    m500 VOXL Flight sdk update to v1.1.x
    VOXL SDK
    4252
    • Darshit DesaiD
      Darshit Desai
      I just updated my m500 voxl flight sdk to v1.1.x. In the documentation it says to update the flight core separately. But the documentation redirects it to this webpage https://docs.modalai.com/flight-core-v2-firmware/ which only has instructions of upgrading flight core v2. I am a bit confused here what is the difference between flight core v2 and voxl flight and do I need to upgrade the flight core of voxl flight after the sdk upgrade?
      • ModeratorM
        Moderator ModalAI Team @Darshit Desai
        @Darshit-Desai You are correct, you should use Flight Core v1 instructions for the Flight Core portion of VOXL Flight.
        https://docs.modalai.com/flight-core-firmware/#px4-v114
        Darshit DesaiD 1 Reply Last reply Reply Quote 0
        • Darshit DesaiD
          Darshit Desai @Moderator
          @Moderator Is the update procedure the same as this one for v1.14 firmware?
          https://docs.modalai.com/update-flight-core-firmware/#update-procedure
          Also since I dont have the desired cable if I want to fallback to v0.9.5 I don't need to change anything in the firmware right?
          Also when I try to go back v0.9.5 sdk and configure my qvio it always shows this error.
          / # voxl-configure-qvio
          Starting Wizard
          Do you want to reset the config file to factory defaults?
          1) yes
          2) no
          #? 1
          wiping old config file
          loading config file
          Creating new config file: /etc/modalai/voxl-qvio-server.conf
          Do you want to enable the voxl-qvio-server service to allow
          visual inertial odometry?
          1) yes
          2) no
          #? 1
          Now we are going to do a preliminary configuration of /etc/modalai/voxl-qvio-server.conf
          Which config voxl-qvio-server use?
          imu0_tracking          for VOXL Flight all-in-one board, M500
          imu1_tracking          for VOXL1 and VOXL-CAM, Seeker V1
          imu_px4_tracking       for RB5 Flight 5G
          imu_apps_tracking      for VOXL2, Sentinel
          imu_apps_stereo_lower  for Starling V2 stereo version
          1) imu0_tracking	  3) imu_px4_tracking	    5) imu_apps_stereo_lower
          2) imu1_tracking	  4) imu_apps_tracking
          #? 1
          enabling  voxl-qvio-server systemd service
          starting  voxl-qvio-server systemd service
          Done configuring voxl-qvio-server
          / # voxl-inspect-qvio
          waiting for server
           dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state| error_codes |
             30.2 |    0.00    0.00    0.00|   0.0   -0.0    0.0|     0  |   -1% | FAIL | IMU_MISSING STALLED ^C
          received SIGINT Ctrl-C
          closing and exiting
          • ModeratorM
            @Darshit-Desai your firmware should match what was used in the SDK, they are paired together
            why would you go to SDK 0.9.5? It is really old and no longer supported
              @Moderator I don't have the usb-jst connector for the firmware update and I think 0.95 that was the original factory sdk version
              • Darshit DesaiD
                Darshit Desai @Darshit Desai
                @Moderator
                @Moderator said in m500 VOXL Flight sdk update to v1.1.x:
                What firmware matches the voxl-1 sdk 1.1.2 version
                  @Moderator I have got the cable for flight core update, I upgraded the sdk to 1.1.2 again but then I am following the instructions as shown in the below but nothing shows up in the firmware tab
                  https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---mainline-builds
                    tom admin @Darshit Desai
                    @Darshit-Desai The .px4 file is in the SDK release zip:
                    for FCv1: voxl_SDK_1.1.2/flight-core/modalai_fc-v1_1.14.0-2.0.63.px4
                    Follow the instructions here (ModalAI Build) with the above .px4 file:
                    https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---modalai-build
                    • Darshit DesaiD
                      Darshit Desai @tom
                      @tom Yes but in the firmware page nothing shows up in QGC
                      @tom said in m500 VOXL Flight sdk update to v1.1.x:
                        @Darshit-Desai Did you unplug power and re-connect power while keeping USB attached?
                        • Darshit DesaiD
                          Darshit Desai @tom
                          @tom I was able to finish the upgrade, but in QGC it shows something about actuators, when I open it opens the esc calibration related page, Do I need to calibrate esc again?
                          Edit: I found this page (https://docs.modalai.com/modal-esc-px4-user-guide/) on ESCs and added the parameters accordingly, the only ones I don't know are the min and max RPM, I am using the voxl 1 m500 with holybro 2216-920kv motors. Also I don't think the motors rotate when I try to using the sliders
                            @Darshit-Desai Can you try loading the FCv1 m500 params from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV1.params
                            • Darshit DesaiD
                              Darshit Desai @tom
                              @tom V1 or V2? Because when I flash firmware it detects v2
                                @Darshit-Desai Sorry yes v2 https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV2.params
                                  tom admin @tom
                                  @tom It's hard for me to follow which hardware you have, so whichever one you have v1 or v2
                                  • Darshit DesaiD
                                    Darshit Desai @tom
                                    @tom Yes I am also not sure what came with m500 I recently bought because the earlier ones had v1
                                    Edit: The motor issue was resolved with this and I can spin the motors, I will have a flight with the propellers and confirm it
                                      @tom On the next reboot it's showing esc failure in the logs
                                      [13:38:12.651] Info: Kill-switch engaged
                                      [13:38:13.768] Info: Kill-switch disengaged
                                      [13:39:33.963] Info: Armed by RC
                                      [13:39:34.096] Info: logging: opening log file sess114/log100.ulg
                                      [13:39:34.296] Critical: Failsafe activated, triggering disarm
                                      ESC failure
                                      [13:39:34.296] Info: Disarmed by failsafe
                                      [13:39:36.780] Info: Armed by RC
                                      [13:39:36.781] Info: logging: opening log file sess114/log101.ulg
                                      [13:39:37.131] Critical: Failsafe activated, triggering disarm
                                      [13:39:37.131] Info: Disarmed by failsafe
                                      [13:39:39.424] Info: Armed by RC
                                      [13:39:39.465] Info: logging: opening log file sess114/log102.ulg
                                      [13:39:39.787] Critical: Failsafe activated, triggering disarm
                                      [13:39:39.787] Info: Disarmed by failsafe
                                      And the motors try to spin up for a few seconds when arming and then instantly stop
                                      When I move this sliders now the motors rotate but when I try to arm the drone using RC it shows the ESC failure error
                                      • Darshit DesaiD Darshit Desai referenced this topic on
                                        @Darshit-Desai If you upload the px4 log someone on our team can analyze it
                                        • Darshit DesaiD
                                          Darshit Desai @tom
                                          @tom By px4 log you mean the one mentioned in the post earlier, How can I access the log file which is mentioned here in the QGC log?
                                          @Darshit-Desai said in m500 VOXL Flight sdk update to v1.1.x:
                                          ESC failure
                                            @Darshit-Desai The logs can be downloaded through QGroundControl: https://docs.px4.io/v1.11/en/getting_started/flight_reporting.html#downloading-logs-from-the-flight-controller
