  3. VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published
Scheduled Pinned Locked Moved Solved General Questions
27 Posts 3 Posters 2.0k Views 3 Watching
  • Eric KatzfeyE Offline
    Can you upload the log file to https://review.px4.io/ and then send the link?
    • nickanickN Offline
      nickanickN Offline
      nickanick
      px4 log: https://review.px4.io/plot_app?log=31e428fe-d363-43c6-9cc3-236af2212533
      Will post output.txt file shortly
        nickanickN Offline
        nickanick
        Is there I way that I can share the output.txt file with you? https://review.px4.io/ doesn't take my output.txt file
          The forum won't let you attach it in your reply?
            nickanickN Offline
            nickanick
            Error
            You do not have enough privileges for this action.
            Also, the text is too long so I can't copy and paste the entire log here
              Okay, shoot, let me see if we can get that fixed.
                I sent an email to the address you have linked to this account.
                  nickanickN Offline
                  nickanick
                  output.txt sent
                    File:
                    output.txt
                      #21
                      This is what Codex says:
                      The root cause is a PX4 source-enum bug, not the ESC, baud rate, or VOXL_ESC_PUB_BST.
                        - The supplied parameters select BAT1_SOURCE=2, meaning “ESCs”: /home/modalai/development/log_debug/no-batt-status/
                          vehicle.params:5.
                        - But voxl_esc constructs its battery object as BATTERY_SOURCE_POWER_MODULE (0): src/drivers/actuators/voxl_esc/
                          voxl_esc.cpp:51.
                        - The battery library publishes only when the driver’s source equals BAT1_SOURCE: src/lib/battery/battery.cpp:172.
                        - Therefore 0 != 2, and every battery report is silently suppressed.
                        This matches all the evidence:
                        - VOXL_ESC_PUB_BST=1.
                        - All four M0138 channels, including current-sensing ID 2, communicate at 2 Mbaud: /home/modalai/development/log_debug/no-
                          batt-status/output.txt:279.
                        - The flight log contains 232,935 healthy esc_status samples but no battery_status.
                        - The forum test showed ID 2 reporting BOARD_VOLTAGE and BOARD_CURRENT, proving the ESC produces the special telemetry
                          packet. This is the expected M0138 behavior documented in the ModalAI ESC FAQ (https://docs.modalai.com/voxl-escs/faq/).
                        The proper code fix is one line:
                        _battery(1, nullptr, _battery_report_interval,
                                 battery_status_s::BATTERY_SOURCE_ESCS)
                        As an immediate workaround with the existing binary, set BAT1_SOURCE to Power Module (0), leave POWER_MANAGER=none, restart
                        voxl-px4, and check:
                        px4-listener battery_status 5
                        That should publish, although the resulting topic will incorrectly identify its source as a power module. The one-line source
                        change is the permanent fix.
                      Can you try setting that parameter and see if it works?
                        I think you need to keep BAT1_SOURCE set to 0.
                          nickanickN Offline
                          nickanick
                          BAT1_SOURCE set to POWER MODULE in QGC fixed the problem.
                          TOPIC: battery_status
                          battery_status
                          timestamp: 332496007 (0.011529 seconds ago)
                          voltage_v: 23.70500
                          voltage_filtered_v: 23.70641
                          current_a: -0.08000
                          current_filtered_a: -0.07003
                          current_average_a: 15.00000
                          discharged_mah: 0.00138
                          remaining: 0.70196
                          scale: 1.04008
                          time_remaining_s: 673.87732
                          temperature: nan
                          voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
                          max_cell_voltage_delta: 0.00000
                          custom_faults: 0
                          average_power: 0.00000
                          available_energy: 0.00000
                          full_charge_capacity_wh: 0.00000
                          remaining_capacity_wh: 0.00000
                          design_capacity: 0.00000
                          nominal_voltage: 0.00000
                          capacity: 4000
                          cycle_count: 0
                          average_time_to_empty: 0
                          serial_number: 0
                          manufacture_date: 0
                          state_of_health: 0
                          max_error: 0
                          interface_error: 0
                          faults: 0
                          average_time_to_full: 0
                          over_discharge_count: 0
                          connected: True
                          cell_count: 6
                          source: 0
                          priority: 0
                          is_powering_off: False
                          is_required: False
                          warning: 0
                          mode: 0
                            nickanickN Offline
                            nickanick
                            Thanks for your help
                            • Alex KushleyevA Offline
                              @nickanick ,
                              Now that the main issue is resolved.. i am confused why the following test command did not work for you :
                              ./voxl-esc-spin.py --id 255 --power 0
                              The screenshot you posted had the command cut off -- are you sure you used the correct command? 255 is a special value that should spin all 4 ESCs: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/voxl-esc-spin.py?ref_type=heads#L190
                              Can you check if the voxl-esc-spin.py script on your VOXL2 is the same as this file?
                                nickanickN Offline
                                nickanick
                                That's weird. It's working now:
                                voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 255 --power 0
                                Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)
                                [GCC 8.4.0]
                                VOXL Platform: M0054
                                Board : version 42: ModalAi 4-in-1 ESC (M0138-1)
                                UID : 0x203837304848570400480052
                                Firmware : version 39, hash a58f5f6f
                                Bootloader : version 187, hash aad89d63
                                UID        : 0x203837304848570400490045
                                UID        : 0x20383730484857040029004D
                                UID        : 0x20383730484857040029004E
                                WARNING:
                                from all persons.
                                Type "Yes" to continue: yes
                                [0.017] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                                [0.017] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A
                                [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                                [0.017] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                                [0.035] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.035] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.035] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.058] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.058] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.058] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.058] (3) RPM: 0, PWR: 0, VOLTAGE: 23.593V, TEMPERATURE: 31.06C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                                [0.074] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.656V, BOARD_CURRENT: -0.104A
                                  OK, thanks for checking. maybe there was a typo before
                                  • Alex KushleyevA Alex Kushleyev has marked this topic as solved on
