  3. voxl-mapper/planner for a Seeker drone
25 Posts 2 Posters 7.0k Views 1 Watching
    @Pooyan Okay you can't mix and match packages like that. voxl-camera-server from dev can't be used with SDK 0.9.5.
    You need to use SDK 1.1.2 and use the packages as they come, not pull in others, it won't work
    P Offline
    P Offline
    Pooyan
    wrote on last edited by Pooyan
    #14
    @tom Hello again,
    The SDK was updated to 1.2.0 and it was because of putting the configure-opkg on dev as it was said in the GitLab voxl-mapper link. I went through every steps in the following link again. Do you have any idea about what I can do?
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper
    as you can see, when I run the "voxl-mapper", I get the following errors and it keeps repeating.
    Thank you so much for your help.
    P 1 Reply Last reply
    • P Pooyan
      @tom Hello again,
      P Offline
      P Offline
      Pooyan
      @tom Again I changed the version to 1.1.2 and got the same issue about loading shared libraries: libvoxblox.so. So I want to explain more what I do in case you could help me better.
      I have included the screenshot as well.
      When I push the built mapper to voxl I get the following error as well. I wanted to show that to you as well:
      The codes I use to do that are as follow:
      git clone https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper.git
      ./install_build_deps.sh APQ8096 dev
      ./build.sh apq8096
      ./make_package.sh ipk
      ./deploy_to_voxl.sh
      I would appreciate it if you could give me any hints on this.
      • P Pooyan
        ./build.sh apq8096
        ./deploy_to_voxl.sh
        @Pooyan After a fresh flash using the release and ./install.sh if you adb on and run opkg install voxl-mapper and then run voxl-mapper what happens?
          P Offline
          P Offline
          Pooyan
          @tom I have just flashed it again and before anything else I did opkg install voxl-mapper and I got this:
          I did it when the seeker is connected to the internet and the adb cable is connected, and I got this:
          Still I didn't even install the FC2 through QGC or doing anything else.
          • P Pooyan
            @Pooyan Oh sorry, on voxl run opkg install /data/voxl-suite-offline-packages/voxl-mapper*.ipk
              P Offline
              P Offline
              Pooyan
              @tom thank you for the command. I get this now:
              • P Pooyan
                wrote on last edited by tom
                #20
                @Pooyan Okay you'll just have to install the dependencies in the same way. I just did this on my voxl1:
                cd /data/voxl-suite-offline-packages/
                opkg install voxl-ceres-solver_2\:1.14.0-10.ipk
                opkg install voxl-nlopt_2.5.0-4.ipk
                opkg install voxl-voxblox_1.1.5.ipk
                opkg install voxl-mapper_0.2.0.ipk
                  P Offline
                  P Offline
                  Pooyan
                  @tom Thank you so much. Now it seems that I have it and when I run it I get the following errors:
                  Do I need to upload the FC2? as I didnt do it yet.
                  • P Pooyan
                    @Pooyan Cool you shouldn't have to change anything on the flight core for this to work, I'll see if I can get someone else from my team to take a look.
                    P 2 Replies Last reply
                      P Offline
                      P Offline
                      Pooyan
                      @tom Thank you so much. I didn't change anything and just put the commands you gave me. I am looking forward to hearing from you.
                        P Offline
                        P Offline
                        Pooyan
                        @tom So, if I just restart and then do "systemctl enable voxl-mapper", it will work. But if I run it on CMD with voxl-mapper, it will still show me the same error. If you have any comments I would appreciate it, otherwise it works in that way.
                        Thank you so much.
                        • P Pooyan
                          Thank you so much.
                          @Pooyan Interesting, systemd is ideal way for it to be running
