  3. VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2
31 Posts 3 Posters 6.8k Views 2 Watching
    @Jetson-Nano , if the voxl_esc driver is started by PX4 running on the Flight Core, it should print out debugging information to the UART console. The log below was taken from PX4 running on VOXL2 DSP, but the output should be the same when using Flight Core V2.
    Please also note that the Flight Core (V2), when powered up, starts immediately (as opposed to VOXL2 booting takes a few seconds), so FC V2 will try to detect the ESC before the ESC exits bootloader (which takes 1 second after power is applied) and will fail to detect the ESC. This was fixed in our FC V2 drone config, please check your voxl-esc driver behavior. Here is the commit that added the delay of 1.5 seconds before starting voxl esc driver on FC V2:
    • https://github.com/modalai/px4-firmware/pull/70/commits/55742d298bf9241a2af5aa2c7ba3a26788073356
    • https://github.com/modalai/px4-firmware/pull/70/commits/1c11e2e0ac3fcc19cb45ab59292b3cf5f4fdb348
    (voxl-esc driver log from VOXL2 DSP is below)
    INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
    INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
    INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
    INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
    INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 0
    INFO  [muorb] SLPI: VOXL_ESC: 	Board Type : 37: ModalAi 4-in-1 ESC (M0134-1)
    INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900480024
    INFO  [muorb] SLPI: VOXL_ESC: 	Firmware   : version   39, hash eb6fb500
    INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : version  183, hash b4fa2cf8
    INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1646us
    INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 1
    INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D004D
    INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 621us
    INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 2
    INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900500042
    INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : versiINFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1120us
    INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 3
    INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D0050
    INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 617us
    INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 1
    INFO  [muorb] SLPI: VOXL_ESC: All ESCs successfully detected
    Jetson NanoJ Offline
    Jetson Nano
    Veteran
    @Alex-Kushleyev Thank you for reverting back. I will verify this and get back.
    I changed the firmware version to the voxl-fpv-dev still the FC is not detecting the ESC.
    if i start esc through voxl_esc start , it is starting
    could please verify the parameters I mentioned.
    nsh> voxl_esc status
    INFO  [voxl_esc] Max update rate: 0 Hz
    INFO  [voxl_esc] Outputs on: no
    INFO  [voxl_esc] UART port: /dev/ttyS4
    INFO  [voxl_esc] UART open: no
    INFO  [voxl_esc]
    INFO  [voxl_esc] Params: VOXL_ESC_CONFIG: 1
    INFO  [voxl_esc] Params: VOXL_ESC_MODE: 0
    INFO  [voxl_esc] Params: VOXL_ESC_BAUD: 250000
    INFO  [voxl_esc] Params: VOXL_ESC_FUNC1: 101
    INFO  [voxl_esc] Params: VOXL_ESC_FUNC2: 104
    INFO  [voxl_esc] Params: VOXL_ESC_FUNC3: 102
    INFO  [voxl_esc] Params: VOXL_ESC_FUNC4: 103
    INFO  [voxl_esc] Params: VOXL_ESC_SDIR1: 0
    INFO  [voxl_esc] Params: VOXL_ESC_SDIR2: 0
    INFO  [voxl_esc] Params: VOXL_ESC_SDIR3: 0
    INFO  [voxl_esc] Params: VOXL_ESC_SDIR4: 0
    INFO  [voxl_esc] Params: VOXL_ESC_RPM_MIN: 5500
    INFO  [voxl_esc] Params: VOXL_ESC_RPM_MAX: 15000
    INFO  [voxl_esc] Params: VOXL_ESC_T_PERC: 90
    INFO  [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
    INFO  [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
    INFO  [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
    INFO  [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
    INFO  [voxl_esc] Params: VOXL_ESC_VLOG: 0
    INFO  [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
    INFO  [voxl_esc] Params: VOXL_ESC_T_WARN: 0
    INFO  [voxl_esc] Params: VOXL_ESC_T_OVER: 0
    INFO  [voxl_esc] Params: GPIO_CTL_CH: 0
    INFO  [voxl_esc]
    INFO  [voxl_esc] -- ID: 0
    INFO  [voxl_esc]    Motor:           1
    INFO  [voxl_esc]    Direction:       1
    INFO  [voxl_esc]    State:           0
    INFO  [voxl_esc]    Requested:       0 RPM
    INFO  [voxl_esc]    Measured:        0 RPM
    INFO  [voxl_esc]    Command Counter: 0
    INFO  [voxl_esc]    Voltage:         0.000000 VDC
    INFO  [voxl_esc]
    INFO  [voxl_esc] -- ID: 1
    INFO  [voxl_esc]    Motor:           4
    INFO  [voxl_esc]
    INFO  [voxl_esc] -- ID: 2
    INFO  [voxl_esc]    Motor:           2
    INFO  [voxl_esc]
    INFO  [voxl_esc] -- ID: 3
    INFO  [voxl_esc]    Motor:           3
    INFO  [voxl_esc]
    voxl_esc: cycle: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
    voxl_esc: output update interval: 0 events, 0.00us avg, min 0us max 0us 0.000us rms
    INFO  [mixer_module] Param prefix: VOXL_ESC
    control latency: 0 events, 0us elapsed, 0.00us avg, min 0us max 0us 0.000us rms
    Channel Configuration:
    Channel 0: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
    Channel 1: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
    Channel 2: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
    Channel 3: func:   0, value: 0, failsafe: 0, disarmed: 0, min: 5500, max: 15000
      @Jetson-Nano How are the VOXL_ESC parameters set on your FCv2? There could be a UART baud rate mismatch between what FCv2 is using and what the ESC is using.
      Jetson Nano
      Veteran
      @Eric-Katzfey @Alex-Kushleyev
      Voxl2 is connected to Flight core v2 through telem 1.
      ESC is connected to flight core through telem 2.
      the parameters are the following
      • Jetson NanoJ Jetson Nano
        INFO  [voxl_esc]
        INFO  [voxl_esc]
        INFO  [voxl_esc]
        INFO  [voxl_esc]
        INFO  [voxl_esc]
        INFO  [voxl_esc]
        @Jetson-Nano said in VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2:
        Can you please provide the debug prints that voxl_esc driver outputs when you call voxl_esc start ?
          Jetson Nano
          Veteran
          #9
          @Alex-Kushleyev When I run it for sometime it is makes the ESC blink once.
          then once again if I run the command it gives the following statement
          Error [voxl_esc] Task already running
            @Jetson-Nano , you can stop the task and run it again or just look at the console output when you power on FC V2, so you see what happens when voxl_esc task prints when it start for the first time.
              Jetson Nano
              Veteran
              #11
              nsh> voxl_esc stop
              ERROR [voxl_esc] timeout, forcing stop
              ERROR [voxl_esc] failed restoring uart to original state
              ERROR [voxl_esc] error closing uart
              nsh> voxl_esc start
              ERROR [px4_work_queue] wq:ttyS4 not available
              ERROR [px4_work_queue] init failed
              INFO  [voxl_esc] Starting VOXL ESC driver
              nsh>
              can you verify whether it is a parameter related error. I have mentioned the parameters in the above thread.
                nsh> voxl_esc stop
                nsh> voxl_esc start
                nsh>
                the error above seems like an issue.
                Also is your ESC actually running at 250K baud rate? Did you verify this using voxl-esc tools?
                Additionally, it seems the voxl_esc driver does not produce the prints I was expecting, let me check to make sure the FC V2 is using the latest voxl_esc implementation.
                  Jetson Nano
                  Veteran
                  #13
                  Yes it is running in the 250k baud rate.
                  I did not verify with the voxl-esc tools. I directly connected it to the FC.
                  I am using the voxl-fpv-dev version of px4
                    @Jetson-Nano , what do you mean voxl-fpv-dev version of px4? can you provide the link to the exact release?
                      Jetson Nano
                      Veteran
                      https://github.com/modalai/px4-firmware/tree/voxl-fpv-dev
                        Jetson Nano
                        Veteran
                        #16
                        @Alex-Kushleyev here you had mentioned a version where the change has been made with respect to the delay.
                        https://forum.modalai.com/post/21951
                          @Jetson-Nano , from your above screen shot from QGC, it seems you are using TELEM2 for MAV0, so that is probably why the port is not able to open. You should probably set MAV_0_CONFIG to Disabled...
                            Jetson Nano
                            Veteran
                            @Alex-Kushleyev Thank you for the help . I changed the parameter and now the ESC has been initialised. motor are able to rotate.
                            Also is there any other parameter i should be aware of
                              @Jetson-Nano , since you are probably using a custom motor and propeller you should:
                              • first of all, update the ESC firmware to the latest
                              • calibrate the ESC for the motor/propeller and upload params
                              • update min and max rpm params in PX4 because they are used to scale the control output
                              • set the correct motor mapping and direction in px4 params
                              • i also recommend updating the baud rate to at least 921600 (or 1M). We are using 2Mbit for all latest ESC configs now. This reduces latency and ensures that you don't have ESC packet drops (depending on the update rate of your flight control loop)
                              In order to perform the updates and tuning, you will need to use voxl-esc tools. Please see the following page for more info: https://docs.modalai.com/voxl-escs/faq/
                                Jetson Nano
                                Veteran
                                @Alex-Kushleyev Thank you for the support. I will make the changes you have mentioned.
                                  Jetson Nano
                                  Veteran
                                  #21
                                  hey @Alex-Kushleyev
                                  I am facing the same issue again, the ESC is not initialising when connected through fc v2 , i have followed all the suggestions you mentioned earlier. the FC as well as VOXL 2 is powered through ESC.
                                  nsh> voxl_esc start
                                  INFO  [voxl_esc] VOXL_ESC: Starting VOXL ESC driver
                                  INFO  [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
                                  INFO  [voxl_esc] not running
                                  nsh> voxl_esc start
                                  nsh>
                                    hey @Alex-Kushleyev
                                    nsh> voxl_esc start
                                    nsh> voxl_esc start
                                    nsh>
                                    @Jetson-Nano ,
                                    The primary causes of ESC not being detected by the FC (aside from hardware / wiring issues) is using incorrect UART port or incorrect baud rate. So you should make sure the ESC is running the latest firmware, double check the params that you want to use on the ESC (for your motor / prop) and you can also set the ESC baud rate in the ESC params. You should set up your ESC (using voxl-esc tools) before plugging it into your FC, so that you know exactly what your ESC is set up to do and then you just need to match your PX4 params to what you set in the ESC (baud rate, rpm limits, and use correct UART port).
                                      @Jetson-Nano ,
                                      Jetson Nano
                                      Veteran
                                      @Alex-Kushleyev Thank you for reverting, I didnt change anything with respect to the fc or ESC, the firmware is the same.
                                      could you help me with understanding why it was working earlier , it is not now.
                                      The firmware of the FC is voxl-fpv-dev version, and when i tried to build again it is giving error, and not building.
                                      I still dont know whether the issue is with respect to FC firmware or ESC
                                        @Jetson-Nano , please confirm the ESC is working by using a usb to serial connection directly to the esc and voxl-esc Python tools on a Linux PC or VM.
                                        You can run simple commands to detect the esc and perform spin tests if needed, this is all documented.
                                        If the esc is ok, then you will need to double check the FC v2 setup.
                                          Jetson Nano
                                          Veteran
                                          Hey @Alex-Kushleyev , for the same setup I mentioned above my esc is not starting by default, while I run voxl_esc start in mavlink console, it starts and works.
                                          what could be the reason for such behaviour. Please could you help me out
