  3. voxl-px4 service pipeline uORB failure
15 Posts 6 Posters 2.8k Views 3 Watching
  • jacob yaacubovJ Offline
    jacob yaacubov
    my voxl2 which is running on dev drone is failing to communicate with the PX4
    i use the 1.0.0 SDK
    systemctl status voxl-px4 gives this
    PORT:/etc/modalai$ systemctl status voxl-px4.service
    ● voxl-px4.service - px4
       Loaded: loaded (/etc/systemd/system/voxl-px4.service; enabled; vendor preset: enabled)
       Active: active (running) since Thu 2024-04-11 18:14:47 IDT; 9s ago
      Process: 18235 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
     Main PID: 18358 (voxl-px4)
        Tasks: 13 (limit: 4915)
       CGroup: /system.slice/voxl-px4.service
               ├─18358 /bin/bash /usr/bin/voxl-px4
               ├─18365 px4 -d -s /usr/bin/voxl-px4-start
               ├─18886 /bin/sh /usr/bin/voxl-px4-start 0
               └─18956 px4-param --instance 0 load
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] orb_publish failed parameter_update
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] Error Sending [parameter_client_set_value_request] topic data over comm_channel
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO1_PRIO
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [uORB] Error Sending [parameter_update] topic data over comm_channel
    Apr 11 18:14:56 PORT voxl-px4[18358]: ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CAL_GYRO2_PRIO
    looks like no parameters passed successfully to pxs4 dsp - the parameters were unchnged so it not related to their content
    itried to restart various services but it doenst help
    i compared the config files to other working drone
    nothing helped shall i reinstall the sdk
    • jacob yaacubovJ jacob yaacubov
      i use the 1.0.0 SDK
      Eric KatzfeyE Online
      @jacob-yaacubov You should definitely upgrade to SDK 1.1.3.
      jacob yaacubovJ 1 Reply Last reply
        jacob yaacubov
        @Eric-Katzfey i tried this now
        i reinstalled 1.1.3 and even tried again to reinstall 1.0.0
        i used different px4 parameters file backed up by me
        and still get error in the px4 service
        i cant even see my drone in the ground control seems like something seriously wrong with px4 any other suggestions ? @Eric-Katzfey
           Active: active (running) since Sun 2024-04-14 11:55:27 UTC; 3min 38s ago
          Process: 12036 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
         Main PID: 12042 (voxl-px4)
            Tasks: 15 (limit: 4915)
                   ├─12042 /bin/bash /usr/bin/voxl-px4
                   ├─12045 px4 -d -s /usr/bin/voxl-px4-start
                   ├─12062 /bin/sh /usr/bin/voxl-px4-start 0
                   └─13882 px4-qshell --instance 0 ekf2 start
        Apr 14 11:58:19 m0054 voxl-px4[12042]: ERROR [qshell] command timed out
        Apr 14 11:58:19 m0054 voxl-px4[12042]: ERROR [qshell] Command failed
          @jacob-yaacubov , can you please stop and disable voxl-px4 service:
          systemctl stop voxl-px4
          systemctl disable voxl-px4
          then reboot voxl2, and start px4 manually in foreground:
          voxl-px4 -d
          Then save the output (from the terminal) into a text file and share with us?
          S 1 Reply Last reply
            voxl-px4 -d
            S Offline
            S Offline
            swickliff
            @Alex-Kushleyev It looks like I am having the same issue as Jacob. We've added a brand new Voxl2 to our drone, this one is running on SDK 1.1.3 and we cannot get it to connect to PX4. Our prior build used Voxl2s with SDK 1.1.2 and worked fine for us, so we tried downgrading the SDK but that did not work either.
            We re-updated the SDK to 1.1.3 and I stopped and disabled voxl-px4 service and rebooted the Voxl2 and started px4 manually. Want me to share a text file with the output?
            tomT Alex KushleyevA 2 Replies Last reply
            • S swickliff
              @swickliff If you believe that the file system is corrupted you can reflash the latest SDK release using the -w arg, ./install.sh -w
              This will wipe all partitions, ensuring your board is in a factory state
              • S swickliff
                @swickliff , please share the output of px4 starting manually and also try to do a full wipe as Tom suggested and see if that helps. Thanks!
                Jeremy FrederickJ 1 Reply Last reply
                  Jeremy FrederickJ Offline
                  Jeremy Frederick
                  @Alex-Kushleyev
                  Alex, picking up this thread where swickliff left off. We tried a full partion wipe and are still having issues. Attached to this post is a .txt file with the entire PX4 startup output from command to crash.
                  voxl2:/$ voxl-px4
                  Found DSP signature file
                  [INFO] Daemon mode enabled
                  GPS=AUTODETECT
                  RC=CRSF_RAW
                  ESC=VOXL_ESC
                  POWER MANAGER=VOXLPM
                  DISTANCE SENSOR=NONE
                  OSD=DISABLE
                  DAEMON_MODE=ENABLE
                  SENSOR_CAL=ACTUAL
                  EXTRA STEPS:
                  INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
                  INFO [px4] assuming working directory is rootfs, no symlinks needed.
                  INFO [muorb] Got muorb init command
                  INFO [muorb] SLPI: muorb aggregator thread running
                  INFO [muorb] muorb protobuf initalize method succeeded
                  INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
                  INFO [muorb] SLPI: Creating pthread test_MUORB
                  INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                  INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
                  INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                  INFO [muorb] succesfully did TOPIC_TEST_TYPE
                  INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                  INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
                  INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                  INFO [muorb] muorb test passed
                  | ___ \ \ \ / / / |
                  | |/ / \ V / / /| |
                  | __/ / \ / /
                  | | / /^\ \ ___ |
                  _| / / |_/
                  px4 starting.
                  INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
                  INFO [muorb] SLPI: Advertising remote topic log_message
                  INFO [parameters] Starting param sync THREAD
                  INFO [muorb] SLPI: Starting param sync THREAD
                  GPS: AUTODETECT
                  RC: CRSF_RAW
                  ESC: VOXL_ESC
                  POWER MANAGER: VOXLPM
                  DISTANCE SENSOR: NONE
                  OSD: DISABLE
                  EXTRA STEPS:
                  Running on M0054
                  INFO [muorb] SLPI: before starting the qshell_entry task
                  INFO [muorb] SLPI: Creating pthread qshell
                  INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                  INFO [muorb] SLPI: qshell entry.....
                  INFO [muorb] SLPI: after starting the qshell_entry task
                  INFO [muorb] SLPI: Init app map initialized
                  INFO [param] selected parameter default file /data/px4/param/parameters
                  INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                  INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
                  INFO [muorb] SLPI: Advertising remote topic parameter_update
                  INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                  INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
                  INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                  INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
                  INFO [parameters] BSON document size 1509 bytes, decoded 1509 bytes (INT32:29, FLOAT:41)
                  INFO [logger] logger started (mode=all)
                  INFO [qshell] Send cmd: 'icm42688p start -s'
                  INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
                  INFO [muorb] SLPI: qshell gotten: icm42688p start -s
                  INFO [muorb] SLPI: arg0 = 'icm42688p'
                  INFO [muorb] SLPI: arg1 = 'start'
                  INFO [muorb] SLPI: arg2 = '-s'
                  INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                  INFO [uORB] Advertising remote topic sensor_accel
                  INFO [uORB] Advertising remote topic sensor_gyro
                  INFO [muorb] SLPI: ICM42688P::probe successful!
                  INFO [muorb] SLPI: on SPI bus 1
                  INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
                  INFO [muorb] SLPI:
                  INFO [muorb] SLPI: >>> ICM42688P this: 3176c8a0
                  INFO [muorb] SLPI: Ok executing command: icm42688p start -s
                  INFO [uORB] Advertising remote topic qshell_retval
                  INFO [qshell] qshell return value timestamp: 380545341, local time: 380552974
                  INFO [muorb] SLPI: Register interrupt b21d3364 e6201b9c 3176c8a0
                  INFO [uORB] Advertising remote topic sensor_gyro_fifo
                  INFO [uORB] Advertising remote topic sensor_accel_fifo
                  INFO [uORB] Advertising remote topic imu_server
                  INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
                  INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                  INFO [muorb] SLPI: arg0 = 'icp101xx'
                  INFO [muorb] SLPI: arg2 = '-I'
                  INFO [muorb] SLPI: arg3 = '-b'
                  INFO [muorb] SLPI: arg4 = '5'
                  INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                  INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
                  INFO [muorb] SLPI: address 0x63
                  INFO [muorb] SLPI:
                  INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                  INFO [qshell] qshell return value timestamp: 380601909, local time: 380603599
                  INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
                  INFO [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
                  INFO [muorb] SLPI: arg0 = 'qmc5883l'
                  INFO [muorb] SLPI: arg2 = '-R'
                  INFO [muorb] SLPI: arg3 = '10'
                  INFO [muorb] SLPI: arg4 = '-X'
                  INFO [muorb] SLPI: arg5 = '-b'
                  INFO [muorb] SLPI: arg6 = '1'
                  INFO [muorb] SLPI: *** I2C Device ID 0x80d09 527625
                  ERROR [muorb] SLPI: i2c probe failed
                  INFO [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
                  ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
                  INFO [qshell] cmd returned with: -1
                  INFO [qshell] qshell return value timestamp: 380665246, local time: 380666868
                  INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                  INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                  INFO [muorb] SLPI: arg0 = 'ist8310'
                  INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                  ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1
                  INFO [qshell] qshell return value timestamp: 380701724, local time: 380702898
                  INFO [qshell] Send cmd: 'gps start'
                  INFO [muorb] SLPI: qshell gotten: gps start
                  INFO [muorb] SLPI: arg0 = 'gps'
                  INFO [muorb] SLPI: Creating pthread gps
                  INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
                  INFO [muorb] SLPI: Ok executing command: gps start
                  INFO [qshell] qshell return value timestamp: 380731993, local time: 380733860
                  Looking for ncp5623c RGB LED
                  INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                  INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                  INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
                  INFO [muorb] SLPI: arg2 = '-X'
                  INFO [muorb] SLPI: arg4 = '1'
                  INFO [muorb] SLPI: arg5 = '-f'
                  INFO [muorb] SLPI: arg6 = '400'
                  INFO [muorb] SLPI: arg7 = '-a'
                  INFO [muorb] SLPI: arg8 = '56'
                  INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                  INFO [muorb] SLPI: Set i2c address 0x38, fd 3
                  ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                  INFO [qshell] qshell return value timestamp: 380774191, local time: 380776550
                  Starting VOXL ESC driver
                  INFO [uORB] Advertising remote topic sensor_baro
                  INFO [qshell] Send cmd: 'voxl_esc start'
                  INFO [muorb] SLPI: qshell gotten: voxl_esc start
                  INFO [muorb] SLPI: arg0 = 'voxl_esc'
                  INFO [uORB] Advertising remote topic actuator_outputs
                  INFO [muorb] SLPI: Ok executing command: voxl_esc start
                  INFO [muorb] SLPI: Opened UART ESC device
                  INFO [qshell] qshell return value timestamp: 380907621, local time: 380909607
                  Starting CRSF RC driver
                  INFO [uORB] Advertising remote topic esc_status
                  INFO [qshell] Send cmd: 'crsf_rc start -d 7'
                  INFO [muorb] SLPI: qshell gotten: crsf_rc start -d 7
                  INFO [muorb] SLPI: arg0 = 'crsf_rc'
                  INFO [muorb] SLPI: arg2 = '-d'
                  INFO [muorb] SLPI: arg3 = '7'
                  INFO [muorb] SLPI: Ok executing command: crsf_rc start -d 7
                  INFO [muorb] SLPI: Crsf serial opened sucessfully
                  INFO [muorb] SLPI: Crsf serial is single wire. Telemetry disabled
                  INFO [uORB] Advertising remote topic input_rc
                  INFO [qshell] qshell return value timestamp: 380966325, local time: 380968275
                  INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
                  INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
                  INFO [muorb] SLPI: arg0 = 'voxlpm'
                  INFO [muorb] SLPI: arg4 = '2'
                  INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
                  INFO [muorb] SLPI: baudrate set to 9600
                  INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
                  INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
                  INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
                  INFO [muorb] SLPI: Set i2c address 0x6a, fd 4
                  terminate called after throwing an instance of 'qmi_error'
                  what(): qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi error (-16)
                  /usr/bin/voxl-px4: line 147: 5263 Aborted GPS=$GPS RC=$RC ESC=$ESC POWER_MANAGER=$POWER_MANAGER DISTANCE_SENSOR=$DISTANCE_SENSOR OSD=$OSD EXTRA_STEPS=$EXTRA_STEPS px4 $DAEMON -s /usr/bin/voxl-px4-start
                  voxl2:/$ ERROR [px4] PX4 server not running
                  • Jeremy FrederickJ Jeremy Frederick
                    @Alex-Kushleyev
                    voxl2:/$ voxl-px4
                    GPS=AUTODETECT
                    RC=CRSF_RAW
                    ESC=VOXL_ESC
                    OSD=DISABLE
                    DAEMON_MODE=ENABLE
                    SENSOR_CAL=ACTUAL
                    EXTRA STEPS:
                    | ___ \ \ \ / / / |
                    | |/ / \ V / / /| |
                    | __/ / \ / /
                    | | / /^\ \ ___ |
                    _| / / |_/
                    px4 starting.
                    GPS: AUTODETECT
                    RC: CRSF_RAW
                    ESC: VOXL_ESC
                    OSD: DISABLE
                    EXTRA STEPS:
                    Running on M0054
                    INFO [muorb] SLPI:
                    INFO [muorb] SLPI:
                    #9
                    @Jeremy-Frederick , can you please disable gps driver and try again? Also, a different test, unplug gps receiver (while gps driver is still enabled) if you have one.
                    Finally, please confirm which SDK version you are using. Thanks!
                      Jeremy Frederick
                      @Alex-Kushleyev Circling back to this as bandwidth opens up again, the board shipped with 1.1.3 but we downgraded to 1.1.2 for consistency across our fleet. After disabling the GPS driver, here is the read out. Once it begins to repeat the standard error event 2, it continues to do so until commanded to cancel.
                      voxl2:/$ voxl-px4
                      GPS=NONE
                      RC=SPEKTRUM
                      ESC=VOXL_ESC
                      OSD=DISABLE
                      DAEMON_MODE=ENABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA STEPS:
                      | ___ \ \ \ / / / |
                      | |/ / \ V / / /| |
                      | __/ / \ / /
                      | | / /^\ \ ___ |
                      _| / / |_/
                      px4 starting.
                      GPS: NONE
                      RC: SPEKTRUM
                      ESC: VOXL_ESC
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      INFO [parameters] BSON document size 2516 bytes, decoded 2516 bytes (INT32:32, FLOAT:84)
                      INFO [muorb] SLPI:
                      INFO [muorb] SLPI: >>> ICM42688P this: 3176e890
                      INFO [qshell] qshell return value timestamp: 769109146, local time: 769112405
                      INFO [muorb] SLPI: Register interrupt b21d31a4 e6201b9c 3176e890
                      INFO [muorb] SLPI:
                      INFO [qshell] qshell return value timestamp: 769151747, local time: 769152453
                      INFO [qshell] qshell return value timestamp: 769197191, local time: 769199300
                      INFO [qshell] qshell return value timestamp: 769243333, local time: 769245843
                      INFO [qshell] qshell return value timestamp: 769289461, local time: 769290797
                      INFO [qshell] qshell return value timestamp: 769402896, local time: 769405483
                      Starting Spektrum RC
                      INFO [uORB] Advertising remote topic actuator_outputs_debug
                      INFO [qshell] Send cmd: 'spektrum_rc start'
                      INFO [muorb] SLPI: qshell gotten: spektrum_rc start
                      INFO [muorb] SLPI: arg0 = 'spektrum_rc'
                      INFO [muorb] SLPI: Creating pthread spektrum_rc_main
                      INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
                      INFO [muorb] SLPI: Ok executing command: spektrum_rc start
                      INFO [qshell] qshell return value timestamp: 769460341, local time: 769462971
                      INFO [qshell] Send cmd: 'sensors start'
                      INFO [qshell] Send cmd: 'ekf2 start'
                      INFO [qshell] Send cmd: 'mc_pos_control start'
                      INFO [qshell] Send cmd: 'mc_att_control start'
                      Received standard error event INFO [qshell] Send cmd: 'mc_rate_control start'
                      INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
                      INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
                      INFO [qshell] Send cmd: 'land_detector start multicopter'
                      INFO [qshell] Send cmd: 'manual_control start'
                      INFO [qshell] Send cmd: 'control_allocator start'
                        voxl2:/$ voxl-px4
                        GPS=NONE
                        RC=SPEKTRUM
                        ESC=VOXL_ESC
                        OSD=DISABLE
                        DAEMON_MODE=ENABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA STEPS:
                        | ___ \ \ \ / / / |
                        | |/ / \ V / / /| |
                        | __/ / \ / /
                        | | / /^\ \ ___ |
                        _| / / |_/
                        px4 starting.
                        GPS: NONE
                        RC: SPEKTRUM
                        ESC: VOXL_ESC
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO [muorb] SLPI:
                        INFO [muorb] SLPI:
                        Jeremy Frederick
                        @Jeremy-Frederick More Info: I've upgraded to SDK 1.2 and am having the same issue. It seems like the mavlink pipe is having trouble connecting as well, whenever I attempt to read the onboard mavlink messages, with voxl-inspect-mavlink, it indefinitely waits for the pipe to connect.
                          @Jeremy-Frederick It looks like the SLPI DSP is crashing. Can you look at the dmesg log? It probably indicates that the SLPI DSP has crashed.
                            @Jeremy-Frederick Can you also try setting POWER_MANAGER to NONE in /etc/modalai/voxl-px4.conf and see if that changes anything?
                              Jeremy Frederick
                              @Eric-Katzfey That seems to have solved the issue, now were able to establish a connection to QGC. Any idea why that would cause an issue?
                                @Jeremy-Frederick I'm guessing that the black 4 wire cable between the VOXL 2 and the APM may have some issues making an occasional problem for the i2c bus. Do you have another one of those cables to swap with?
