  3. VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2
31 Posts 3 Posters 8.2k Views 2 Watching
  • Jetson NanoJ Jetson Nano
    @Alex-Kushleyev When I run it for sometime it is makes the ESC blink once.
    then once again if I run the command it gives the following statement
    Error [voxl_esc] Task already running
    @Jetson-Nano , you can stop the task and run it again or just look at the console output when you power on FC V2, so you see what happens when voxl_esc task prints when it start for the first time.
      Jetson NanoJ Offline
      Jetson Nano
      Veteran
      #11
      nsh> voxl_esc stop
      ERROR [voxl_esc] timeout, forcing stop
      ERROR [voxl_esc] failed restoring uart to original state
      ERROR [voxl_esc] error closing uart
      nsh> voxl_esc start
      ERROR [px4_work_queue] wq:ttyS4 not available
      ERROR [px4_work_queue] init failed
      INFO  [voxl_esc] Starting VOXL ESC driver
      INFO  [voxl_esc] Params: VOXL_ESC_CONFIG: 1
      INFO  [voxl_esc] Params: VOXL_ESC_MODE: 0
      INFO  [voxl_esc] Params: VOXL_ESC_BAUD: 250000
      INFO  [voxl_esc] Params: VOXL_ESC_FUNC1: 101
      INFO  [voxl_esc] Params: VOXL_ESC_FUNC2: 104
      INFO  [voxl_esc] Params: VOXL_ESC_FUNC3: 102
      INFO  [voxl_esc] Params: VOXL_ESC_FUNC4: 103
      INFO  [voxl_esc] Params: VOXL_ESC_SDIR1: 0
      INFO  [voxl_esc] Params: VOXL_ESC_SDIR2: 0
      INFO  [voxl_esc] Params: VOXL_ESC_SDIR3: 0
      INFO  [voxl_esc] Params: VOXL_ESC_SDIR4: 0
      INFO  [voxl_esc] Params: VOXL_ESC_RPM_MIN: 5500
      INFO  [voxl_esc] Params: VOXL_ESC_RPM_MAX: 15000
      INFO  [voxl_esc] Params: VOXL_ESC_T_PERC: 90
      INFO  [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
      INFO  [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
      INFO  [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
      INFO  [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
      INFO  [voxl_esc] Params: VOXL_ESC_VLOG: 0
      INFO  [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
      INFO  [voxl_esc] Params: VOXL_ESC_T_WARN: 0
      INFO  [voxl_esc] Params: VOXL_ESC_T_OVER: 0
      INFO  [voxl_esc] Params: GPIO_CTL_CH: 0
      nsh>
      can you verify whether it is a parameter related error. I have mentioned the parameters in the above thread.
        nsh> voxl_esc stop
        nsh> voxl_esc start
        nsh>
        @Jetson-Nano said in VOXL FPV Racing 4-in-1 ESC with flight core v2 and voxl2:
        the error above seems like an issue.
        Also is your ESC actually running at 250K baud rate? Did you verify this using voxl-esc tools?
        Additionally, it seems the voxl_esc driver does not produce the prints I was expecting, let me check to make sure the FC V2 is using the latest voxl_esc implementation.
          Jetson Nano
          Veteran
          #13
          Yes it is running in the 250k baud rate.
          I did not verify with the voxl-esc tools. I directly connected it to the FC.
          I am using the voxl-fpv-dev version of px4
            @Jetson-Nano , what do you mean voxl-fpv-dev version of px4? can you provide the link to the exact release?
              Jetson Nano
              Veteran
              https://github.com/modalai/px4-firmware/tree/voxl-fpv-dev
                @Jetson-Nano , if the voxl_esc driver is started by PX4 running on the Flight Core, it should print out debugging information to the UART console. The log below was taken from PX4 running on VOXL2 DSP, but the output should be the same when using Flight Core V2.
                Please also note that the Flight Core (V2), when powered up, starts immediately (as opposed to VOXL2 booting takes a few seconds), so FC V2 will try to detect the ESC before the ESC exits bootloader (which takes 1 second after power is applied) and will fail to detect the ESC. This was fixed in our FC V2 drone config, please check your voxl-esc driver behavior. Here is the commit that added the delay of 1.5 seconds before starting voxl esc driver on FC V2:
                • https://github.com/modalai/px4-firmware/pull/70/commits/55742d298bf9241a2af5aa2c7ba3a26788073356
                • https://github.com/modalai/px4-firmware/pull/70/commits/1c11e2e0ac3fcc19cb45ab59292b3cf5f4fdb348
                (voxl-esc driver log from VOXL2 DSP is below)
                INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
                INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
                INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
                INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
                INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 0
                INFO  [muorb] SLPI: VOXL_ESC: 	Board Type : 37: ModalAi 4-in-1 ESC (M0134-1)
                INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900480024
                INFO  [muorb] SLPI: VOXL_ESC: 	Firmware   : version   39, hash eb6fb500
                INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : version  183, hash b4fa2cf8
                INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1646us
                INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 1
                INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D004D
                INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 621us
                INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 2
                INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x203330385246571900500042
                INFO  [muorb] SLPI: VOXL_ESC: 	Bootloader : versiINFO  [qshell] Send cmd: 'voxl_esc start'
                INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 1120us
                INFO  [muorb] SLPI: VOXL_ESC: 	ESC ID     : 3
                INFO  [muorb] SLPI: VOXL_ESC: 	Unique ID  : 0x2033303852465719004D0050
                INFO  [muorb] SLPI: VOXL_ESC: 	Reply time : 617us
                INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 1
                INFO  [muorb] SLPI: VOXL_ESC: All ESCs successfully detected
                Jetson Nano
                Veteran
                #16
                @Alex-Kushleyev here you had mentioned a version where the change has been made with respect to the delay.
                https://forum.modalai.com/post/21951
                  @Jetson-Nano , from your above screen shot from QGC, it seems you are using TELEM2 for MAV0, so that is probably why the port is not able to open. You should probably set MAV_0_CONFIG to Disabled...
                    Jetson Nano
                    Veteran
                    @Alex-Kushleyev Thank you for the help . I changed the parameter and now the ESC has been initialised. motor are able to rotate.
                    Also is there any other parameter i should be aware of
                      @Jetson-Nano , since you are probably using a custom motor and propeller you should:
                      • first of all, update the ESC firmware to the latest
                      • calibrate the ESC for the motor/propeller and upload params
                      • update min and max rpm params in PX4 because they are used to scale the control output
                      • set the correct motor mapping and direction in px4 params
                      • i also recommend updating the baud rate to at least 921600 (or 1M). We are using 2Mbit for all latest ESC configs now. This reduces latency and ensures that you don't have ESC packet drops (depending on the update rate of your flight control loop)
                      In order to perform the updates and tuning, you will need to use voxl-esc tools. Please see the following page for more info: https://docs.modalai.com/voxl-escs/faq/
                        Jetson Nano
                        Veteran
                        @Alex-Kushleyev Thank you for the support. I will make the changes you have mentioned.
                          Jetson Nano
                          Veteran
                          #21
                          hey @Alex-Kushleyev
                          I am facing the same issue again, the ESC is not initialising when connected through fc v2 , i have followed all the suggestions you mentioned earlier. the FC as well as VOXL 2 is powered through ESC.
                          nsh> voxl_esc start
                          INFO  [voxl_esc] VOXL_ESC: Starting VOXL ESC driver
                          INFO  [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
                          nsh> voxl_esc status
                          INFO  [voxl_esc] not running
                          nsh> voxl_esc start
                          nsh>
                            hey @Alex-Kushleyev
                            nsh> voxl_esc start
                            nsh> voxl_esc start
                            nsh>
                            @Jetson-Nano ,
                            The primary causes of ESC not being detected by the FC (aside from hardware / wiring issues) is using incorrect UART port or incorrect baud rate. So you should make sure the ESC is running the latest firmware, double check the params that you want to use on the ESC (for your motor / prop) and you can also set the ESC baud rate in the ESC params. You should set up your ESC (using voxl-esc tools) before plugging it into your FC, so that you know exactly what your ESC is set up to do and then you just need to match your PX4 params to what you set in the ESC (baud rate, rpm limits, and use correct UART port).
                              @Jetson-Nano ,
                              Jetson Nano
                              Veteran
                              @Alex-Kushleyev Thank you for reverting, I didnt change anything with respect to the fc or ESC, the firmware is the same.
                              could you help me with understanding why it was working earlier , it is not now.
                              The firmware of the FC is voxl-fpv-dev version, and when i tried to build again it is giving error, and not building.
                              I still dont know whether the issue is with respect to FC firmware or ESC
                                @Jetson-Nano , please confirm the ESC is working by using a usb to serial connection directly to the esc and voxl-esc Python tools on a Linux PC or VM.
                                You can run simple commands to detect the esc and perform spin tests if needed, this is all documented.
                                If the esc is ok, then you will need to double check the FC v2 setup.
                                  Jetson Nano
                                  Veteran
                                  Hey @Alex-Kushleyev , for the same setup I mentioned above my esc is not starting by default, while I run voxl_esc start in mavlink console, it starts and works.
                                  what could be the reason for such behaviour. Please could you help me out
                                    @Jetson-Nano , this is likely related to the fact that the FC starts quicker than the ESC bootloader's 1s wait time. We discussed this before.
                                    So if you are saying that delaying the start of voxl_esc driver in px4 on your FC solves the problem, then the issue is exactly that.
                                    Please delay the start of the voxl_esc driver in your px4 start-up script, for example you can see it at the bottom of the script here : https://github.com/modalai/px4-firmware/blob/bugfix-fpv-rev0-airframe/boards/modalai/fc-v2/init/rc.board_sensors
                                    if param greater VOXL_ESC_CONFIG 0
                                    then
                                    	usleep 1500000
                                    	voxl_esc start
                                    fi
                                      then
                                      	usleep 1500000
                                      	voxl_esc start
                                      fi
                                      Jetson Nano
                                      Veteran
                                      @Alex-Kushleyev I have already tried it, It was working fine earlier. since past 2 days the behaviour has changed, I have verified everything else and nothing else could be a reason for such behaviour , I even played around with delay to verify it, still the same issue.
                                      please excuse me for repeating the questions but is there any other reason that can cause this issue.
                                        @Jetson-Nano ,
                                        Thank you for clarifying. Unfortunately, since I don't know what you changed between the working and non-working condition, it is hard to help. Also, since you are indicating that the ESC is responding if you manually start the esc driver, then the ESC itself should still be functional.
                                        Please try to backtrack your changes until you have a working setup again.
                                          @Jetson-Nano ,
                                          Jetson Nano
                                          Veteran
                                          @Alex-Kushleyev , I will backtrack the steps and try re-configuring the setup.
