  3. PX4 disconnected from UART & QGC cannot connected to modalAI
m500
15 Posts 5 Posters 3.4k Views 1 Watching
  • D DarkKnightCH
    As you can see from the first figure, when I run:voxl_vision_px4 status, it shows that WARNING PX4 DISCONNECTED FROM UART, do you know how to address this issue? The firmware version is 1.11.3.
    I have noticed that this post have the same issue with mine. However, my ModalAI's MAV_1_MODE is already set to Onboard. https://forum.modalai.com/topic/70/warning-px4-disconnected-error-message-from-voxl-vision-px4?_=1657322074175
    Meanwhile, right now the QGC cannot connect to ModalAI.
    Any suggestion? Thanks in advance!
    H Offline
    H Offline
    howard
    @DarkKnightCH
    Hi, Please try restarting the voxl-vision-px4 by running systemctl restart voxl-vision-px4.
    Try enabling voxl-mavlink-server
    Also ensure you have right qgc ip address in /etc/modalai/voxl-vision-px4.
    D 1 Reply Last reply
    • D Offline
      D Offline
      DarkKnightCH
      HI,
      I also found this post which has the same issue with me. I tried to follow the suggestion in this post:I open a MAVLink connection over USB to the flight core, and run mavlink status from the nutshell
      NuttShell (NSH)
      nsh> mavlink status
      instance #0:
          GCS heartbeat:    267144 us ago
          mavlink chan: #0
          type:        USB CDC
          flow control: OFF
          rates:
            tx: 15.682 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 800000 B/s
            rx: 0.046 kB/s
          FTP enabled: YES, TX enabled: YES
          mode: Config
          MAVLink version: 2
          transport protocol: serial (/dev/ttyACM0 @2000000)
          ping statistics:
            last: 1.72 ms
            mean: 2.18 ms
            max: 6541.72 ms
            min: 0.19 ms
            dropped packets: 5
      instance #1:
          mavlink chan: #1
          type:        GENERIC LINK OR RADIO
          flow control: ON
          rates:
            tx: 1.564 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 2880 B/s
            rx: 0.000 kB/s
          mode: Normal
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS6 @57600)
      instance #2:
          mavlink chan: #2
          flow control: OFF
          rates:
            tx: 14.672 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            tx rate max: 46080 B/s
            rx: 0.000 kB/s
          mode: Onboard
          MAVLink version: 2
          transport protocol: serial (/dev/ttyS4 @921600)
      instance #3:
          mavlink chan: #3
          flow control: ON
          rates:
            tx: 1.564 kB/s
            txerr: 0.000 kB/s
            tx rate mult: 1.000
            rx: 0.000 kB/s
          mode: Normal
          MAVLink version: 1
          transport protocol: serial (/dev/ttyS1 @57600)
      From above information, I cannot track where the issue is, any suggestion?
      • H howard
        @DarkKnightCH
        D Offline
        D Offline
        DarkKnightCH
        @keil
        Hi, keil, Thanks for help.
        I tried to run the systemctl restart voxl-vision-px4, but it doesn't help.
        What do you mean enabling voxl-mavlink-server?
        QGC ip address is correct.
        • D DarkKnightCH
          HI,
          NuttShell (NSH)
          nsh> mavlink status
          instance #0:
              mavlink chan: #0
              type:        USB CDC
              flow control: OFF
              rates:
                tx: 15.682 kB/s
                txerr: 0.000 kB/s
                tx rate mult: 1.000
                rx: 0.046 kB/s
              mode: Config
              MAVLink version: 2
              ping statistics:
                last: 1.72 ms
                mean: 2.18 ms
                max: 6541.72 ms
                min: 0.19 ms
                dropped packets: 5
          instance #1:
              mavlink chan: #1
              flow control: ON
              rates:
                tx: 1.564 kB/s
                txerr: 0.000 kB/s
                tx rate mult: 1.000
                rx: 0.000 kB/s
              mode: Normal
              MAVLink version: 1
          instance #2:
              mavlink chan: #2
              flow control: OFF
              rates:
                tx: 14.672 kB/s
                txerr: 0.000 kB/s
                tx rate mult: 1.000
                rx: 0.000 kB/s
              mode: Onboard
              MAVLink version: 2
          instance #3:
              mavlink chan: #3
              flow control: ON
              rates:
                tx: 1.564 kB/s
                txerr: 0.000 kB/s
                tx rate mult: 1.000
                rx: 0.000 kB/s
              mode: Normal
              MAVLink version: 1
          D Offline
          D Offline
          DarkKnightCH
          • D Offline
            D Offline
            DarkKnightCH
            wrote on last edited by DarkKnightCH
            More tests have done:
            (1) First, I can ssh into voxl through my laptop. And this means the wifi in VOXL is working.
            (2) I can adb into voxl board, which means that my voxl board is not bricked?
            (3)I can connect my flight core with my QGC via USB.
            (4)I tried to run voxl-inspect-services, and it shows
            (5)I also tried to run voxl-inspect-qvio, and it shows that
            (6)I also tried to reset the voxl-vision-px4 by running voxl-configure-vision-px4 as follows
            But there still is a WARNING show PX4 disconnected from UART.
            Any suggestion😧 ?
              That warning implies there is an issue in the comms between the Snapdragon and the STM32F7. Maybe try to reload the STM32F7 (Flight Core) firmware and see if that helps?
              • D Offline
                D Offline
                DarkKnightCH
                @Chad-Sweet Yeah. I already reload a flight core firmware and it doesn't help. Is it possible that voxl-vision-px4 server is broken? The UART wire physical connection looks pretty valid. it is hard for me to find out where the issue is from.
                • D Offline
                  D Offline
                  DarkKnightCH
                  @Chad-Sweet I would like to update my voxl-suite-ipk meta package since I doubt maybe something is wrong about the voxl-vision-px4? is there a simple way to do it except flashing a new system image of voxl? should I use the following command to do it?
                  opkg update && opkg upgrade
                    That warning implies a hardware issue more than a software issue. What if you try the nuttx shell to test connectivity between the Snapdragon and Flight Core?
                    • Chad SweetC Chad Sweet
                      D Offline
                      D Offline
                      DarkKnightCH
                      @Chad-Sweet I tried to follow your advice and it shows
                      voxl:~$ voxl-px4-shell
                      ERROR opening /run/mpa/vvpx4_shell/
                      most likely the voxl-vision-px4 service is not running
                      I also tried to run
                      and
                      voxl-vision-px4 status
                      and it shows
                      voxl:~$ voxl-vision-px4 status
                      loading our own config file
                      qgc_ip:                     192.168.0.121
                      en_localhost_mavlink_udp    1
                      en_secondary_qgc:           0
                      qgc_udp_port_number:        14550
                      udp_mtu:                    512
                      en_vio:                     1
                      en_voa:                     1
                      en_send_vio_to_qgc:         0
                      en_send_voa_to_qgc:         0
                      en_set_clock_from_gps:      1
                      en_force_onboard_mav1_mode: 1
                      en_reset_px4_on_error:      1
                      qvio_auto_reset_quality:    0.000500
                      horizon_cal_tolerance:      0.300000
                      voa_upper_bound_m:          1.250000
                      voa_lower_bound_m:          1.250000
                      en_adsb:                    0
                      adsb_uart_bus:              7
                      adsb_uart_baudrate:         57600
                      px4_uart_bus:               5
                      px4_uart_baudrate:          921600
                      follow_tag_id:              0
                      en_tag_fixed_frame:         0
                      fixed_frame_filter_len:     5
                      starting geometry module
                      starting px4 monitor
                      starting uart mavlink
                      Successfully opened mavparser
                      starting udp mavlink
                      Adding manual QGC IP address to udp connection list: 192.168.0.121
                      Added new UDP connection to 192.168.0.121
                      starting px4 shell
                      starting fixed pose input
                      starting vio manager
                      starting tag manager
                      starting voa manager
                      starting control input pipe
                      Connected to voxl-qvio-server
                      updating to use imu: imu0
                      done updating transforms to use imu: imu0
                      Connected to voxl-tag-detector
                      Connected to voxl-dfs-server
                      any suggestion?
                        You could try a fresh install by following the instructions here: https://docs.modalai.com/voxl-suite/ . There does seem to be a chance your hardware is damaged though.
                          D Offline
                          D Offline
                          DarkKnightCH
                          @Chad-Sweet Yeah. I tried the following command
                          voxl-configure-opkg
                          and
                          opkg update
                          and then try to restart the voxl-vision-px4 and it seems nothing helps.
                          Since I can connect to voxl through wifi and adb, I have no idea why voxl will broken since I treat it very carefully. Indeed sometimes this QGC disconnection issue happens randomly. Could I mail back the Flight Core and VOXL to you and would you mind helping me check what is the issue?
                          • A Offline
                            Anubhav
                            @DarkKnightCH
                            Are you able to connect to QGC now. if yes, what was the issue and how you rectified it?
                            T 1 Reply Last reply
                            • A Anubhav
                              @DarkKnightCH
                              T Offline
                              T Offline
                              tpavlic
                              @Anubhav and @DarkKnightCH: Was there any movement on this?
                              We have 7 drones with FCv2 (all of our other m500 drones have different FC's) that were also sent to us with the wrong radios. We were able to reconfigure the PX4 for the desired radios (and confirm RC connection to QGC), but running voxl-mavlink-server manually shows a UART error on the console. We are RMA'ing the 7 units with the bad mavlink back to ModalAI for a fix, but it would be great to save the shipping if a fix was found here.
