  3. VOXL2 ADB not working
18 Posts 5 Posters 4.2k Views 3 Watching
    @darwin-keem After running the QDL flash and removing power did you switch back off the EDL switch on VOXL2 before powering back on?
    D 1 Reply Last reply
      D Offline
      D Offline
      darwin.keem
      @tom Yes, we did.
        @darwin-keem Did the output of the QDL flash look complete? Did it reach the point seen in this doc: https://docs.modalai.com/Qualcomm-Flight-RB5-QDL/
        partition 1 is now bootable
        <data>
        <data>
        • D Offline
          D Offline
          darwin.keem
          @tom Yes, it reached the point. The result is written on the previous replies.
            @darwin-keem Apologies, I missed that reply. Are you able to force the VOXL2 into fastboot via. the button? You can follow this video for instructions: https://www.youtube.com/watch?v=IM3PnW7cipQ
            • D Offline
              D Offline
              darwin.keem
              @tom Yes, entering into fastboot mode is possible. We tried re-flashing with voxl2_platform_1.3.1-0.8/system-image/flash-system-image.sh. But after flashing, it doesn't go after but only waiting for ADB.
              Done Flashing
              [--------------------------------------------------------](100%)
              rebooting...
              finished. total time: 0.050s
              [INFO] Waiting for ADB
              • D Offline
                D Offline
                darwin.keem
                wrote on last edited by darwin.keem
                #13
                We need VOXL 2 to work urgently. Can we get any remote assist? Thanks.
                • D darwin.keem
                  @darwin-keem This can mean that you have a damaged power cable from the APM to the VOXL 2. The cables are Robotis 184-903-0081-000 Cable-4P if you don't have a spare to try.
                  D 2 Replies Last reply
                    D Offline
                    D Offline
                    darwin.keem
                    @Eric-Katzfey Thanks. We will try as soon as possible. Are there any more possible solutions that might solve this problem?
                      D Offline
                      D Offline
                      darwin.keem
                      @Eric-Katzfey We've tried replacing power cable with a spare. Tried fastboot and qdl again, but it doesn't work.
                      • modaltbM Offline
                        modaltbM Offline
                        modaltb
                        @darwin-keem ,
                        Going through the thread above, a link was provided for the RB5 Flight QDL, but you have a VOXL2 Sentinel.... So for QDL on VOXL 2 the link is: https://docs.modalai.com/voxl2-qdl/
                        And you should be using these files for the QDL process:
                        VOXL2 QDL Image 14.1a_1.1.2
                        r14.1a_1.1.2-M0054-14.1a-FLAT-V3.zip
                        Can you confirm that is what you have used? This is what we would use as the first step towards troubleshooting as well internally.
                        What I normally do is remove any hardware connections to the bare minimum if I'm having issues with bootup..... If camera connectors have issues, it can prevent bootup for sure.
                        • modaltbM modaltb
                          @darwin-keem ,
                          D Offline
                          D Offline
                          darwin.keem
                          @modaltb Yes, we used r14.1a_1.1.2-M0054-14.1a-FLAT-V3.zip as well.
                          We will make a try with removing all the hardware connection.
