  2. VOXL SDK and Software
  3. m500 VOXL Flight sdk update to v1.1.x
voxl-sdk
26 Posts 4 Posters 11.4k Views 2 Watching
    I just updated my m500 voxl flight sdk to v1.1.x. In the documentation it says to update the flight core separately. But the documentation redirects it to this webpage https://docs.modalai.com/flight-core-v2-firmware/ which only has instructions of upgrading flight core v2. I am a bit confused here what is the difference between flight core v2 and voxl flight and do I need to upgrade the flight core of voxl flight after the sdk upgrade?
    @Darshit-Desai You are correct, you should use Flight Core v1 instructions for the Flight Core portion of VOXL Flight.
    https://docs.modalai.com/flight-core-firmware/#px4-v114
    • ModeratorM Moderator
      Darshit DesaiD Offline
      Darshit Desai
      @Moderator Is the update procedure the same as this one for v1.14 firmware?
      https://docs.modalai.com/update-flight-core-firmware/#update-procedure
      Also since I dont have the desired cable if I want to fallback to v0.9.5 I don't need to change anything in the firmware right?
      Also when I try to go back v0.9.5 sdk and configure my qvio it always shows this error.
      / # voxl-configure-qvio
      Starting Wizard
      Do you want to reset the config file to factory defaults?
      1) yes
      2) no
      #? 1
      wiping old config file
      loading config file
      Creating new config file: /etc/modalai/voxl-qvio-server.conf
      Do you want to enable the voxl-qvio-server service to allow
      visual inertial odometry?
      1) yes
      2) no
      #? 1
      Now we are going to do a preliminary configuration of /etc/modalai/voxl-qvio-server.conf
      Which config voxl-qvio-server use?
      imu0_tracking          for VOXL Flight all-in-one board, M500
      imu1_tracking          for VOXL1 and VOXL-CAM, Seeker V1
      imu_px4_tracking       for RB5 Flight 5G
      imu_apps_tracking      for VOXL2, Sentinel
      imu_apps_stereo_lower  for Starling V2 stereo version
      1) imu0_tracking	  3) imu_px4_tracking	    5) imu_apps_stereo_lower
      2) imu1_tracking	  4) imu_apps_tracking
      #? 1
      enabling  voxl-qvio-server systemd service
      starting  voxl-qvio-server systemd service
      Done configuring voxl-qvio-server
      / # voxl-inspect-qvio
      waiting for server
       dt(ms) |    T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)|features|quality| state| error_codes |
         30.2 |    0.00    0.00    0.00|   0.0   -0.0    0.0|     0  |   -1% | FAIL | IMU_MISSING STALLED ^C
      received SIGINT Ctrl-C
      closing and exiting
      ModeratorM 1 Reply Last reply
        Starting Wizard
        1) yes
        2) no
        #? 1
        loading config file
        1) yes
        2) no
        #? 1
        #? 1
        waiting for server
        closing and exiting
        @Darshit-Desai your firmware should match what was used in the SDK, they are paired together
        why would you go to SDK 0.9.5? It is really old and no longer supported
          Darshit Desai
          @Moderator I don't have the usb-jst connector for the firmware update and I think 0.95 that was the original factory sdk version
            Darshit Desai
            @Moderator
            @Moderator said in m500 VOXL Flight sdk update to v1.1.x:
            What firmware matches the voxl-1 sdk 1.1.2 version
              @Moderator
              Darshit Desai
              @Moderator I have got the cable for flight core update, I upgraded the sdk to 1.1.2 again but then I am following the instructions as shown in the below but nothing shows up in the firmware tab
              https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---mainline-builds
                wrote on last edited by tom
                @Darshit-Desai The .px4 file is in the SDK release zip:
                for FCv1: voxl_SDK_1.1.2/flight-core/modalai_fc-v1_1.14.0-2.0.63.px4
                Follow the instructions here (ModalAI Build) with the above .px4 file:
                https://docs.modalai.com/update-flight-core-firmware/#update-using-qgroundcontrol---modalai-build
                  Darshit Desai
                  #9
                  @tom Yes but in the firmware page nothing shows up in QGC
                  @tom said in m500 VOXL Flight sdk update to v1.1.x:
                    @Darshit-Desai Did you unplug power and re-connect power while keeping USB attached?
                      Darshit Desai
                      #11
                      @tom I was able to finish the upgrade, but in QGC it shows something about actuators, when I open it opens the esc calibration related page, Do I need to calibrate esc again?
                      Edit: I found this page (https://docs.modalai.com/modal-esc-px4-user-guide/) on ESCs and added the parameters accordingly, the only ones I don't know are the min and max RPM, I am using the voxl 1 m500 with holybro 2216-920kv motors. Also I don't think the motors rotate when I try to using the sliders
                        #12
                        @Darshit-Desai ~~Can you try loading the FCv1 m500 params from here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV1.param~~s
                          Darshit Desai
                          @tom V1 or V2? Because when I flash firmware it detects v2
                            @Darshit-Desai Sorry yes v2 https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-px4-params/-/blob/master/params/v1.14/platforms/M500_FCV2.params
                              @tom It's hard for me to follow which hardware you have, so whichever one you have v1 or v2
                                Darshit Desai
                                #16
                                @tom Yes I am also not sure what came with m500 I recently bought because the earlier ones had v1
                                Edit: The motor issue was resolved with this and I can spin the motors, I will have a flight with the propellers and confirm it
                                  Darshit Desai
                                  #17
                                  @tom On the next reboot it's showing esc failure in the logs
                                  [13:38:12.651] Info: Kill-switch engaged
                                  [13:38:13.768] Info: Kill-switch disengaged
                                  [13:39:33.963] Info: Armed by RC
                                  [13:39:34.096] Info: logging: opening log file sess114/log100.ulg
                                  [13:39:34.296] Critical: Failsafe activated, triggering disarm
                                  ESC failure
                                  [13:39:34.296] Info: Disarmed by failsafe
                                  [13:39:36.780] Info: Armed by RC
                                  [13:39:36.781] Info: logging: opening log file sess114/log101.ulg
                                  [13:39:37.131] Critical: Failsafe activated, triggering disarm
                                  [13:39:37.131] Info: Disarmed by failsafe
                                  [13:39:39.424] Info: Armed by RC
                                  [13:39:39.465] Info: logging: opening log file sess114/log102.ulg
                                  [13:39:39.787] Critical: Failsafe activated, triggering disarm
                                  [13:39:39.787] Info: Disarmed by failsafe
                                  And the motors try to spin up for a few seconds when arming and then instantly stop
                                  When I move this sliders now the motors rotate but when I try to arm the drone using RC it shows the ESC failure error
                                  • Darshit DesaiD Darshit Desai referenced this topic on
                                    ESC failure
                                    @Darshit-Desai If you upload the px4 log someone on our team can analyze it
                                      Darshit Desai
                                      #19
                                      @tom By px4 log you mean the one mentioned in the post earlier, How can I access the log file which is mentioned here in the QGC log?
                                      @Darshit-Desai said in m500 VOXL Flight sdk update to v1.1.x:
                                      ESC failure
                                        ESC failure
                                        @Darshit-Desai The logs can be downloaded through QGroundControl: https://docs.px4.io/v1.11/en/getting_started/flight_reporting.html#downloading-logs-from-the-flight-controller
                                          Darshit Desai
                                          @tom Here's the ulog file link,
                                          https://drive.google.com/file/d/1vuy_Ut0h_rEZDWseDgeywE093CISo9RB/view?usp=sharing
                                          C Darshit DesaiD 2 Replies Last reply
