  3. voxl-configure-mpa failled on voxl-esc step
12 Posts 5 Posters 2.7k Views 3 Watching
  • Cai BillC Offline
    Cai BillC Offline
    Cai Bill
    I was trying to get the drone flying again, so I tried the voxl-configure-mpa to reset all service. But It failed on voxl-esc setup_sentinel_v. Should I be worried? How should I fix this problem.
    Log shown bellow:
    executing: voxl-esc setup_sentinel_v1
    enabling bridge
    detected voxl-px4 is enabled
    Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
    detected voxl-px4 is running, stopping it now
    bridge enabled
    [INFO] Scanning for ESC...
    Error calling voxl_uart_init
    [ERROR] Unknown board detected:
    disabling bridge
    re-enabling voxl-px4
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
    restarting voxl-px4
    bridge disabled
    EXITING VOXL-ESC WITH ERROR
    FAILED TO EXECUTE: voxl-esc setup_sentinel_v1
    executing: voxl-configure-px4 sentinel_v1
    wiping old config file
    enabling  voxl-px4 systemd service
    Done configuring voxl-px4
    Success!
    executing: voxl-configure-px4-params -np MRB-D0006
    [INFO] Voxl-px4 service found and active.
    [INFO] Loading the following param files: platforms/Sentinel_V1.params, EKF2_helpers/outdoor_gps_baro.params.
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Sentinel_V1.params
    [INFO] Scanning currently loaded parameters...
    [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/outdoor_gps_baro.params
    [INFO] Loading file: /data/px4/param/parameters_gyro.cal
    [INFO] Trimming duplicate parameters...
    [INFO] Loading file: /data/px4/param/parameters_acc.cal
    [INFO] Loading file: /data/px4/param/parameters_level.cal
    [INFO] Loading file: /data/px4/param/parameters_rc.cal
    [INFO] Done configuring for platform MRB-D0006
    Success!
    checking /data/modalai/voxl-imu-server.cal
    checking /data/px4/param/parameters_mag.cal
             FAILED TO EXECUTE the following steps:
          Encountered Problems Configuring MPA Services :-/
            Some Services may not start up on next reboot
    Calibration File Status:
    Missing /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_intrinsics.yml
    Present /data/modalai/opencv_stereo_front_intrinsics.yml
    Present /data/modalai/opencv_stereo_front_extrinsics.yml
    Present /data/modalai/opencv_stereo_rear_intrinsics.yml
    Present /data/modalai/opencv_stereo_rear_extrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Missing /data/px4/param/parameters_mag.cal
    Present /data/px4/param/parameters_level.cal
    Detected Missing Calibration Files
    please run the required cals
    https://docs.modalai.com/calibration/
                    PLEASE POWER CYCLE YOUR VOXL
    • Cai BillC Cai Bill
      Log shown bellow:
      enabling bridge
      bridge enabled
      disabling bridge
      restarting voxl-px4
      bridge disabled
      Success!
      Success!
      @Cai-Bill If you run voxl-esc setup_sentinel_v1 manually does it still fail?
      Cai BillC 1 Reply Last reply
        Cai BillC Offline
        Cai BillC Offline
        Cai Bill
        @tom Yes, It still fail:
        Here is the log:
        $voxl-esc setup_sentinel_v1
        enabling bridge
        bridge enabled
        disabling bridge
        restarting voxl-px4
        bridge disabled
          Here is the log:
          enabling bridge
          bridge enabled
          disabling bridge
          restarting voxl-px4
          bridge disabled
          @Cai-Bill I would inspect the ESC wiring, both power and data to voxl2. When power is given to the drone do the LEDs on the ESC light up? Does it make any noise?
          Cai BillC 2 Replies Last reply
            Cai BillC Offline
            Cai BillC Offline
            Cai Bill
            @tom
            When I power on the drone, the ESC does light up blue and flash for a bit, then it turned off. The drone makes boot on noise. I check the wiring, all joint are connected to the broad.
            • Cai BillC Offline
              Cai BillC Offline
              Cai Bill
              voxl2:~$ px4-qshell modalai_esc
              INFO  [qshell] Send cmd: 'modalai_esc'
              ERROR [uORB] Error Sending [qshell_req] topic data over comm_channel
              ERROR [qshell] command timed out
              ERROR [qshell] Command failed
              voxl2:~$ px4-listener esc_status
              never published
              I also tried px4-qshell modalai_esc and px4-listener esc_status, Both of them failed
                Cai BillC Offline
                Cai BillC Offline
                Cai Bill
                @tom Hi Tom,
                I'm still unable to figure out what happen to the ESC, I can only suspected the firmware or the wiring. Do you guys offer mailed in repair?
                  @tom Hi Tom,
                  @Cai-Bill We do: https://www.modalai.com/pages/rma
                  but I suspect it is a wiring / cable issue given the ESC is lighting up and the motors are chiming as expected
                  • Erik PriestE Erik Priest referenced this topic on
                  • S Offline
                    S Offline
                    smilon
                    Any updates on this @Cai-Bill ? Was it a hardware-related issue? I am facing something similar.
                    • S smilon
                      @smilon Hello, if you are seeing the following error: Error calling voxl_uart_init , then there is some mismatch between the voxl-esc tools and libvoxl_io library or a similar issue.
                      Please update to the latest SDK 1.1.1 to get everything in sync.
                      Thank you
                        Thank you
                        Eric KatzfeyE Online
                        @Alex-Kushleyev I agree, seems like a version mismatch. The newest SDK 1.1.2 was just released yesterday so we recommend you load that and try again.
                        • S Offline
                          S Offline
                          smilon
                          wrote on last edited by smilon
                          #12
                          @Alex-Kushleyev @Eric-Katzfey Thank you for clearing this up. I am trying to install SDK 1.1.2 but my host machine can't discover the VOXL2 as a fastboot device (I have made an issue here). I would appreciate if you have any recommendations to hop on there as it is an urgent issue.
