  2. VOXL Accessories
  3. Microhard Modems
  4. RC connection/MH carrier directly to VOXL2, while using Flight core V2
Scheduled Pinned Locked Moved Microhard Modems
7 Posts 2 Posters 937 Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Hello @Vinny @tom
    I am currently working with Flight Core v2 as the External FC. I would like to know if I could connect the RC(SBus ELRS) to VOXL 2 board , instead of connecting to the FC. Since it is similiar to the connection here, where Microhard modem is used with Cube orange - FC.
    • Jetson NanoJ Jetson Nano
      Hello @Vinny @tom
      @Jetson-Nano Which connector would you use for this on VOXL 2? In order to send RC values to PX4 running on an external FC v2 you need to send the RC values in an RC_CHANNELS_OVERRIDE Mavlink message. (https://mavlink.io/en/messages/common.html#RC_CHANNELS_OVERRIDE) So, you would need a custom program on the VOXL 2 to read the input from the RC receiver, create the Mavlink message, and send it to the external FC over the UART.
        Jetson Nano
        Veteran
        @Eric-Katzfey thanks for reverting back. can you be little more specific about where to create the custom program and run it. is it inside any servers or externally.
        could guide me with the development.
          Jetson Nano
          Veteran
          @Eric-Katzfey I'm planning to use the similar case as in Starling 2 Drone. I'm planning to use the J19 port.
            @Jetson-Nano I think what you are trying to do is entirely possible. But it isn't anything we have ever tried. So I'm just throwing out some ideas that could maybe help you develop this. Or maybe you have some better ideas. One possibility, that I was referring to above, is to create a new program running on the Linux applications processor. It would have to use the libqrb5165-io library to get access to the UART on J19 that is mapped to the SLPI DSP. Another idea is to actually run PX4 on VOXL 2 and either use px4-listener to monitor the input_rc topic or monitor the RC_CHANNELS Mavlink message via voxl-mavlink-server or even voxl-vision-hub and use that to create an RC_CHANNELS_OVERRIDE Mavlink message to send to the external FC. I'm just brainstorming here and can't really provide much more support than offering some high level ideas.
              Jetson Nano
              Veteran
              @Eric-Katzfey Thank you for reverting back. I would like to try out the voxl-mavlink-server approach. I had question with regards to that, how will i be able to get the DATA
              (RC_CHANNELS) from the mavlink-server. Any ideas regarding that.
              @Alex-Kushleyev
                @Alex-Kushleyev
                @Jetson-Nano Here's some example code: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/master/src/autopilot_monitor.c?ref_type=heads#L514
