  3. VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published
Scheduled Pinned Locked Moved Solved General Questions
27 Posts 3 Posters 2.7k Views 3 Watching
  • Eric KatzfeyE Offline
    Okay, shoot, let me see if we can get that fixed.
      I sent an email to the address you have linked to this account.
      • nickanickN Offline
        nickanickN Offline
        nickanick
        output.txt sent
          File:
          output.txt
            #21
            This is what Codex says:
            The root cause is a PX4 source-enum bug, not the ESC, baud rate, or VOXL_ESC_PUB_BST.
              - The supplied parameters select BAT1_SOURCE=2, meaning “ESCs”: /home/modalai/development/log_debug/no-batt-status/
                vehicle.params:5.
              - But voxl_esc constructs its battery object as BATTERY_SOURCE_POWER_MODULE (0): src/drivers/actuators/voxl_esc/
                voxl_esc.cpp:51.
              - The battery library publishes only when the driver’s source equals BAT1_SOURCE: src/lib/battery/battery.cpp:172.
              - Therefore 0 != 2, and every battery report is silently suppressed.
              This matches all the evidence:
              - VOXL_ESC_PUB_BST=1.
              - All four M0138 channels, including current-sensing ID 2, communicate at 2 Mbaud: /home/modalai/development/log_debug/no-
                batt-status/output.txt:279.
              - The flight log contains 232,935 healthy esc_status samples but no battery_status.
              - The forum test showed ID 2 reporting BOARD_VOLTAGE and BOARD_CURRENT, proving the ESC produces the special telemetry
                packet. This is the expected M0138 behavior documented in the ModalAI ESC FAQ (https://docs.modalai.com/voxl-escs/faq/).
              The proper code fix is one line:
              _battery(1, nullptr, _battery_report_interval,
                       battery_status_s::BATTERY_SOURCE_ESCS)
              As an immediate workaround with the existing binary, set BAT1_SOURCE to Power Module (0), leave POWER_MANAGER=none, restart
              voxl-px4, and check:
              px4-listener battery_status 5
              That should publish, although the resulting topic will incorrectly identify its source as a power module. The one-line source
              change is the permanent fix.
            Can you try setting that parameter and see if it works?
              I think you need to keep BAT1_SOURCE set to 0.
                nickanickN Offline
                nickanick
                BAT1_SOURCE set to POWER MODULE in QGC fixed the problem.
                TOPIC: battery_status
                battery_status
                timestamp: 332496007 (0.011529 seconds ago)
                voltage_v: 23.70500
                voltage_filtered_v: 23.70641
                current_a: -0.08000
                current_filtered_a: -0.07003
                current_average_a: 15.00000
                discharged_mah: 0.00138
                remaining: 0.70196
                scale: 1.04008
                time_remaining_s: 673.87732
                temperature: nan
                voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
                max_cell_voltage_delta: 0.00000
                custom_faults: 0
                average_power: 0.00000
                available_energy: 0.00000
                full_charge_capacity_wh: 0.00000
                remaining_capacity_wh: 0.00000
                design_capacity: 0.00000
                nominal_voltage: 0.00000
                capacity: 4000
                cycle_count: 0
                average_time_to_empty: 0
                serial_number: 0
                manufacture_date: 0
                state_of_health: 0
                max_error: 0
                interface_error: 0
                faults: 0
                average_time_to_full: 0
                over_discharge_count: 0
                connected: True
                cell_count: 6
                source: 0
                priority: 0
                is_powering_off: False
                is_required: False
                warning: 0
                mode: 0
                  nickanickN Offline
                  nickanick
                  Thanks for your help
                  • Alex KushleyevA Offline
                    @nickanick ,
                    Now that the main issue is resolved.. i am confused why the following test command did not work for you :
                    ./voxl-esc-spin.py --id 255 --power 0
                    The screenshot you posted had the command cut off -- are you sure you used the correct command? 255 is a special value that should spin all 4 ESCs: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/voxl-esc-spin.py?ref_type=heads#L190
                    Can you check if the voxl-esc-spin.py script on your VOXL2 is the same as this file?
                      nickanickN Offline
                      nickanick
                      That's weird. It's working now:
                      voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 255 --power 0
                      Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)
                      [GCC 8.4.0]
                      VOXL Platform: M0054
                      Board : version 42: ModalAi 4-in-1 ESC (M0138-1)
                      UID : 0x203837304848570400480052
                      Firmware : version 39, hash a58f5f6f
                      Bootloader : version 187, hash aad89d63
                      UID        : 0x203837304848570400490045
                      UID        : 0x20383730484857040029004D
                      UID        : 0x20383730484857040029004E
                      WARNING:
                      from all persons.
                      Type "Yes" to continue: yes
                      [0.017] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                      [0.017] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A
                      [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                      [0.017] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                      [0.035] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.035] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.035] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.058] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.058] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.058] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.058] (3) RPM: 0, PWR: 0, VOLTAGE: 23.593V, TEMPERATURE: 31.06C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                      [0.074] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.656V, BOARD_CURRENT: -0.104A
                        OK, thanks for checking. maybe there was a typo before
                        • Alex KushleyevA Alex Kushleyev has marked this topic as solved on
