<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published]]></title><description><![CDATA[<p dir="auto">esc_status is healthy: 4 ESCs online, esc_voltage 24.055 (6S pack). BAT1_SOURCE = ESCs, VOXL_ESC_PUB_BST enabled, POWER_MANAGER=none in /etc/modalai/voxl-px4.conf per its own comment ("use none for modalai mini-esc since the esc driver handles PM"). px4-listener battery_status 5 reports "never published" after a voxl-px4 restart and a full reboot. No esc_battery module in this build. QGC shows no battery, and the preflight reports -100%.</p>
<p dir="auto">What publishes battery_status from ESC telemetry on 1.6.3? Is the ESC path supported on the FPV 4-in-1 (M0138), or only the mini ESC?</p>
]]></description><link>https://forum.modalai.com/topic/5350/voxl2-voxl-esc-fpv-4-in-1-voxl-suite-1.6.3-battery_status-never-published</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Jul 2026 21:37:35 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5350.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Jul 2026 05:19:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published on Tue, 28 Jul 2026 19:10:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alex-kushleyev" aria-label="Profile: alex-kushleyev">@<bdi>alex-kushleyev</bdi></a></p>
<p dir="auto">Result: --id 255 isn't supported by my voxl-esc-tools (bin version 1.9) — it scans, finds IDs 0–3, then exits with ERROR: Specified ESC ID not found. Running ./voxl-esc-spin.py --id 2 --power 0 works and I do see BOARD_VOLTAGE and BOARD_CURRENT printed. So the ESC is emitting the battery telemetry message correctly.</p>
<p dir="auto">But PX4 still never publishes battery_status:</p>
<p dir="auto">VOXL2 M0054, voxl-suite 1.6.3, 4× M0138-1 ESCs on firmware 39, tools 1.9<br />
BAT1_SOURCE = ESCs, VOXL_ESC_PUB_BST enabled in QGC<br />
POWER_MANAGER=none in /etc/modalai/voxl-px4.conf (was voxlpm; changed per the comment "use none for modalai mini-esc since the esc driver handles PM" — I have no voxlpm module, the ESC is my only sensing)<br />
px4-listener battery_status 5 → "never published", after systemctl restart voxl-px4 and a full reboot<br />
esc_status is healthy: 4 ESCs online, esc_voltage 24.055 (6S)</p>
<p dir="auto">Questions:</p>
<ul>
<li>
<p dir="auto">How do I verify VOXL_ESC_PUB_BST on the flight side? px4-qshell param show VOXL_ESC_PUB_BST doesn't return anything readable in my terminal, so I can't confirm the QGC write reached the DSP.</p>
</li>
<li>
<p dir="auto">Does the voxl-esc driver poll ESC channel 2 for telemetry in my configuration? If its telemetry rotation depends on the motor mapping, could it be missing the one channel that sends the battery message?</p>
</li>
<li>
<p dir="auto">Is POWER_MANAGER=none correct for the FPV 4-in-1 (M0138), or is that comment specific to the mini ESC (M0129)?</p>
</li>
</ul>
]]></description><link>https://forum.modalai.com/post/26496</link><guid isPermaLink="true">https://forum.modalai.com/post/26496</guid><dc:creator><![CDATA[nickanick]]></dc:creator><pubDate>Tue, 28 Jul 2026 19:10:19 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published on Tue, 28 Jul 2026 19:02:43 GMT]]></title><description><![CDATA[<p dir="auto">voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 2 --power 0<br />
Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)<br />
[GCC 8.4.0]<br />
Found voxl-esc tools bin version: 1.9<br />
VOXL Platform: M0054<br />
Detected RB5 Flight, VOXL2 M0054 or M0104!<br />
INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 2000000<br />
Sending library name request: libslpi_qrb5165_io.so<br />
Sending initialization request<br />
INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 2000000<br />
Board      : version 42: ModalAi 4-in-1 ESC (M0138-1)<br />
UID        : 0x203837304848570400480052<br />
Firmware   : version   39, hash a58f5f6f<br />
Bootloader : version  187, hash aad89d63</p>
<pre><code>ID         : 1
UID        : 0x203837304848570400490045
UID        : 0x20383730484857040029004D
UID        : 0x20383730484857040029004E
<hr />
<p dir="auto">WARNING:<br />
This test requires motors to spin at high speeds with<br />
propellers attached. Please ensure that appropriate<br />
protective equipment is being worn at all times and<br />
that the motor and propeller are adequately isolated<br />
from all persons.</p>
<p dir="auto">For best results, please perform this test at the<br />
nominal voltage for the battery used.</p>
<p dir="auto">Type "Yes" to continue: yes<br />
[0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 23.842V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.842V, BOARD_CURRENT: -0.096A<br />
[0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.072A<br />
[0.054] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.48C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.080A<br />
[0.076] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.49C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.040A<br />
[0.092] (2) RPM: 0, PWR: 0, VOLTAGE: 23.844V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.844V, BOARD_CURRENT: -0.096A<br />
[0.121] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.064A<br />
[0.133] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.44C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.008A<br />
[0.153] (2) RPM: 0, PWR: 0, VOLTAGE: 23.840V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.840V, BOARD_CURRENT: -0.048A<br />
[0.178] (2) RPM: 0, PWR: 0, VOLTAGE: 23.841V, TEMPERATURE: 37.45C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.841V, BOARD_CURRENT: -0.064A</p>
]]></description><link>https://forum.modalai.com/post/26495</link><guid isPermaLink="true">https://forum.modalai.com/post/26495</guid><dc:creator><![CDATA[nickanick]]></dc:creator><pubDate>Tue, 28 Jul 2026 19:02:43 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published on Tue, 28 Jul 2026 19:04:55 GMT]]></title><description><![CDATA[<p dir="auto">Attached is the output for './voxl-esc-spin.py --id 255 --power 0'<br />
<img src="/assets/uploads/files/1785263512646-screenshot-2026-07-28-113131.png" alt="Screenshot 2026-07-28 113131.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.modalai.com/post/26494</link><guid isPermaLink="true">https://forum.modalai.com/post/26494</guid><dc:creator><![CDATA[nickanick]]></dc:creator><pubDate>Tue, 28 Jul 2026 19:04:55 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published on Tue, 28 Jul 2026 15:37:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nickanick" aria-label="Profile: nickanick">@<bdi>nickanick</bdi></a> ,</p>
<p dir="auto">Here is some background..</p>
<p dir="auto">The Mini ESC (M0129) and the FPV ESC (M0138) do not have individual channel current sensing (unlike M0134 ESC), so the individual ESC channel current is reported as 0, while each ESC channel still reports the measured voltage in the standard telemetry packet sent to the FC. For these two ESCs (M0129 and M0138), one of the ESC channels measures the total board current that flows through the ESC and sends out a second telemetry message with just voltage and total current. For M0129, the ESC channel 3 does this, and for M0138, channel 2 (0-indexed).</p>
<p dir="auto">The telemetry messages are sent from the ESC to the FC (VOXL2) via UART and is parsed in the PX4 in <code>voxl-esc</code> driver. In the <code>voxl-esc</code> driver, if the battery status telemetry message is received from the ESC and <code>VOXL_ESC_PUB_BST</code> is enabled, then the driver will publish the <code>battery_status</code> topic with the battery voltage and current from the ESC telemetry message.</p>
<p dir="auto">In order to do a quick test to make sure the ESC is sending out the battery status, you can do the following:</p>
<ul>
<li>stop px4 : <code>systemctl stop voxl-px4</code></li>
<li>test the ESC using <code>voxl-esc</code> tools (note that these tools are not part of px4):</li>
</ul>
<pre><code>cd /usr/share/modalai/voxl-esc-tools
<p dir="auto">Note that you will be running a spin test command (take off props for safety!), but the command is 0, so the motors will not spin, but you will see the telemetry from the ESC being printed in the terminal on voxl2. You will see<em><strong>BOARD_VOLTAGE</strong></em>  and <em><strong>BOARD_CURRENT</strong></em> being reported and that is coming from the extra telemetry message from the ESC. If you see this current printed, then the ESC is sending the correct information.</p>
<p dir="auto">The argument <code>--id 255</code> will tell the test script to communicate with all 4 ESC channels and the commands will be sent and telemetry requested from all 4 ESC channels (including the channel that sends back the battery status telemetry message).</p>
<p dir="auto">Can you please check this?</p>
<pre><code>voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 255 --power 0
[GCC 8.4.0]
	Board      : version 40: ModalAi 4-in-1 ESC (M0129-3)
	UID        : 0x2039333557555313000F0036
	Firmware   : version   39, hash 9c6233d6
	Bootloader : version  184, hash 10bf24c8
	UID        : 0x2039333557555313000F0032
	UID        : 0x2039333557555313000F0034
	UID        : 0x2039333557555313000F0038
WARNING:
from all persons.
[0.015] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
[0.015] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A
[0.015] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
[0.015] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
[0.036] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
[0.036] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A
[0.036] (2) RPM: 0, PWR: 0, VOLTAGE: 16.059V, TEMPERATURE: 38.85C, CURRENT: 0.000A
[0.036] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
[0.059] (0) RPM: 0, PWR: 0, VOLTAGE: 16.039V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.059] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.059] (2) RPM: 0, PWR: 0, VOLTAGE: 16.059V, TEMPERATURE: 38.85C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.059] (3) RPM: 0, PWR: 0, VOLTAGE: 16.047V, TEMPERATURE: 38.86C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.075] (0) RPM: 0, PWR: 0, VOLTAGE: 16.039V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.075] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.075] (2) RPM: 0, PWR: 0, VOLTAGE: 16.065V, TEMPERATURE: 38.89C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.075] (3) RPM: 0, PWR: 0, VOLTAGE: 16.047V, TEMPERATURE: 38.86C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
[0.101] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.19C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.101] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.101] (2) RPM: 0, PWR: 0, VOLTAGE: 16.065V, TEMPERATURE: 38.89C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.101] (3) RPM: 0, PWR: 0, VOLTAGE: 16.041V, TEMPERATURE: 38.91C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.119] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.19C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.119] (1) RPM: 0, PWR: 0, VOLTAGE: 16.054V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.119] (2) RPM: 0, PWR: 0, VOLTAGE: 16.060V, TEMPERATURE: 38.88C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.119] (3) RPM: 0, PWR: 0, VOLTAGE: 16.041V, TEMPERATURE: 38.91C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
[0.137] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.25C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
[0.137] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
[0.137] (2) RPM: 0, PWR: 0, VOLTAGE: 16.060V, TEMPERATURE: 38.88C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
[0.137] (3) RPM: 0, PWR: 0, VOLTAGE: 16.043V, TEMPERATURE: 38.90C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
[0.156] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.25C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
]]></description><link>https://forum.modalai.com/post/26491</link><guid isPermaLink="true">https://forum.modalai.com/post/26491</guid><dc:creator><![CDATA[Alex Kushleyev]]></dc:creator><pubDate>Tue, 28 Jul 2026 15:37:34 GMT</pubDate></item></channel></rss>
