  3. PX4 disconnected from UART & QGC cannot connected to modalAI
m500
15 Posts 5 Posters 3.5k Views 1 Watching
  • H howard
    @DarkKnightCH
    Hi, Please try restarting the voxl-vision-px4 by running systemctl restart voxl-vision-px4.
    Try enabling voxl-mavlink-server
    Also ensure you have right qgc ip address in /etc/modalai/voxl-vision-px4.
    D Offline
    D Offline
    DarkKnightCH
    @keil
    Hi, keil, Thanks for help.
    I tried to run the systemctl restart voxl-vision-px4, but it doesn't help.
    What do you mean enabling voxl-mavlink-server?
    QGC ip address is correct.
    • D DarkKnightCH
      HI,
      I also found this post which has the same issue with me. I tried to follow the suggestion in this post:I open a MAVLink connection over USB to the flight core, and run mavlink status from the nutshell
      NuttShell (NSH)
      nsh> mavlink status
      instance #0:
          GCS heartbeat:    267144 us ago
          mavlink chan: #0
          type:        USB CDC
          flow control: OFF
          rates:
            tx: 15.682 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 800000 B/s
            rx: 0.046 kB/s
          FTP enabled: YES, TX enabled: YES
          mode: Config
          MAVLink version: 2
          transport protocol: serial (/dev/ttyACM0 @2000000)
          ping statistics:
            last: 1.72 ms
            mean: 2.18 ms
            max: 6541.72 ms
            min: 0.19 ms
            dropped packets: 5
      instance #1:
          mavlink chan: #1
          type:        GENERIC LINK OR RADIO
          flow control: ON
          rates:
            tx: 1.564 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 2880 B/s
            rx: 0.000 kB/s
          mode: Normal
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS6 @57600)
      instance #2:
          mavlink chan: #2
          flow control: OFF
          rates:
            tx: 14.672 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 46080 B/s
            rx: 0.000 kB/s
          mode: Onboard
          MAVLink version: 2
          transport protocol: serial (/dev/ttyS4 @921600)
      instance #3:
          mavlink chan: #3
          flow control: ON
          rates:
            tx: 1.564 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            rx: 0.000 kB/s
          mode: Normal
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS1 @57600)
      From above information, I cannot track where the issue is, any suggestion?
      D Offline
      D Offline
      DarkKnightCH
      • D Offline
        D Offline
        DarkKnightCH
        wrote on last edited by DarkKnightCH
        More tests have done:
        (1) First, I can ssh into voxl through my laptop. And this means the wifi in VOXL is working.
        (2) I can adb into voxl board, which means that my voxl board is not bricked?
        (3)I can connect my flight core with my QGC via USB.
        (4)I tried to run voxl-inspect-services, and it shows
        (5)I also tried to run voxl-inspect-qvio, and it shows that
        (6)I also tried to reset the voxl-vision-px4 by running voxl-configure-vision-px4 as follows
        But there still is a WARNING show PX4 disconnected from UART.
        Any suggestion😧 ?
          That warning implies there is an issue in the comms between the Snapdragon and the STM32F7. Maybe try to reload the STM32F7 (Flight Core) firmware and see if that helps?
          • D Offline
            D Offline
            DarkKnightCH
            @Chad-Sweet Yeah. I already reload a flight core firmware and it doesn't help. Is it possible that voxl-vision-px4 server is broken? The UART wire physical connection looks pretty valid. it is hard for me to find out where the issue is from.
            • D Offline
              D Offline
              DarkKnightCH
              @Chad-Sweet I would like to update my voxl-suite-ipk meta package since I doubt maybe something is wrong about the voxl-vision-px4? is there a simple way to do it except flashing a new system image of voxl? should I use the following command to do it?
              opkg update && opkg upgrade
                That warning implies a hardware issue more than a software issue. What if you try the nuttx shell to test connectivity between the Snapdragon and Flight Core?
                D 1 Reply Last reply
                • Chad SweetC Chad Sweet
                  D Offline
                  D Offline
                  DarkKnightCH
                  @Chad-Sweet I tried to follow your advice and it shows
                  voxl:~$ voxl-px4-shell
                  ERROR opening /run/mpa/vvpx4_shell/
                  most likely the voxl-vision-px4 service is not running
                  I also tried to run
                  and
                  voxl-vision-px4 status
                  and it shows
                  voxl:~$ voxl-vision-px4 status
                  loading our own config file
                  qgc_ip:                     192.168.0.121
                  en_localhost_mavlink_udp    1
                  en_secondary_qgc:           0
                  qgc_udp_port_number:        14550
                  udp_mtu:                    512
                  en_vio:                     1
                  en_voa:                     1
                  en_send_vio_to_qgc:         0
                  en_send_voa_to_qgc:         0
                  en_set_clock_from_gps:      1
                  en_force_onboard_mav1_mode: 1
                  en_reset_px4_on_error:      1
                  qvio_auto_reset_quality:    0.000500
                  horizon_cal_tolerance:      0.300000
                  voa_upper_bound_m:          1.250000
                  voa_lower_bound_m:          1.250000
                  en_adsb:                    0
                  adsb_uart_bus:              7
                  adsb_uart_baudrate:         57600
                  px4_uart_bus:               5
                  px4_uart_baudrate:          921600
                  follow_tag_id:              0
                  en_tag_fixed_frame:         0
                  fixed_frame_filter_len:     5
                  starting geometry module
                  starting px4 monitor
                  starting uart mavlink
                  Successfully opened mavparser
                  starting udp mavlink
                  Adding manual QGC IP address to udp connection list: 192.168.0.121
                  Added new UDP connection to 192.168.0.121
                  starting px4 shell
                  starting fixed pose input
                  starting vio manager
                  starting tag manager
                  starting voa manager
                  starting control input pipe
                  Connected to voxl-qvio-server
                  updating to use imu: imu0
                  done updating transforms to use imu: imu0
                  Connected to voxl-tag-detector
                  Connected to voxl-dfs-server
                  WARNING PX4 DISCONNECTED FROM UART
                  any suggestion?
                    You could try a fresh install by following the instructions here: https://docs.modalai.com/voxl-suite/ . There does seem to be a chance your hardware is damaged though.
                      D Offline
                      D Offline
                      DarkKnightCH
                      @Chad-Sweet Yeah. I tried the following command
                      voxl-configure-opkg
                      and
                      opkg update
                      and then try to restart the voxl-vision-px4 and it seems nothing helps.
                      Since I can connect to voxl through wifi and adb, I have no idea why voxl will broken since I treat it very carefully. Indeed sometimes this QGC disconnection issue happens randomly. Could I mail back the Flight Core and VOXL to you and would you mind helping me check what is the issue?
                      • A Offline
                        Anubhav
                        @DarkKnightCH
                        Are you able to connect to QGC now. if yes, what was the issue and how you rectified it?
                        T 1 Reply Last reply
                        • A Anubhav
                          @DarkKnightCH
                          T Offline
                          T Offline
                          tpavlic
                          @Anubhav and @DarkKnightCH: Was there any movement on this?
                          We have 7 drones with FCv2 (all of our other m500 drones have different FC's) that were also sent to us with the wrong radios. We were able to reconfigure the PX4 for the desired radios (and confirm RC connection to QGC), but running voxl-mavlink-server manually shows a UART error on the console. We are RMA'ing the 7 units with the bad mavlink back to ModalAI for a fix, but it would be great to save the shipping if a fix was found here.
