  3. Sony RXO over USB
Sony RXO over USB
microhard
37 Posts 7 Posters 12.4k Views 5 Watching
  • Matt GoddardM Offline
    Matt Goddard
    We have tried VLC with both Linux and Windows, appears to load it with no video stream.
      Matt Goddard
      @tom is the VOXL streamer apk required in order to use the gphoto2 to stream video?
      • Matt GoddardM Matt Goddard
        @Matt-Goddard We have two different implementations for gphoto2 on VOXL. voxl-libgphoto2 which is what you are using and we also have voxl-gphoto2 which is a newer version that also uses voxl-streamer. I think I will have you try voxl-gphoto2 now.
        Here is the link to the build/install instructions for the newer gphoto2 implementation.
        Here is a link to the documentation
        You will need to use this in combination with voxl-streamer and here is some documentation for getting that going.
          Matt Goddard
          I will try this now and get back to you. Thanks!
            Matt Goddard
            During the process, we managed to brick the board. Will not boot now..
              @Matt-Goddard We have some documentation on unbricking here
                Matt Goddard
                Got it, we will order the part and unbrick lol. Thanks for the help!
                • Aaron BottkeA Offline
                  Aaron Bottke
                  wrote on last edited by Aaron Bottke
                  #16
                  The USB and Serial Debug board arrived today. I unbricked the board and installed gphoto2 and VOXL-streamer. The image below is an error I received after running the voxl-gphoto2 command.
                  Please advise.
                    Have you tried gphoto2 using a Linux machine to make sure this device is supported?
                      @Matt-Goddard said in Sony RXO over USB:
                      Sony RXO
                      The RX0 II is on the list, is that what you're using?
                      http://www.gphoto.org/proj/libgphoto2/support.php
                        Aaron Bottke
                        #19
                        Yes we are attempting to use the RX0. The image below shows that gphoto2 does detect it on an ubuntu machine.
                        • Aaron BottkeA Aaron Bottke
                          @Aaron-Bottke What happens when you run gphoto2 --capture-preview? Do you get an image?
                            @Aaron-Bottke Also, can you try running voxl-gphoto2 with debugging information enabled and send us the ouput? For example: voxl-gphoto2 -d -v -g
                              Aaron Bottke
                              Results of gphoto2 --capture-preview on my host machine as follows.
                              On the VOXL running voxl-gphoto2 -d -v -g yields way to much for me to share here so I will split it up.
                              voxl-gphoto2 -d below.
                              voxl-gphoto2 -v yields a lot of messages very quickly.
                              Output as follows.
                              voxl-gphoto2 -v yields too many messages for me to upload with a screenshot.
                              I don't see a way to submit a .txt file but the most interesting part of the output that I see is this.
                                Output as follows.
                                @Aaron-Bottke Okay, thanks! That's very helpful information. It looks like the camera is producing images and voxl-gphoto2 is processing them correctly. So try voxl-streamer and see if you can stream the video. That error message seems to be coming from the gphoto2 library but doesn't seem to be hurting anything.
                                  Aaron Bottke
                                  #24
                                  Unless I am missing something in the command this is the result from running voxl-streamer and voxl-gphoto2.
                                  Thanks for all the help.
                                    @Aaron-Bottke Documentation on voxl-streamer is here: https://docs.modalai.com/voxl-streamer/
                                    For gphoto2 you will want to look at the gphoto2-mpa configuration in /etc/modalai/voxl-streamer.conf. You can use this configuration record by launching with voxl-streamer -c gphoto2-mpa
                                      Aaron Bottke
                                      That got it working!!! I really appreciate the help with this!!!
                                      My telemetry quit working though so I have to play with that and get that up and running again.
                                        Aaron Bottke
                                        #27
                                        The gphoto-2 seams to be breaking the voxl-vision-px4 system. Any command associated with the voxl-vision-px4 system causes the voxl to kick any adb connection then prevent any from connecting until a power cycle. I can't get both voxl-vision-px4 and gphoto2 installed and running on the same system.
                                        Any thoughts?
                                          Any thoughts?
                                          @Aaron-Bottke I'll take a look
