  3. VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2
31 Posts 3 Posters 7.9k Views 2 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hello @Eric-Katzfey @Alex-Kushleyev @tom
    I am using voxl2 , with flight core v2 and VOXL FPV Racing 4-in-1 ESC. I would like to know how to setup this pipeline. what are the parameters that requires to be changed and what are values.
    could anyone help me this approach
    The Flight controller is not recognising the ESC.
    • Jetson NanoJ Jetson Nano
      Eric KatzfeyE Online
      @Jetson-Nano Are you using PX4 on the flight core v2? If so, what version? What do you mean when you say that it is not recognizing the ESC?
        Jetson Nano
        Veteran
        @Eric-Katzfey i am using http://voxl-packages.modalai.com/dists/fc-v2/dev/modalai_fc-v2_1.14.0-2.0.95.px4 version and also tried with http://voxl-packages.modalai.com/dists/fc-v2/dev/modalai_fc-v2_1.14.0-2.0.90.px4.
        The ESC should start blinking blue LED to represent achieving data from FC. It is not happening.
          @Jetson-Nano How are the VOXL_ESC parameters set on your FCv2? There could be a UART baud rate mismatch between what FCv2 is using and what the ESC is using.
          Alex KushleyevA Jetson NanoJ 2 Replies Last reply
            @Jetson-Nano , if the voxl_esc driver is started by PX4 running on the Flight Core, it should print out debugging information to the UART console. The log below was taken from PX4 running on VOXL2 DSP, but the output should be the same when using Flight Core V2.
            Please also note that the Flight Core (V2), when powered up, starts immediately (as opposed to VOXL2 booting takes a few seconds), so FC V2 will try to detect the ESC before the ESC exits bootloader (which takes 1 second after power is applied) and will fail to detect the ESC. This was fixed in our FC V2 drone config, please check your voxl-esc driver behavior. Here is the commit that added the delay of 1.5 seconds before starting voxl esc driver on FC V2:
            • https://github.com/modalai/px4-firmware/pull/70/commits/55742d298bf9241a2af5aa2c7ba3a26788073356
            • https://github.com/modalai/px4-firmware/pull/70/commits/1c11e2e0ac3fcc19cb45ab59292b3cf5f4fdb348
            (voxl-esc driver log from VOXL2 DSP is below)
            INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
            INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
            INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
            INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
            INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 0
            INFO  [muorb] SLPI: VOXL_ESC: 	Board Type : 37: ModalAi 4-in-1 ESC (M0134-1)
            INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900480024
            INFO  [muorb] SLPI: VOXL_ESC: 	Firmware   : version   39, hash eb6fb500
            INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : version  183, hash b4fa2cf8
            INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1646us
            INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 1
            INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D004D
            INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 621us
            INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 2
            INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900500042
            INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : versiINFO  [qshell] Send cmd: 'voxl_esc start'
            INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1120us
            INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 3
            INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D0050
            INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 617us
            INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 1
            INFO  [muorb] SLPI: VOXL_ESC: All ESCs successfully detected
              Jetson Nano
              Veteran
              @Alex-Kushleyev Thank you for reverting back. I will verify this and get back.
              I changed the firmware version to the voxl-fpv-dev still the FC is not detecting the ESC.
              if i start esc through voxl_esc start , it is starting
              could please verify the parameters I mentioned.
              nsh> voxl_esc status
              INFO  [voxl_esc] Max update rate: 0 Hz
              INFO  [voxl_esc] Outputs on: no
              INFO  [voxl_esc] UART port: /dev/ttyS4
              INFO  [voxl_esc] UART open: no
              INFO  [voxl_esc]
              INFO  [voxl_esc] Params: VOXL_ESC_CONFIG: 1
              INFO  [voxl_esc] Params: VOXL_ESC_MODE: 0
              INFO  [voxl_esc] Params: VOXL_ESC_BAUD: 250000
              INFO  [voxl_esc] Params: VOXL_ESC_FUNC1: 101
              INFO  [voxl_esc] Params: VOXL_ESC_FUNC2: 104
              INFO  [voxl_esc] Params: VOXL_ESC_FUNC3: 102
              INFO  [voxl_esc] Params: VOXL_ESC_FUNC4: 103
              INFO  [voxl_esc] Params: VOXL_ESC_SDIR1: 0
              INFO  [voxl_esc] Params: VOXL_ESC_SDIR2: 0
              INFO  [voxl_esc] Params: VOXL_ESC_SDIR3: 0
              INFO  [voxl_esc] Params: VOXL_ESC_SDIR4: 0
              INFO  [voxl_esc] Params: VOXL_ESC_RPM_MIN: 5500
              INFO  [voxl_esc] Params: VOXL_ESC_RPM_MAX: 15000
              INFO  [voxl_esc] Params: VOXL_ESC_T_PERC: 90
              INFO  [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
              INFO  [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
              INFO  [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
              INFO  [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
              INFO  [voxl_esc] Params: VOXL_ESC_VLOG: 0
              INFO  [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
              INFO  [voxl_esc] Params: VOXL_ESC_T_WARN: 0
              INFO  [voxl_esc] Params: VOXL_ESC_T_OVER: 0
              INFO  [voxl_esc] Params: GPIO_CTL_CH: 0
              INFO  [voxl_esc]
              INFO  [voxl_esc] -- ID: 0
              INFO  [voxl_esc]    Motor:           1
              INFO  [voxl_esc]    Direction:       1
              INFO  [voxl_esc]    State:           0
              INFO  [voxl_esc]    Requested:       0 RPM
              INFO  [voxl_esc]    Measured:        0 RPM
              INFO  [voxl_esc]    Command Counter: 0
              INFO  [voxl_esc]    Voltage:         0.000000 VDC
              INFO  [voxl_esc]
              INFO  [voxl_esc] -- ID: 1
              INFO  [voxl_esc]    Motor:           4
              INFO  [voxl_esc]
              INFO  [voxl_esc] -- ID: 2
              INFO  [voxl_esc]    Motor:           2
              INFO  [voxl_esc]
              INFO  [voxl_esc] -- ID: 3
              INFO  [voxl_esc]    Motor:           3
              INFO  [voxl_esc]
              voxl_esc: cycle: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
              voxl_esc: output update interval: 0 events, 0.00us avg, min 0us max 0us 0.000us rms
              INFO  [mixer_module] Param prefix: VOXL_ESC
              control latency: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
              Channel Configuration:
              Channel 0: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
              Channel 1: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
              Channel 2: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
              Channel 3: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
                Jetson Nano
                Veteran
                Voxl2 is connected to Flight core v2 through telem 1.
                ESC is connected to flight core through telem 2.
                the parameters are the following
                  INFO  [voxl_esc]
                  INFO  [voxl_esc]
                  INFO  [voxl_esc]
                  INFO  [voxl_esc]
                  INFO  [voxl_esc]
                  INFO  [voxl_esc]
                  @Jetson-Nano said in VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2:
                  Can you please provide the debug prints that voxl_esc driver outputs when you call voxl_esc start ?
                    Jetson Nano
                    Veteran
                    #9
                    @Alex-Kushleyev When I run it for sometime it is makes the ESC blink once.
                    then once again if I run the command it gives the following statement
                    Error [voxl_esc] Task already running
                      @Jetson-Nano , you can stop the task and run it again or just look at the console output when you power on FC V2, so you see what happens when voxl_esc task prints when it start for the first time.
                        Jetson Nano
                        Veteran
                        #11
                        @Alex-Kushleyev
                        nsh> voxl_esc stop
                        ERROR [voxl_esc] timeout, forcing stop
                        ERROR [voxl_esc] failed restoring uart to original state
                        ERROR [voxl_esc] error closing uart
                        nsh> voxl_esc start
                        ERROR [px4_work_queue] wq:ttyS4 not available
                        ERROR [px4_work_queue] init failed
                        INFO  [voxl_esc] Starting VOXL ESC driver
                        nsh>
                        can you verify whether it is a parameter related error. I have mentioned the parameters in the above thread.
                          @Alex-Kushleyev
                          nsh> voxl_esc stop
                          nsh> voxl_esc start
                          nsh>
                          the error above seems like an issue.
                          Also is your ESC actually running at 250K baud rate? Did you verify this using voxl-esc tools?
                          Additionally, it seems the voxl_esc driver does not produce the prints I was expecting, let me check to make sure the FC V2 is using the latest voxl_esc implementation.
                            Jetson Nano
                            Veteran
                            #13
                            @Alex-Kushleyev
                            Yes it is running in the 250k baud rate.
                            I did not verify with the voxl-esc tools. I directly connected it to the FC.
                            I am using the voxl-fpv-dev version of px4
                              @Alex-Kushleyev
                              @Jetson-Nano , what do you mean voxl-fpv-dev version of px4? can you provide the link to the exact release?
                                Jetson Nano
                                Veteran
                                @Alex-Kushleyev
                                https://github.com/modalai/px4-firmware/tree/voxl-fpv-dev
                                  Jetson Nano
                                  Veteran
                                  #16
                                  @Alex-Kushleyev here you had mentioned a version where the change has been made with respect to the delay.
                                  https://forum.modalai.com/post/21951
                                    @Jetson-Nano , from your above screen shot from QGC, it seems you are using TELEM2 for MAV0, so that is probably why the port is not able to open. You should probably set MAV_0_CONFIG to Disabled...
                                      Jetson Nano
                                      Veteran
                                      @Alex-Kushleyev Thank you for the help . I changed the parameter and now the ESC has been initialised. motor are able to rotate.
                                      Also is there any other parameter i should be aware of
                                        @Jetson-Nano , since you are probably using a custom motor and propeller you should:
                                        • first of all, update the ESC firmware to the latest
                                        • calibrate the ESC for the motor/propeller and upload params
                                        • update min and max rpm params in PX4 because they are used to scale the control output
                                        • set the correct motor mapping and direction in px4 params
                                        • i also recommend updating the baud rate to at least 921600 (or 1M). We are using 2Mbit for all latest ESC configs now. This reduces latency and ensures that you don't have ESC packet drops (depending on the update rate of your flight control loop)
                                        In order to perform the updates and tuning, you will need to use voxl-esc tools. Please see the following page for more info: https://docs.modalai.com/voxl-escs/faq/
                                          Jetson Nano
                                          Veteran
                                          @Alex-Kushleyev Thank you for the support. I will make the changes you have mentioned.
