    microhard integration with voxl2, not able to get the data.
    1087
    • Jetson NanoJ
      Jetson Nano
      Hello @Vinny @tom @Alex-Kushleyev @modaltb @Eric-Katzfey
      I am trying to integrate microhard with voxl2. I was able to set up the master connection in the voxl side, as well as setup slave side. Both of the microhard modules are showing connected, but the ip address on the slave side is varying and ip address on the voxl side, thats the master side is also varying.
      Can anyone help me with the error.
      0564f849-7d09-45c9-9a58-93b69fea20ff-Screenshot from 2025-04-11 18-55-01.png b1e05ca4-8f37-4cbc-87b9-859ed1e9257b-Screenshot from 2025-04-11 18-58-50.png
      1540c9e1-f78d-47f1-a4df-4994683c8932-Screenshot from 2025-04-11 19-08-58.png
      • tomT
        tom admin @Jetson Nano
        @Jetson-Nano See here how to set a static IP for microhard on the VOXL side: https://docs.modalai.com/microhard-add-on-manual/#software-setup
        For the ground station side you'll have to manually assign an IP, like we do for Doodle modems here: https://docs.modalai.com/doodle-labs-user-guide/#ground-station-software-setup
        Jetson NanoJ 1 Reply Last reply Reply Quote 0
        • Jetson NanoJ
          Jetson Nano @tom
          @tom Thanks for reverting back. I repeated those steps and now the IP is static, still I am not able to get the data from the VOXL 2 board. Is there any thing else I am required to setup.
          • tomT
            @Jetson-Nano Are you able to ping from VOXL2 to the onboard Microhard board or the other Microhard board with the modules specified IPs? Usually 192.168.168.1 for master and 192.168.168.2 for slave
            Jetson NanoJ 2 Replies Last reply Reply Quote 0
            • Jetson NanoJ
              Jetson Nano @tom
              @tom I am able to ping the onboard microhard board, by ping 192.168.168.1, but when I try ping 192.168.168.2 or the custom ip I set, it is showing host destination unreachable
              • Jetson NanoJ
                Jetson Nano @Jetson Nano
                @tom I was able to get the data,, i had to change the ip address in voxl-mavlink-server. Also slave connection was not getting established automatically, I had to do it manually.
                Now I am able to get both portal data and start QGC.
                • Jetson NanoJ
                  Jetson Nano @tom
                  @tom I would like to know whether I could use two microhard ground units to communicate with each other. one on air and another on the ground side.
                  • tomT
                    @Jetson-Nano Yes, you can. You just need to make sure one is a "master" and one is a "slave"
                    • Jetson NanoJ
                      Jetson Nano @tom
                      @tom I had an additional query , when i connect the microhard ground module to the windows system, I am able to get the portal on browser through the ip address 192.168.168.100. when I assign the ip to the QGC, it is not loading.
                      This was not an issue in ubuntu, in ubuntu the QGC was loading automatically.
                      • tomT
                        @Jetson-Nano We have never used Microhard on windows but it's possible your firewall is blocking UDP data on that port
