    voxl-configure-mpa failled on voxl-esc step
    869
    • Cai BillC
      Cai Bill
      I was trying to get the drone flying again, so I tried the voxl-configure-mpa to reset all service. But It failed on voxl-esc setup_sentinel_v. Should I be worried? How should I fix this problem.
      Log shown bellow:
      executing: voxl-esc setup_sentinel_v1
      enabling bridge
      detected voxl-px4 is enabled
      Removed /etc/systemd/system/multi-user.target.wants/voxl-px4.service.
      detected voxl-px4 is running, stopping it now
      bridge enabled
      [INFO] Scanning for ESC...
      Couldn't configure flight_controller sensor
      Error calling voxl_uart_init
      [ERROR] Unknown board detected:
      disabling bridge
      re-enabling voxl-px4
      Created symlink /etc/systemd/system/multi-user.target.wants/voxl-px4.service → /etc/systemd/system/voxl-px4.service.
      restarting voxl-px4
      bridge disabled
      EXITING VOXL-ESC WITH ERROR
      FAILED TO EXECUTE: voxl-esc setup_sentinel_v1
      executing: voxl-configure-px4 sentinel_v1
      wiping old config file
      enabling  voxl-px4 systemd service
      Done configuring voxl-px4
      Success!
      executing: voxl-configure-px4-params -np MRB-D0006
      [INFO] Voxl-px4 service found and active.
      [INFO] Loading the following param files: platforms/Sentinel_V1.params, EKF2_helpers/outdoor_gps_baro.params.
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/platforms/Sentinel_V1.params
      [INFO] Scanning currently loaded parameters...
      [INFO] Loading file: /usr/share/modalai/px4_params/v1.14/EKF2_helpers/outdoor_gps_baro.params
      [INFO] Loading file: /data/px4/param/parameters_gyro.cal
      [INFO] Trimming duplicate parameters...
      [INFO] Loading file: /data/px4/param/parameters_acc.cal
      [INFO] Loading file: /data/px4/param/parameters_level.cal
      [INFO] Loading file: /data/px4/param/parameters_rc.cal
      [INFO] Done configuring for platform MRB-D0006
      Success!
      checking /data/modalai/voxl-imu-server.cal
      checking /data/px4/param/parameters_mag.cal
               FAILED TO EXECUTE the following steps:
            Encountered Problems Configuring MPA Services :-/
              Some Services may not start up on next reboot
      Calibration File Status:
      Missing /data/modalai/voxl-imu-server.cal
      Present /data/modalai/opencv_tracking_intrinsics.yml
      Present /data/modalai/opencv_stereo_front_intrinsics.yml
      Present /data/modalai/opencv_stereo_front_extrinsics.yml
      Present /data/modalai/opencv_stereo_rear_intrinsics.yml
      Present /data/modalai/opencv_stereo_rear_extrinsics.yml
      Present /data/px4/param/parameters_gyro.cal
      Present /data/px4/param/parameters_acc.cal
      Missing /data/px4/param/parameters_mag.cal
      Present /data/px4/param/parameters_level.cal
      Detected Missing Calibration Files
      please run the required cals
      https://docs.modalai.com/calibration/
                      PLEASE POWER CYCLE YOUR VOXL
        tom admin @Cai Bill
        @Cai-Bill If you run voxl-esc setup_sentinel_v1 manually does it still fail?
        Cai BillC 1 Reply Last reply Reply Quote 0
        • Cai BillC
          Cai Bill @tom
          @tom Yes, It still fail:
          Here is the log:
          $voxl-esc setup_sentinel_v1
          enabling bridge
          bridge enabled
          disabling bridge
          restarting voxl-px4
          bridge disabled
            tom admin @Cai Bill
            @Cai-Bill I would inspect the ESC wiring, both power and data to voxl2. When power is given to the drone do the LEDs on the ESC light up? Does it make any noise?
            Cai BillC 2 Replies Last reply Reply Quote 0
            • Cai BillC
              Cai Bill @tom
              When I power on the drone, the ESC does light up blue and flash for a bit, then it turned off. The drone makes boot on noise. I check the wiring, all joint are connected to the broad.
              • Cai BillC
                Cai Bill
                voxl2:~$ px4-qshell modalai_esc
                INFO  [qshell] Send cmd: 'modalai_esc'
                ERROR [uORB] Error Sending [qshell_req] topic data over comm_channel
                ERROR [qshell] Command failed
                voxl2:~$ px4-listener esc_status
                never published
                I also tried px4-qshell modalai_esc and px4-listener esc_status, Both of them failed
                • Cai BillC
                  Cai Bill @tom
                  @tom Hi Tom,
                  I'm still unable to figure out what happen to the ESC, I can only suspected the firmware or the wiring. Do you guys offer mailed in repair?
                    tom admin @Cai Bill
                    @Cai-Bill We do: https://www.modalai.com/pages/rma
                    but I suspect it is a wiring / cable issue given the ESC is lighting up and the motors are chiming as expected
                    • Erik PriestE Erik Priest referenced this topic on
                    • S
                      smilon
                      Any updates on this @Cai-Bill ? Was it a hardware-related issue? I am facing something similar.
                        Alex Kushleyev ModalAI Team @smilon
                        @smilon Hello, if you are seeing the following error: Error calling voxl_uart_init , then there is some mismatch between the voxl-esc tools and libvoxl_io library or a similar issue.
                        Please update to the latest SDK 1.1.1 to get everything in sync.
                        Thank you
                          Eric Katzfey ModalAI Team @Alex Kushleyev
                          @Alex-Kushleyev I agree, seems like a version mismatch. The newest SDK 1.1.2 was just released yesterday so we recommend you load that and try again.
                          • S
                            smilon
                            @Alex-Kushleyev @Eric-Katzfey Thank you for clearing this up. I am trying to install SDK 1.1.2 but my host machine can't discover the VOXL2 as a fastboot device (I have made an issue here). I would appreciate if you have any recommendations to hop on there as it is an urgent issue.
