  3. Sentinel drone randomly reboots
22 Posts 7 Posters 8.6k Views 2 Watching
  • R Offline
    R Offline
    rohitpillai
    @Vinny sounds good. Eager for more ideas on how to fix the issue.
      @rohitpillai One thing to take a look at is the APM (power module), ensure that the cable and none of it's wires in the connectors of the MCBL-0001 (https://docs.modalai.com/cable-datasheets/#mcbl-00001) have come loose. It may also be worth replacing it as a test.
      • R rohitpillai
        @Vinny Just wanted to update you guys on this post.
        We tried using the kapton tape on the VOXL2 and making sure there is enough space between the Microhard board and the J5. It hasn't fixed the issue. Any other ideas on how to fix this? We might have to bring the drone into your office for check up.
        Jeremy SchmidtJ Offline
        Jeremy Schmidt
        @rohitpillai Good morning,
        @Vinny filled me in on your issue and I wanted to check in with you on the status. You mentioned coming by the office and so I also wanted to discuss that option with you. Ease let me know if you're still interested in doing that.
        • R Offline
          R Offline
          rohitpillai
          @tom Yep let me test this out and get back to you.
          @Jeremy-Schmidt If no other solutions work, I will bring it into the office early next week!
          • Dobry KolaczD Offline
            Dobry Kolacz
            @rohitpillai When you removed the extension cable, were you still plugging the tracking camera into the M0054 board directly?
            • R Offline
              R Offline
              rohitpillai
              Yes, I believe so. We plugged it back in exactly how it was when we picked the drone up.
                Dobry Kolacz
                @rohitpillai do you have a spare mcbl-0001 you can try on this setup?
                • R Offline
                  R Offline
                  rohitpillai
                  I re-flashed the drone with the new VOXL2 package and it seems to have fixed itself for the time being. I will post in this thread again if the issue springs back up.
                  • R Offline
                    R Offline
                    rohitpillai
                    Update: We are hitting a roadblock where adb shell is not working and the device is not showing up under adb devices. Could you help us here? We are able to SSH in fine but can't use the cable.
                      @rohitpillai What is the output of lsusb on the host PC with the Sentinel plugged into it via. USB-C?
                      dleeD 1 Reply Last reply
                        dleeD Offline
                        dleeD Offline
                        dlee
                        wrote on last edited by dlee
                        #16
                        This is the lsusb result.
                        After rebooting many times, it was detected by lsusb. But when we attach the 'VOXL Microhard Modem Add-on with USB Hub', it kept rebooting and didn't work. I think we have to bring them to your office and check it.
                          @dlee Any sort of reboot loop is likely to be an MCBL-0001 failure
                            dleeD Offline
                            dleeD Offline
                            dlee
                            #18
                            VOXL Sentinel
                            This is the reboot loop.
                              @dlee Yep that looks exactly like what I've seen when the MCBL-0001 from the power module goes bad. Do you have another you could try with? If not, you could try making sure all of it's wires are seated fully into their connectors. Depending on how often / how the cable was unplugged the wires may not be fully seated.
                                dleeD Offline
                                dleeD Offline
                                dlee
                                @tom Yep, I have another. What should I do. Check the power cable?
                                  @dlee Yeah I would try switching out the drone's MCBL-0001 for the spare that you have to see if it solves the issue.
                                    dleeD Offline
                                    dleeD Offline
                                    dlee
                                    @tom Thank you. It works well
                                    • VinnyV Vinny referenced this topic on
