight core for this to work, I'll see if I can get someone else from my team to take a look.
                              P Offline
                              P Offline
                              Pooyan
                              @tom Thank you so much. I didn't change anything and just put the commands you gave me. I am looking forward to hearing from you.
                                P Offline
                                P Offline
                                Pooyan
                                @tom So, if I just restart and then do "systemctl enable voxl-mapper", it will work. But if I run it on CMD with voxl-mapper, it will still show me the same error. If you have any comments I would appreciate it, otherwise it works in that way.
                                Thank you so much.
                                • P Pooyan
                                  Thank you so much.
                                  @Pooyan Interesting, systemd is ideal way for it to be running
