  3. Sony RXO over USB
Sony RXO over USB
microhard
37 Posts 7 Posters 12.7k Views 5 Watching
  • Matt GoddardM Offline
    Matt Goddard
    Trying to stream Sony RXO to QGC over micro USB, Microhard sees it but no stream?
      Hi @Matt-Goddard ,
      I hadn't seen that camera before, pretty slick! I'm looking at this for reference.
      I'm not positive if is supports a UVC interface (e.g. webcam)? If so we can stream off that to QGC. For example, here
      It doesn't show mini-HDMI connector. We have an HDMI input adapter that could be used possibly and then we can stream video off. For example, here
      Matt GoddardM 1 Reply Last reply
      • modaltbM modaltb
        Hi @Matt-Goddard ,
        Matt Goddard
        @modaltb Thanks for the response! So we can get it to trigger, and we have got it to work with Sonys webcam software separately!. It says it is streaming, but we can not receive video like it's sending empty data. Libg Photo 2 is reading the camera and recognizes it, but can't pull the video up in QGC or any other video source. It's just one of those things we have been spending a ton of time on scratching our heads, knowing there is something small we are missing haha! First time using VOXL and Modem..which I must say is absolutely amazing, we want to switch our fleet over to this system.
        • Matt GoddardM Matt Goddard
          Hi @Matt-Goddard, I understand that you are using QGC, are you able to get telemetry through to QGC? If so, are you doing that over WiFi or Microhard?
          It looks like you are successfully getting frames off of the camera, so I'm wondering if there is a networking issue.
            Matt Goddard
            Yes, Tom we are getting full telem using the Microhard through QGC, also have used WiFi. Yes, that was odd to me as well?
              wrote on last edited by tom
              @Matt-Goddard Okay, so I assume you are using voxl-vision-px4 to talk with QGC then. You will want to point voxl-libgphoto2 to the IP address of your ground station on the Microhard network, which would be the same IP address that you are sending voxl-vision-px4 to.
              Right now it seems as though your voxl-libgphoto2 is attempting to send video to QGC over WiFi, when in reality you are connected to QGC over Microhard.
              So, instead of using voxl-libgphoto2 192.168.1.215, you will want to use the same IP address as you are for voxl-vision-px4, which you can find using ifconfig on your ground station or should be in voxl-vision-px4's config file: /etc/modalai/voxl-vision-px4.conf. All Microhard IPs will be in the form 192.168.168.X
                Matt Goddard
                wrote on last edited by Matt Goddard
                @tom This is something we have done already
                • tomT Offline
                  Are you able to open the video stream with a different program like VLC or ffplay?
                    Matt Goddard
                    We have tried VLC with both Linux and Windows, appears to load it with no video stream.
                      Matt Goddard
                      @tom is the VOXL streamer apk required in order to use the gphoto2 to stream video?
                        @Matt-Goddard We have two different implementations for gphoto2 on VOXL. voxl-libgphoto2 which is what you are using and we also have voxl-gphoto2 which is a newer version that also uses voxl-streamer. I think I will have you try voxl-gphoto2 now.
                        Here is the link to the build/install instructions for the newer gphoto2 implementation.
                        Here is a link to the documentation
                        You will need to use this in combination with voxl-streamer and here is some documentation for getting that going.
                          Matt Goddard
                          I will try this now and get back to you. Thanks!
                            Matt Goddard
                            During the process, we managed to brick the board. Will not boot now..
                              @Matt-Goddard We have some documentation on unbricking here
                                Matt Goddard
                                Got it, we will order the part and unbrick lol. Thanks for the help!
                                • Aaron BottkeA Offline
                                  Aaron Bottke
                                  wrote on last edited by Aaron Bottke
                                  #16
                                  The USB and Serial Debug board arrived today. I unbricked the board and installed gphoto2 and VOXL-streamer. The image below is an error I received after running the voxl-gphoto2 command.
                                  Please advise.
                                    Have you tried gphoto2 using a Linux machine to make sure this device is supported?
                                      @Matt-Goddard said in Sony RXO over USB:
                                      Sony RXO
                                      The RX0 II is on the list, is that what you're using?
                                      http://www.gphoto.org/proj/libgphoto2/support.php
                                        Aaron Bottke
                                        #19
                                        Yes we are attempting to use the RX0. The image below shows that gphoto2 does detect it on an ubuntu machine.
                                        • Aaron BottkeA Aaron Bottke
                                          @Aaron-Bottke What happens when you run gphoto2 --capture-preview? Do you get an image?
