  3. Starling drone shut down mid flight
30 Posts 4 Posters 7.4k Views 2 Watching
    @Shivam-Sehgal , Yes, you should try it, however i am not sure whether the recovery attempt will be successful. Typically unbricking is required when something goes wrong during SDK update or something like that, when the system is left in incomplete state. In your case, the drone was flying and stopped responding after a crash. The fact that it shut off during flight could mean there was a pre-existing issue (before the crash) which may be causing the board not to boot now. However, it is worth to try the unbricking and if does not work, please contact our RMA department, they will help you out.
    Shivam SehgalS Offline
    Shivam Sehgal
    @Alex-Kushleyev I did not unbrick it it had opened the voxl2 board and I was able to connect to it, then when I closed it it did not connect again.
    What I found out is when the hires and tracking camera are connected to the board I am unable to connect to the drone. What could be the reason for this?
    • Shivam SehgalS Shivam Sehgal
      @Shivam-Sehgal , most likely one of the camera flex cables is broken and it is shorting one of the power rails to ground, which prevents voxl2 from booting. I suggest trying to connect one camera at a time to narrow down the issue to a specific camera and then inspect the “bad” camera’s flex cable or extension flex cable.
      Shivam SehgalS 1 Reply Last reply
        Shivam Sehgal
        @Alex-Kushleyev I connected both cameras to the other connector on which tof sensor was connected. I could connect to the board. Also the tof sensor worked on the other board.
        But I could not connect to the tracking and hires camera, I could only connected to TOF sensor.
          Shivam Sehgal
          @Shivam-Sehgal I connected the cameras back in their basic configration that it is shipped with.
          Then I ran voxl-camera-cameras and set it to 06 - D0005 Starling pmd-tof imx214 hires ov7251 tracking.
          voxl2:/$ voxl-configure-cameras
          Available camera config IDs are as follows:
          01 - ov7251 tracking ov7251 stereo
          02 - ov7251 tracking
          03 - ov7251 tracking ov7251 stereo imx214 hires
          04 - ov7251 tracking imx214 hires
          05 - pmd-tof ov7251 tracking
          08 - imx214
          09 - pmd-tof
          10 - ov7251 stereo
          11 - D0006 Sentinel
          12 - ov9782 stereo
          13 - ov9782 stereo imx214 hires
          14 - ov9782 stereo pmd-tof ov7251 tracking (copy)
          15 - D0008 dual 9782 tracking
          16 - pmd-tof ov7251 dual tracking imx214 hires
          17 - D0010 pmd-tof imx412 hires ov7251 tracking ov9782 stereo
          18 - D0008 triple ov9782
          19 - D0005 without tof imx214 hires ov7251 tracking
          20 - D0011 imx412 hires ar0144 tracking
          21 - old C6
          22 - D0013 imx412 flipped ov7251
          23 - D0010 without stereo
           C - use user-defined custom camera config in
               (/data/modalai/custom_camera_config.txt)
           q - Quit The Wizard
          selection: 6
          Selected numerical camera config
          Camera Configuration: 6
          camera server config helper list:
          tof:pmd-tof:0:
          hires:imx214:1:
          tracking:ov7251:2:
          driver binary list:
          /usr/share/modalai/chi-cdk/irs1645/com.qti.sensormodule.irs1645_0.bin
          /usr/share/modalai/chi-cdk/imx214/com.qti.sensormodule.imx214_2.bin
          /usr/share/modalai/chi-cdk/ov7251/com.qti.sensormodule.ov7251_3.bin
          calling camera-server-config-helper tof:pmd-tof:0: hires:imx214:1: tracking:ov7251:2:
          detected system image 1.7.1
          using new imx214 defaults
          successfully wrote this camera config to disk:
          configuration for 3 cameras:
          cam #0
              sensor type:         pmd-tof
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              small_video_width:   -1
              small_video_height:  -1
              en_large_video:      0
              large_video_width:   -1
              large_video_height:  -1
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
              independent_exposure:0
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              small_video_width:   1024
              small_video_height:  768
              en_large_video:      1
              large_video_width:   4208
              large_video_height:  3120
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          camera_server_config_helper is done
          copying required camera drivers in place
          enabling voxl-camera-server
          Done Configuring Cameras
          Please power cycle VOXL to load new drivers
          camera server will start on next reboot
          After this I manually restarted the voxl-camera-server and the connection broke after the output below.
          voxl2:/$ voxl-camera-server
          cam #0
              isEnabled:           1
              camId:               0
              camId2:              -1
              fps:                 5
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           224
              pre_height:          1557
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             off
              standby_enabled:     0
              decimator:           5
          cam #1
              sensor type:         imx214
              isEnabled:           1
              camId:               1
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          0
              pre_width:           640
              pre_height:          480
              en_raw_preview:      0
              en_small_video:      1
              en_large_video:      1
              en_snapshot:         1
              snap_width:          4208
              snap_height:         3120
              ae_mode:             isp
              standby_enabled:     0
              decimator:           1
          cam #2
              sensor type:         ov7251
              isEnabled:           1
              camId:               2
              camId2:              -1
              fps:                 30
              en_rotate:           0
              en_rotate2:          0
              en_preview:          1
              pre_width:           640
              pre_height:          480
              en_raw_preview:      1
              en_small_video:      0
              en_large_video:      0
              en_snapshot:         0
              snap_width:          -1
              snap_height:         -1
              ae_mode:             lme_msv
              standby_enabled:     0
              decimator:           1
          GPS server Connected
          Starting Camera: tof (id #0)
          Starting Camera: hires (id #1)
          Using gain limits min: 54 max: 431
          WARNING: Port Def 0:
          	Count Min: 8
          	Count Actual: 16
          	Buffers Contiguous: Yes
          	Buffer Alignment: 0
          WARNING: Port Def 1:
          	Count Min: 4
          	Count Actual: 16
          	Buffers Contiguous: No
          	Buffer Alignment: 0
          	Count Min: 8
          	Count Actual: 16
          	Buffer Alignment: 0
          	Count Min: 4
          	Count Actual: 16
          	Buffer Alignment: 0
          Starting Camera: tracking (id #2)
          Using gain limits min: 54 max: 3451
          setting ov7251 BLC register for cam id 2
          ------ voxl-camera-server: Started 3 of 3 cameras
            08 - imx214
            09 - pmd-tof
            10 - ov7251 stereo
            11 - D0006 Sentinel
            12 - ov9782 stereo
            21 - old C6
             q - Quit The Wizard
            selection: 6
            tof:pmd-tof:0:
            hires:imx214:1:
            tracking:ov7251:2:
            driver binary list:
            cam #0
                isEnabled:           1
                camId:               0
                camId2:              -1
                fps:                 5
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           224
                pre_height:          1557
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             off
                standby_enabled:     0
                decimator:           5
            cam #1
                sensor type:         imx214
                isEnabled:           1
                camId:               1
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          0
                pre_width:           640
                pre_height:          480
                en_raw_preview:      0
                en_small_video:      1
                en_large_video:      1
                en_snapshot:         1
                snap_width:          4208
                snap_height:         3120
                ae_mode:             isp
                standby_enabled:     0
                decimator:           1
            cam #2
                sensor type:         ov7251
                isEnabled:           1
                camId:               2
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           640
                pre_height:          480
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            cam #0
                isEnabled:           1
                camId:               0
                camId2:              -1
                fps:                 5
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           224
                pre_height:          1557
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             off
                standby_enabled:     0
                decimator:           5
            cam #1
                sensor type:         imx214
                isEnabled:           1
                camId:               1
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          0
                pre_width:           640
                pre_height:          480
                en_raw_preview:      0
                en_small_video:      1
                en_large_video:      1
                en_snapshot:         1
                snap_width:          4208
                snap_height:         3120
                ae_mode:             isp
                standby_enabled:     0
                decimator:           1
            cam #2
                sensor type:         ov7251
                isEnabled:           1
                camId:               2
                camId2:              -1
                fps:                 30
                en_rotate:           0
                en_rotate2:          0
                en_preview:          1
                pre_width:           640
                pre_height:          480
                en_raw_preview:      1
                en_small_video:      0
                en_large_video:      0
                en_snapshot:         0
                snap_width:          -1
                snap_height:         -1
                ae_mode:             lme_msv
                standby_enabled:     0
                decimator:           1
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 8
            	Count Actual: 16
            	Buffer Alignment: 0
            	Count Min: 4
            	Count Actual: 16
            	Buffer Alignment: 0
            @Shivam-Sehgal , sorry, can we please take one step back and clarify something..
            Does the VOXL2 board now boot with all the cameras plugged into the original configuration?
            Also, when you say After this I manually restarted the voxl-camera-server and the connection broke after the output below. -- which connection are you referring to?
            If you are able to connect all cameras to their original slots, but something is still not working, i suggest that you test with only one camera enabled at a time and figure out if there is still one camera that is not working.
            Shivam SehgalS 2 Replies Last reply
              Shivam Sehgal
              @Alex-Kushleyev I hope this clears somethings out, its confusing for me too.
              no it does not boot now with all the camera's plugged in original physical connections.
              It was not about the physical connections, but when the camera service started then the connection broke.
              First I shifted the physical connections of the camera's as mentioned above, after which I could boot but the hires and tracking camera did not work or start. (https://forum.modalai.com/post/19383)
              Then restored the original physical connnections, set the voxl-configure-camera to it original configuration it's shipped with and then restarted the voxl-camera-server.
              When I started the service this the output of it, after this output the adb and ssh connection broke and I was unable to connection to the voxl2 board.
              cam #0
                  isEnabled:           1
                  camId:               0
                  camId2:              -1
                  fps:                 5
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           224
                  pre_height:          1557
                  en_raw_preview:      1
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             off
                  standby_enabled:     0
                  decimator:           5
              cam #1
                  sensor type:         imx214
                  isEnabled:           1
                  camId:               1
                  camId2:              -1
                  fps:                 30
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          0
                  pre_width:           640
                  pre_height:          480
                  en_raw_preview:      0
                  en_small_video:      1
                  en_large_video:      1
                  en_snapshot:         1
                  snap_width:          4208
                  snap_height:         3120
                  ae_mode:             isp
                  standby_enabled:     0
                  decimator:           1
              cam #2
                  sensor type:         ov7251
                  isEnabled:           1
                  camId:               2
                  camId2:              -1
                  fps:                 30
                  en_rotate:           0
                  en_rotate2:          0
                  en_preview:          1
                  pre_width:           640
                  pre_height:          480
                  en_raw_preview:      1
                  en_small_video:      0
                  en_large_video:      0
                  en_snapshot:         0
                  snap_width:          -1
                  snap_height:         -1
                  ae_mode:             lme_msv
                  standby_enabled:     0
                  decimator:           1
              	Count Min: 8
              	Count Actual: 16
              	Buffer Alignment: 0
              	Count Min: 4
              	Count Actual: 16
              	Buffer Alignment: 0
              	Count Min: 8
              	Count Actual: 16
              	Buffer Alignment: 0
              	Count Min: 4
              	Count Actual: 16
              	Buffer Alignment: 0
                Shivam Sehgal
                wrote on last edited by Shivam Sehgal
                #17
                @Alex-Kushleyev I was able to point out maybe it's the hires camera that's the issue. I don't know why but I was singly able to run all other camera's but not the hires camera.
                What defect should I look for?
                Also, while doing all that I broke the tracking camera's connector and the 2 in 1 camera boards. I will be ordering those. How can I remove the 2 in 1 camera board from the voxl2 board?
                  Shivam Sehgal
                  @Alex-Kushleyev any update?
                  How can can I remove the 2 in 1 camera board?
                    @Shivam-Sehgal , sorry for the delay!
                    Can you please contact our RMA department and send them the pictures of the current state of the board and camera adapter interposers. Our production team can evaluate the pictures. On some products the interposer boards may be glued in place for robustness, so they can suggest best way to handle it.
                    In general, here is a diagram from the Hirose's product manual that shows how typically you should remove these connnectors:
                      Shivam Sehgal
                      @Alex-Kushleyev Yes Alex, it's glued to the board. Sorry, how can I connect with RMA department?
                        @Shivam-Sehgal
                        https://www.modalai.com/pages/rma
                          @Shivam-Sehgal
                          Shivam Sehgal
                          @Alex-Kushleyev It's a form to send my drone for repair, can't I repair it myself? I have already ordered all the parts required. I just need to understand how to remove the glue.
                          tomT Jeremy SchmidtJ 2 Replies Last reply
                            @Shivam-Sehgal I will see if a member from our production team can chime in here
                              Jeremy SchmidtJ Offline
                              Jeremy Schmidt
                              @Shivam-Sehgal
                              The glue is an easy to remove RTV silicone adhesive. If you follow the instructions posted by Alex, you should be successful. I've done this myself a couple of times.
                              After removing you will need to clean away as much of the remaining glue on the voxl2 as possible before installing the new adapter board. You don't necessarily need to apply glue when installing the new board, but we find it helps with keeping the adapter from accidentally teetering at the hirose connector.
                              Please let me know if you need further help with this matter
                              • Jeremy SchmidtJ Jeremy Schmidt
                                @Shivam-Sehgal
                                Shivam Sehgal
                                @Jeremy-Schmidt So I don't need heat or any special tool for it I can directly remove by hand?
                                  Shivam Sehgal
                                  #26
                                  @tom I was able to get the camera board out thank you but ...
                                  When I again add the 2 new camera boards with out the camera's attached it works I can adb into the board, but as soon as any camera is added I cannot adb into the board.
                                  I am using 2 new boards and 2 new camera's tracking and hires it seems like the issue is something else what can I do?
                                    @Shivam-Sehgal Double check the pinouts to ensure the sensors aren't being plugged in backwards, that is the most likely cause of a board not booting
                                      Shivam Sehgal
                                      @tom thanks I had opened the board so I did not notice it, only if I had assemble I would have noticed it.
                                      Thank you so much it worked!
                                        Shivam Sehgal
                                        @tom @Alex-Kushleyev
                                        I corrected everything and it seemed to work for a minute there then again adb connection broke.
                                        I disconnect the cameras and I am able to adb but with the cameras it does work for like 10 seconds and then the connection breaks.
                                          @Shivam-Sehgal , does it look like the board is rebooting after 10 seconds of running with cameras enabled? also, what if you ssh into the board, does the SSH connection stay alive when the cameras are connecting?
                                          Also, how are you powering the drone for this test - battery or power supply?
