  3. voxl-px4 service pipeline uORB failure
voxl-2
15 Posts 6 Posters 2.7k Views 3 Watching
    @jacob-yaacubov , can you please stop and disable voxl-px4 service:
    systemctl stop voxl-px4
    systemctl disable voxl-px4
    then reboot voxl2, and start px4 manually in foreground:
    voxl-px4 -d
    Then save the output (from the terminal) into a text file and share with us?
    S Offline
    S Offline
    swickliff
    @Alex-Kushleyev It looks like I am having the same issue as Jacob. We've added a brand new Voxl2 to our drone, this one is running on SDK 1.1.3 and we cannot get it to connect to PX4. Our prior build used Voxl2s with SDK 1.1.2 and worked fine for us, so we tried downgrading the SDK but that did not work either.
    We re-updated the SDK to 1.1.3 and I stopped and disabled voxl-px4 service and rebooted the Voxl2 and started px4 manually. Want me to share a text file with the output?
    tomT Alex KushleyevA 2 Replies Last reply
    • S swickliff
      @swickliff If you believe that the file system is corrupted you can reflash the latest SDK release using the -w arg, ./install.sh -w
      This will wipe all partitions, ensuring your board is in a factory state
      • S swickliff
        @swickliff , please share the output of px4 starting manually and also try to do a full wipe as Tom suggested and see if that helps. Thanks!
        Jeremy FrederickJ 1 Reply Last reply
          Jeremy FrederickJ Offline
          Jeremy Frederick
          Alex, picking up this thread where swickliff left off. We tried a full partion wipe and are still having issues. Attached to this post is a .txt file with the entire PX4 startup output from command to crash.
          voxl2:/$ voxl-px4
          Found DSP signature file
          [INFO] Daemon mode enabled
          GPS=AUTODETECT
          RC=CRSF_RAW
          ESC=VOXL_ESC
          POWER MANAGER=VOXLPM
          DISTANCE SENSOR=NONE
          OSD=DISABLE
          DAEMON_MODE=ENABLE
          SENSOR_CAL=ACTUAL
          EXTRA STEPS:
          INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
          INFO [px4] assuming working directory is rootfs, no symlinks needed.
          INFO [muorb] Got muorb init command
          INFO [muorb] SLPI: muorb aggregator thread running
          INFO [muorb] muorb protobuf initalize method succeeded
          INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
          INFO [muorb] SLPI: Creating pthread test_MUORB
          INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
          INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
          INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
          INFO [muorb] succesfully did TOPIC_TEST_TYPE
          INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
          INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
          INFO [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
          INFO [muorb] muorb test passed
          | ___ \ \ \ / / / |
          | |/ / \ V / / /| |
          | __/ / \ / /
          | | / /^\ \ ___ |
          _| / / |_/
          px4 starting.
          INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
          INFO [muorb] SLPI: Advertising remote topic log_message
          INFO [parameters] Starting param sync THREAD
          INFO [muorb] SLPI: Starting param sync THREAD
          GPS: AUTODETECT
          RC: CRSF_RAW
          ESC: VOXL_ESC
          POWER MANAGER: VOXLPM
          DISTANCE SENSOR: NONE
          OSD: DISABLE
          EXTRA STEPS:
          Running on M0054
          INFO [muorb] SLPI: before starting the qshell_entry task
          INFO [muorb] SLPI: Creating pthread qshell
          INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
          INFO [muorb] SLPI: qshell entry.....
          INFO [muorb] SLPI: after starting the qshell_entry task
          INFO [muorb] SLPI: Init app map initialized
          INFO [param] selected parameter default file /data/px4/param/parameters
          INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
          INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
          INFO [muorb] SLPI: Advertising remote topic parameter_update
          INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
          INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
          INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
          INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
          INFO [parameters] BSON document size 1509 bytes, decoded 1509 bytes (INT32:29, FLOAT:41)
          INFO [logger] logger started (mode=all)
          INFO [qshell] Send cmd: 'icm42688p start -s'
          INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
          INFO [muorb] SLPI: qshell gotten: icm42688p start -s
          INFO [muorb] SLPI: arg0 = 'icm42688p'
          INFO [muorb] SLPI: arg1 = 'start'
          INFO [muorb] SLPI: arg2 = '-s'
          INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
          INFO [uORB] Advertising remote topic sensor_accel
          INFO [uORB] Advertising remote topic sensor_gyro
          INFO [muorb] SLPI: ICM42688P::probe successful!
          INFO [muorb] SLPI: on SPI bus 1
          INFO [muorb] SLPI: icm42688p #0 on SPI bus 1
          INFO [muorb] SLPI:
          INFO [muorb] SLPI: >>> ICM42688P this: 3176c8a0
          INFO [muorb] SLPI: Ok executing command: icm42688p start -s
          INFO [uORB] Advertising remote topic qshell_retval
          INFO [qshell] qshell return value timestamp: 380545341, local time: 380552974
          INFO [muorb] SLPI: Register interrupt b21d3364 e6201b9c 3176c8a0
          INFO [uORB] Advertising remote topic sensor_gyro_fifo
          INFO [uORB] Advertising remote topic sensor_accel_fifo
          INFO [uORB] Advertising remote topic imu_server
          INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
          INFO [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
          INFO [muorb] SLPI: arg0 = 'icp101xx'
          INFO [muorb] SLPI: arg2 = '-I'
          INFO [muorb] SLPI: arg3 = '-b'
          INFO [muorb] SLPI: arg4 = '5'
          INFO [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
          INFO [muorb] SLPI: icp101xx #0 on I2C bus 5
          INFO [muorb] SLPI: address 0x63
          INFO [muorb] SLPI:
          INFO [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
          INFO [qshell] qshell return value timestamp: 380601909, local time: 380603599
          INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
          INFO [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
          INFO [muorb] SLPI: arg0 = 'qmc5883l'
          INFO [muorb] SLPI: arg2 = '-R'
          INFO [muorb] SLPI: arg3 = '10'
          INFO [muorb] SLPI: arg4 = '-X'
          INFO [muorb] SLPI: arg5 = '-b'
          INFO [muorb] SLPI: arg6 = '1'
          INFO [muorb] SLPI: *** I2C Device ID 0x80d09 527625
          INFO [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
          INFO [qshell] cmd returned with: -1
          INFO [qshell] qshell return value timestamp: 380665246, local time: 380666868
          ERROR [qshell] Command failed
          INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
          INFO [muorb] SLPI: arg0 = 'ist8310'
          INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
          ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1
          INFO [qshell] qshell return value timestamp: 380701724, local time: 380702898
          INFO [qshell] Send cmd: 'gps start'
          INFO [muorb] SLPI: qshell gotten: gps start
          INFO [muorb] SLPI: arg0 = 'gps'
          INFO [muorb] SLPI: Creating pthread gps
          INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
          INFO [muorb] SLPI: Ok executing command: gps start
          INFO [qshell] qshell return value timestamp: 380731993, local time: 380733860
          Looking for ncp5623c RGB LED
          INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
          INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
          INFO [muorb] SLPI: arg0 = 'rgbled_ncp5623c'
          INFO [muorb] SLPI: arg2 = '-X'
          INFO [muorb] SLPI: arg4 = '1'
          INFO [muorb] SLPI: arg5 = '-f'
          INFO [muorb] SLPI: arg6 = '400'
          INFO [muorb] SLPI: arg7 = '-a'
          INFO [muorb] SLPI: arg8 = '56'
          INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
          INFO [muorb] SLPI: Set i2c address 0x38, fd 3
          ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
          INFO [qshell] qshell return value timestamp: 380774191, local time: 380776550
          Starting VOXL ESC driver
          INFO [uORB] Advertising remote topic sensor_baro
          INFO [qshell] Send cmd: 'voxl_esc start'
          INFO [muorb] SLPI: qshell gotten: voxl_esc start
          INFO [muorb] SLPI: arg0 = 'voxl_esc'
          INFO [uORB] Advertising remote topic actuator_outputs
          INFO [muorb] SLPI: Ok executing command: voxl_esc start
          INFO [muorb] SLPI: Opened UART ESC device
          INFO [qshell] qshell return value timestamp: 380907621, local time: 380909607
          Starting CRSF RC driver
          INFO [uORB] Advertising remote topic esc_status
          INFO [qshell] Send cmd: 'crsf_rc start -d 7'
          INFO [muorb] SLPI: qshell gotten: crsf_rc start -d 7
          INFO [muorb] SLPI: arg0 = 'crsf_rc'
          INFO [muorb] SLPI: arg2 = '-d'
          INFO [muorb] SLPI: arg3 = '7'
          INFO [muorb] SLPI: Ok executing command: crsf_rc start -d 7
          INFO [muorb] SLPI: Crsf serial opened sucessfully
          INFO [muorb] SLPI: Crsf serial is single wire. Telemetry disabled
          INFO [uORB] Advertising remote topic input_rc
          INFO [qshell] qshell return value timestamp: 380966325, local time: 380968275
          INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
          INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
          INFO [muorb] SLPI: arg0 = 'voxlpm'
          INFO [muorb] SLPI: arg4 = '2'
          INFO [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
          INFO [muorb] SLPI: baudrate set to 9600
          INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 1
          INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 2
          INFO [muorb] SLPI: Sending initial CFG_VALSET. Attempt: 3
          INFO [muorb] SLPI: Set i2c address 0x6a, fd 4
          terminate called after throwing an instance of 'qmi_error'
          what(): qmi_client_send_msg_sync() failed, (client_id=)0, result=0: qmi error (-16)
          /usr/bin/voxl-px4: line 147: 5263 Aborted GPS=$GPS RC=$RC ESC=$ESC POWER_MANAGER=$POWER_MANAGER DISTANCE_SENSOR=$DISTANCE_SENSOR OSD=$OSD EXTRA_STEPS=$EXTRA_STEPS px4 $DAEMON -s /usr/bin/voxl-px4-start
          voxl2:/$ ERROR [px4] PX4 server not running
          • Jeremy FrederickJ Jeremy Frederick
            voxl2:/$ voxl-px4
            GPS=AUTODETECT
            RC=CRSF_RAW
            ESC=VOXL_ESC
            OSD=DISABLE
            DAEMON_MODE=ENABLE
            SENSOR_CAL=ACTUAL
            EXTRA STEPS:
            | ___ \ \ \ / / / |
            | |/ / \ V / / /| |
            | __/ / \ / /
            | | / /^\ \ ___ |
            _| / / |_/
            px4 starting.
            GPS: AUTODETECT
            RC: CRSF_RAW
            ESC: VOXL_ESC
            OSD: DISABLE
            EXTRA STEPS:
            Running on M0054
            INFO [muorb] SLPI:
            INFO [muorb] SLPI:
            #9
            @Jeremy-Frederick , can you please disable gps driver and try again? Also, a different test, unplug gps receiver (while gps driver is still enabled) if you have one.
            Finally, please confirm which SDK version you are using. Thanks!
              Jeremy Frederick
              @Alex-Kushleyev Circling back to this as bandwidth opens up again, the board shipped with 1.1.3 but we downgraded to 1.1.2 for consistency across our fleet. After disabling the GPS driver, here is the read out. Once it begins to repeat the standard error event 2, it continues to do so until commanded to cancel.
              voxl2:/$ voxl-px4
              GPS=NONE
              RC=SPEKTRUM
              ESC=VOXL_ESC
              OSD=DISABLE
              DAEMON_MODE=ENABLE
              SENSOR_CAL=ACTUAL
              EXTRA STEPS:
              | ___ \ \ \ / / / |
              | |/ / \ V / / /| |
              | __/ / \ / /
              | | / /^\ \ ___ |
              _| / / |_/
              px4 starting.
              GPS: NONE
              RC: SPEKTRUM
              ESC: VOXL_ESC
              OSD: DISABLE
              EXTRA STEPS:
              Running on M0054
              INFO [parameters] BSON document size 2516 bytes, decoded 2516 bytes (INT32:32, FLOAT:84)
              INFO [muorb] SLPI:
              INFO [muorb] SLPI: >>> ICM42688P this: 3176e890
              INFO [qshell] qshell return value timestamp: 769109146, local time: 769112405
              INFO [muorb] SLPI: Register interrupt b21d31a4 e6201b9c 3176e890
              INFO [muorb] SLPI:
              INFO [qshell] qshell return value timestamp: 769151747, local time: 769152453
              INFO [qshell] qshell return value timestamp: 769197191, local time: 769199300
              INFO [qshell] qshell return value timestamp: 769243333, local time: 769245843
              INFO [qshell] qshell return value timestamp: 769289461, local time: 769290797
              INFO [qshell] qshell return value timestamp: 769402896, local time: 769405483
              Starting Spektrum RC
              INFO [uORB] Advertising remote topic actuator_outputs_debug
              INFO [qshell] Send cmd: 'spektrum_rc start'
              INFO [muorb] SLPI: qshell gotten: spektrum_rc start
              INFO [muorb] SLPI: arg0 = 'spektrum_rc'
              INFO [muorb] SLPI: Creating pthread spektrum_rc_main
              INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097644
              INFO [muorb] SLPI: Ok executing command: spektrum_rc start
              INFO [qshell] qshell return value timestamp: 769460341, local time: 769462971
              INFO [qshell] Send cmd: 'sensors start'
              INFO [qshell] Send cmd: 'ekf2 start'
              INFO [qshell] Send cmd: 'mc_pos_control start'
              INFO [qshell] Send cmd: 'mc_att_control start'
              Received standard error event INFO [qshell] Send cmd: 'mc_rate_control start'
              INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
              INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
              INFO [qshell] Send cmd: 'land_detector start multicopter'
              INFO [qshell] Send cmd: 'manual_control start'
              INFO [qshell] Send cmd: 'control_allocator start'
                voxl2:/$ voxl-px4
                GPS=NONE
                RC=SPEKTRUM
                ESC=VOXL_ESC
                OSD=DISABLE
                DAEMON_MODE=ENABLE
                SENSOR_CAL=ACTUAL
                EXTRA STEPS:
                | ___ \ \ \ / / / |
                | |/ / \ V / / /| |
                | __/ / \ / /
                | | / /^\ \ ___ |
                _| / / |_/
                px4 starting.
                GPS: NONE
                RC: SPEKTRUM
                ESC: VOXL_ESC
                OSD: DISABLE
                EXTRA STEPS:
                Running on M0054
                INFO [muorb] SLPI:
                INFO [muorb] SLPI:
                Jeremy Frederick
                @Jeremy-Frederick More Info: I've upgraded to SDK 1.2 and am having the same issue. It seems like the mavlink pipe is having trouble connecting as well, whenever I attempt to read the onboard mavlink messages, with voxl-inspect-mavlink, it indefinitely waits for the pipe to connect.
                  @Jeremy-Frederick It looks like the SLPI DSP is crashing. Can you look at the dmesg log? It probably indicates that the SLPI DSP has crashed.
                    @Jeremy-Frederick Can you also try setting POWER_MANAGER to NONE in /etc/modalai/voxl-px4.conf and see if that changes anything?
                      Jeremy Frederick
                      @Eric-Katzfey That seems to have solved the issue, now were able to establish a connection to QGC. Any idea why that would cause an issue?
                        @Jeremy-Frederick I'm guessing that the black 4 wire cable between the VOXL 2 and the APM may have some issues making an occasional problem for the i2c bus. Do you have another one of those cables to swap with?
