  3. Starling drone shut down mid flight
30 Posts 4 Posters 7.0k Views 2 Watching
  • Shivam SehgalS Shivam Sehgal
    @Alex-Kushleyev Yes Alex, it's glued to the board. Sorry, how can I connect with RMA department?
    @Shivam-Sehgal
    https://www.modalai.com/pages/rma
    Shivam SehgalS 1 Reply Last reply
      @Shivam-Sehgal
      Shivam SehgalS Offline
      Shivam Sehgal
      @Alex-Kushleyev It's a form to send my drone for repair, can't I repair it myself? I have already ordered all the parts required. I just need to understand how to remove the glue.
      tomT Jeremy SchmidtJ 2 Replies Last reply
        @Shivam-Sehgal I will see if a member from our production team can chime in here
          Jeremy SchmidtJ Offline
          Jeremy Schmidt
          @Shivam-Sehgal
          The glue is an easy to remove RTV silicone adhesive. If you follow the instructions posted by Alex, you should be successful. I've done this myself a couple of times.
          After removing you will need to clean away as much of the remaining glue on the voxl2 as possible before installing the new adapter board. You don't necessarily need to apply glue when installing the new board, but we find it helps with keeping the adapter from accidentally teetering at the hirose connector.
          Please let me know if you need further help with this matter
          • Jeremy SchmidtJ Jeremy Schmidt
            @Shivam-Sehgal
            Shivam Sehgal
            @Jeremy-Schmidt So I don't need heat or any special tool for it I can directly remove by hand?
              Shivam Sehgal
              wrote on last edited by Shivam Sehgal
              #26
              @tom I was able to get the camera board out thank you but ...
              When I again add the 2 new camera boards with out the camera's attached it works I can adb into the board, but as soon as any camera is added I cannot adb into the board.
              I am using 2 new boards and 2 new camera's tracking and hires it seems like the issue is something else what can I do?
                @Shivam-Sehgal Double check the pinouts to ensure the sensors aren't being plugged in backwards, that is the most likely cause of a board not booting
                  Shivam Sehgal
                  @tom thanks I had opened the board so I did not notice it, only if I had assemble I would have noticed it.
                  Thank you so much it worked!
                    Shivam Sehgal
                    @tom @Alex-Kushleyev
                    I corrected everything and it seemed to work for a minute there then again adb connection broke.
                    I disconnect the cameras and I am able to adb but with the cameras it does work for like 10 seconds and then the connection breaks.
                      @Shivam-Sehgal , does it look like the board is rebooting after 10 seconds of running with cameras enabled? also, what if you ssh into the board, does the SSH connection stay alive when the cameras are connecting?
                      Also, how are you powering the drone for this test - battery or power supply?
