  2. VOXL SDK and Software
  3. m500 VOXL Flight sdk update to v1.1.x
voxl-sdk
26 Posts 4 Posters 11.4k Views 2 Watching
    @Moderator
    @Moderator said in m500 VOXL Flight sdk update to v1.1.x:
    your firmware should match what was used in the SDK, they are paired together
    What firmware matches the voxl-1 sdk 1.1.2 version
    Darshit DesaiD Offline
    Darshit Desai
    @Moderator I have got the cable for flight core update, I upgraded the sdk to 1.1.2 again but then I am following the instructions as shown in the below but nothing shows up in the firmware tab
    https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---mainline-builds
      wrote on last edited by tom
      @Darshit-Desai The .px4 file is in the SDK release zip:
      for FCv1: voxl_SDK_1.1.2/flight-core/modalai_fc-v1_1.14.0-2.0.63.px4
      Follow the instructions here (ModalAI Build) with the above .px4 file:
      https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---modalai-build
        Darshit Desai
        #9
        @tom Yes but in the firmware page nothing shows up in QGC
        @tom said in m500 VOXL Flight sdk update to v1.1.x:
          @Darshit-Desai Did you unplug power and re-connect power while keeping USB attached?
            Darshit Desai
            #11
            @tom I was able to finish the upgrade, but in QGC it shows something about actuators, when I open it opens the esc calibration related page, Do I need to calibrate esc again?
            Edit: I found this page (https://docs.modalai.com/modal-esc-px4-user-guide/) on ESCs and added the parameters accordingly, the only ones I don't know are the min and max RPM, I am using the voxl 1 m500 with holybro 2216-920kv motors. Also I don't think the motors rotate when I try to using the sliders
              #12
              @Darshit-Desai ~~Can you try loading the FCv1 m500 params from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV1.param~~s
                Darshit Desai
                @tom V1 or V2? Because when I flash firmware it detects v2
                  @Darshit-Desai Sorry yes v2 https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV2.params
                    @tom It's hard for me to follow which hardware you have, so whichever one you have v1 or v2
                      Darshit Desai
                      #16
                      @tom Yes I am also not sure what came with m500 I recently bought because the earlier ones had v1
                      Edit: The motor issue was resolved with this and I can spin the motors, I will have a flight with the propellers and confirm it
                        Darshit Desai
                        #17
                        @tom On the next reboot it's showing esc failure in the logs
                        [13:38:12.651] Info: Kill-switch engaged
                        [13:38:13.768] Info: Kill-switch disengaged
                        [13:39:33.963] Info: Armed by RC
                        [13:39:34.096] Info: logging: opening log file sess114/log100.ulg
                        [13:39:34.296] Critical: Failsafe activated, triggering disarm
                        ESC failure
                        [13:39:34.296] Info: Disarmed by failsafe
                        [13:39:36.780] Info: Armed by RC
                        [13:39:36.781] Info: logging: opening log file sess114/log101.ulg
                        [13:39:37.131] Critical: Failsafe activated, triggering disarm
                        [13:39:37.131] Info: Disarmed by failsafe
                        [13:39:39.424] Info: Armed by RC
                        [13:39:39.465] Info: logging: opening log file sess114/log102.ulg
                        [13:39:39.787] Critical: Failsafe activated, triggering disarm
                        [13:39:39.787] Info: Disarmed by failsafe
                        And the motors try to spin up for a few seconds when arming and then instantly stop
                        When I move this sliders now the motors rotate but when I try to arm the drone using RC it shows the ESC failure error
                        • Darshit DesaiD Darshit Desai referenced this topic on
                          ESC failure
                          @Darshit-Desai If you upload the px4 log someone on our team can analyze it
                            Darshit Desai
                            #19
                            @tom By px4 log you mean the one mentioned in the post earlier, How can I access the log file which is mentioned here in the QGC log?
                            @Darshit-Desai said in m500 VOXL Flight sdk update to v1.1.x:
                            ESC failure
                              ESC failure
                              @Darshit-Desai The logs can be downloaded through QGroundControl: https://docs.px4.io/v1.11/en/getting_started/flight_reporting.html#downloading-logs-from-the-flight-controller
                                Darshit Desai
                                @tom Here's the ulog file link,
                                https://drive.google.com/file/d/1vuy_Ut0h_rEZDWseDgeywE093CISo9RB/view?usp=sharing
                                C Darshit DesaiD 2 Replies Last reply
                                  C Offline
                                  C Offline
                                  coreyazion
                                  @Darshit-Desai Our m500 also showed something needed to be done with the acutator after updgrade to 1.14. But after loading the parameters (assuming you are using fcv2) and then reboot and it is okay.
                                  p.s. I vaguely rember having to do "loading parameters and rebooting" twice to get everything done. But I'm not very sure about this just I have this impression.
                                  • C coreyazion
                                    Darshit Desai
                                    @coreyazion @tom This didn't work for me, although the drone esc and the drone functionality overall does work on an older sdk and flight core params, so its the newer version that's causing bugs for me
                                      Darshit Desai
                                      @tom any updates on this?
                                        Darshit Desai
                                        @tom any update on this?
                                        ModeratorM 1 Reply Last reply
                                          @Darshit-Desai Can you try the v1.13 PX4 for the Flight Core? https://docs.modalai.com/flight-core-v2-firmware/
