  2. VOXL SDK and Software
  3. m500 VOXL Flight sdk update to v1.1.x
voxl-sdk
26 Posts 4 Posters 10.4k Views 2 Watching
    @tom It's hard for me to follow which hardware you have, so whichever one you have v1 or v2
    Darshit DesaiD Offline
    Darshit Desai
    #16
    @tom Yes I am also not sure what came with m500 I recently bought because the earlier ones had v1
    Edit: The motor issue was resolved with this and I can spin the motors, I will have a flight with the propellers and confirm it
      Darshit Desai
      #17
      @tom On the next reboot it's showing esc failure in the logs
      [13:38:12.651] Info: Kill-switch engaged
      [13:38:13.768] Info: Kill-switch disengaged
      [13:39:33.963] Info: Armed by RC
      [13:39:34.096] Info: logging: opening log file sess114/log100.ulg
      [13:39:34.296] Critical: Failsafe activated, triggering disarm
      ESC failure
      [13:39:34.296] Info: Disarmed by failsafe
      [13:39:36.780] Info: Armed by RC
      [13:39:36.781] Info: logging: opening log file sess114/log101.ulg
      [13:39:37.131] Critical: Failsafe activated, triggering disarm
      [13:39:37.131] Info: Disarmed by failsafe
      [13:39:39.424] Info: Armed by RC
      [13:39:39.465] Info: logging: opening log file sess114/log102.ulg
      [13:39:39.787] Critical: Failsafe activated, triggering disarm
      [13:39:39.787] Info: Disarmed by failsafe
      And the motors try to spin up for a few seconds when arming and then instantly stop
      When I move this sliders now the motors rotate but when I try to arm the drone using RC it shows the ESC failure error
      • Darshit DesaiD Darshit Desai referenced this topic on
        ESC failure
        @Darshit-Desai If you upload the px4 log someone on our team can analyze it
          Darshit Desai
          #19
          @tom By px4 log you mean the one mentioned in the post earlier, How can I access the log file which is mentioned here in the QGC log?
          @Darshit-Desai said in m500 VOXL Flight sdk update to v1.1.x:
          ESC failure
            ESC failure
            @Darshit-Desai The logs can be downloaded through QGroundControl: https://docs.px4.io/v1.11/en/getting_started/flight_reporting.html#downloading-logs-from-the-flight-controller
              Darshit Desai
              @tom Here's the ulog file link,
              https://drive.google.com/file/d/1vuy_Ut0h_rEZDWseDgeywE093CISo9RB/view?usp=sharing
              C Darshit DesaiD 2 Replies Last reply
                C Offline
                C Offline
                coreyazion
                @Darshit-Desai Our m500 also showed something needed to be done with the acutator after updgrade to 1.14. But after loading the parameters (assuming you are using fcv2) and then reboot and it is okay.
                p.s. I vaguely rember having to do "loading parameters and rebooting" twice to get everything done. But I'm not very sure about this just I have this impression.
                • C coreyazion
                  Darshit Desai
                  @coreyazion @tom This didn't work for me, although the drone esc and the drone functionality overall does work on an older sdk and flight core params, so its the newer version that's causing bugs for me
                    Darshit Desai
                    @tom any updates on this?
                      Darshit Desai
                      @tom any update on this?
                      ModeratorM 1 Reply Last reply
                        @Darshit-Desai Can you try the v1.13 PX4 for the Flight Core? https://docs.modalai.com/flight-core-v2-firmware/
