  3. voxl-mapper/planner for a Seeker drone
25 Posts 2 Posters 7.0k Views 1 Watching
  • P Pooyan
    @tom Again I changed the version to 1.1.2 and got the same issue about loading shared libraries: libvoxblox.so. So I want to explain more what I do in case you could help me better.
    I have included the screenshot as well.
    When I push the built mapper to voxl I get the following error as well. I wanted to show that to you as well:
    The codes I use to do that are as follow:
    git clone https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper.git
    ./install_build_deps.sh APQ8096 dev
    ./build.sh apq8096
    ./make_package.sh ipk
    ./deploy_to_voxl.sh
    I would appreciate it if you could give me any hints on this.
    @Pooyan After a fresh flash using the release and ./install.sh if you adb on and run opkg install voxl-mapper and then run voxl-mapper what happens?
    P 1 Reply Last reply
      P Offline
      P Offline
      Pooyan
      @tom I have just flashed it again and before anything else I did opkg install voxl-mapper and I got this:
      I did it when the seeker is connected to the internet and the adb cable is connected, and I got this:
      Still I didn't even install the FC2 through QGC or doing anything else.
      • P Pooyan
        @Pooyan Oh sorry, on voxl run opkg install /data/voxl-suite-offline-packages/voxl-mapper*.ipk
          P Offline
          P Offline
          Pooyan
          @tom thank you for the command. I get this now:
          • P Pooyan
            wrote on last edited by tom
            #20
            @Pooyan Okay you'll just have to install the dependencies in the same way. I just did this on my voxl1:
            cd /data/voxl-suite-offline-packages/
            opkg install voxl-ceres-solver_2\:1.14.0-10.ipk
            opkg install voxl-nlopt_2.5.0-4.ipk
            opkg install voxl-voxblox_1.1.5.ipk
            opkg install voxl-mapper_0.2.0.ipk
              P Offline
              P Offline
              Pooyan
              @tom Thank you so much. Now it seems that I have it and when I run it I get the following errors:
              Do I need to upload the FC2? as I didnt do it yet.
              • P Pooyan
                @Pooyan Cool you shouldn't have to change anything on the flight core for this to work, I'll see if I can get someone else from my team to take a look.
                P 2 Replies Last reply
                  P Offline
                  P Offline
                  Pooyan
                  @tom Thank you so much. I didn't change anything and just put the commands you gave me. I am looking forward to hearing from you.
                    P Offline
                    P Offline
                    Pooyan
                    @tom So, if I just restart and then do "systemctl enable voxl-mapper", it will work. But if I run it on CMD with voxl-mapper, it will still show me the same error. If you have any comments I would appreciate it, otherwise it works in that way.
                    Thank you so much.
                    • P Pooyan
                      Thank you so much.
                      @Pooyan Interesting, systemd is ideal way for it to be running
