  3. VOXL2 ADB not working
18 Posts 5 Posters 4.2k Views 3 Watching
    @darwin-keem sorry to hear you're having issues. You may want to check the camera connections again. If one of the camera connections is not fully seated, it'll prevent full boot of the VOXL2.
    You mentioned that you plugged in the TOF. That might be the cause. Unfortunately, TOF is not yet fully supported on the VOXL2. We'll keep you posted when it does.
    D Offline
    D Offline
    darwin.keem
    @Adrian-Hidalgo We disconnected ToF and reconnected with the original Hi-Res camera. Also, we've checked the camera connections, but had no issue about it. However, we've disconnected GPS module, as we don't need it. Can this be the reason?
    • D Offline
      D Offline
      darwin.keem
      @tom We've ran factory reset with qdl and this is the output.
      After performing qdl, if we run lsusb without turning off the power, it gives us this.
      If we cycle power and run lsusb, it is still shown below. It is not recognized as 05c6:901d.
        @darwin-keem After running the QDL flash and removing power did you switch back off the EDL switch on VOXL2 before powering back on?
        D 1 Reply Last reply
          D Offline
          D Offline
          darwin.keem
          @tom Yes, we did.
            @darwin-keem Did the output of the QDL flash look complete? Did it reach the point seen in this doc: https://docs.modalai.com/Qualcomm-Flight-RB5-QDL/
            partition 1 is now bootable
            <data>
            <data>
            • D Offline
              D Offline
              darwin.keem
              @tom Yes, it reached the point. The result is written on the previous replies.
                @darwin-keem Apologies, I missed that reply. Are you able to force the VOXL2 into fastboot via. the button? You can follow this video for instructions: https://www.youtube.com/watch?v=IM3PnW7cipQ
                • D Offline
                  D Offline
                  darwin.keem
                  @tom Yes, entering into fastboot mode is possible. We tried re-flashing with voxl2_platform_1.3.1-0.8/system-image/flash-system-image.sh. But after flashing, it doesn't go after but only waiting for ADB.
                  Done Flashing
                  [--------------------------------------------------------](100%)
                  rebooting...
                  finished. total time: 0.050s
                  [INFO] Waiting for ADB
                  • D Offline
                    D Offline
                    darwin.keem
                    wrote on last edited by darwin.keem
                    #13
                    We need VOXL 2 to work urgently. Can we get any remote assist? Thanks.
                    • D darwin.keem
                      @darwin-keem This can mean that you have a damaged power cable from the APM to the VOXL 2. The cables are Robotis 184-903-0081-000 Cable-4P if you don't have a spare to try.
                      D 2 Replies Last reply
                        D Offline
                        D Offline
                        darwin.keem
                        @Eric-Katzfey Thanks. We will try as soon as possible. Are there any more possible solutions that might solve this problem?
                          D Offline
                          D Offline
                          darwin.keem
                          @Eric-Katzfey We've tried replacing power cable with a spare. Tried fastboot and qdl again, but it doesn't work.
                          • modaltbM Offline
                            modaltbM Offline
                            modaltb
                            @darwin-keem ,
                            Going through the thread above, a link was provided for the RB5 Flight QDL, but you have a VOXL2 Sentinel.... So for QDL on VOXL 2 the link is: https://docs.modalai.com/voxl2-qdl/
                            And you should be using these files for the QDL process:
                            VOXL2 QDL Image 14.1a_1.1.2
                            r14.1a_1.1.2-M0054-14.1a-FLAT-V3.zip
                            Can you confirm that is what you have used? This is what we would use as the first step towards troubleshooting as well internally.
                            What I normally do is remove any hardware connections to the bare minimum if I'm having issues with bootup..... If camera connectors have issues, it can prevent bootup for sure.
                            • modaltbM modaltb
                              @darwin-keem ,
                              D Offline
                              D Offline
                              darwin.keem
                              @modaltb Yes, we used r14.1a_1.1.2-M0054-14.1a-FLAT-V3.zip as well.
                              We will make a try with removing all the hardware connection.
