  3. VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published
Scheduled Pinned Locked Moved Solved General Questions
27 Posts 3 Posters 2.7k Views 3 Watching
  • Eric KatzfeyE Offline
    The forum won't let you attach it in your reply?
    • nickanickN Offline
      nickanickN Offline
      nickanick
      Error
      You do not have enough privileges for this action.
      Also, the text is too long so I can't copy and paste the entire log here
        Okay, shoot, let me see if we can get that fixed.
          I sent an email to the address you have linked to this account.
            nickanickN Offline
            nickanick
            output.txt sent
              File:
              output.txt
                #21
                This is what Codex says:
                The root cause is a PX4 source-enum bug, not the ESC, baud rate, or VOXL_ESC_PUB_BST.
                  - The supplied parameters select BAT1_SOURCE=2, meaning “ESCs”: /home/modalai/development/log_debug/no-batt-status/
                    vehicle.params:5.
                  - But voxl_esc constructs its battery object as BATTERY_SOURCE_POWER_MODULE (0): src/drivers/actuators/voxl_esc/
                    voxl_esc.cpp:51.
                  - The battery library publishes only when the driver’s source equals BAT1_SOURCE: src/lib/battery/battery.cpp:172.
                  - Therefore 0 != 2, and every battery report is silently suppressed.
                  This matches all the evidence:
                  - VOXL_ESC_PUB_BST=1.
                  - All four M0138 channels, including current-sensing ID 2, communicate at 2 Mbaud: /home/modalai/development/log_debug/no-
                    batt-status/output.txt:279.
                  - The flight log contains 232,935 healthy esc_status samples but no battery_status.
                  - The forum test showed ID 2 reporting BOARD_VOLTAGE and BOARD_CURRENT, proving the ESC produces the special telemetry
                    packet. This is the expected M0138 behavior documented in the ModalAI ESC FAQ (https://docs.modalai.com/voxl-escs/faq/).
                  The proper code fix is one line:
                  _battery(1, nullptr, _battery_report_interval,
                           battery_status_s::BATTERY_SOURCE_ESCS)
                  As an immediate workaround with the existing binary, set BAT1_SOURCE to Power Module (0), leave POWER_MANAGER=none, restart
                  voxl-px4, and check:
                  px4-listener battery_status 5
                  That should publish, although the resulting topic will incorrectly identify its source as a power module. The one-line source
                  change is the permanent fix.
                Can you try setting that parameter and see if it works?
                  I think you need to keep BAT1_SOURCE set to 0.
                    nickanickN Offline
                    nickanick
                    BAT1_SOURCE set to POWER MODULE in QGC fixed the problem.
                    TOPIC: battery_status
                    battery_status
                    timestamp: 332496007 (0.011529 seconds ago)
                    voltage_v: 23.70500
                    voltage_filtered_v: 23.70641
                    current_a: -0.08000
                    current_filtered_a: -0.07003
                    current_average_a: 15.00000
                    discharged_mah: 0.00138
                    remaining: 0.70196
                    scale: 1.04008
                    time_remaining_s: 673.87732
                    temperature: nan
                    voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
                    max_cell_voltage_delta: 0.00000
                    custom_faults: 0
                    average_power: 0.00000
                    available_energy: 0.00000
                    full_charge_capacity_wh: 0.00000
                    remaining_capacity_wh: 0.00000
                    design_capacity: 0.00000
                    nominal_voltage: 0.00000
                    capacity: 4000
                    cycle_count: 0
                    average_time_to_empty: 0
                    serial_number: 0
                    manufacture_date: 0
                    state_of_health: 0
                    max_error: 0
                    interface_error: 0
                    faults: 0
                    average_time_to_full: 0
                    over_discharge_count: 0
                    connected: True
                    cell_count: 6
                    source: 0
                    priority: 0
                    is_powering_off: False
                    is_required: False
                    warning: 0
                    mode: 0
                      nickanickN Offline
                      nickanick
                      Thanks for your help
                      • Alex KushleyevA Offline
                        @nickanick ,
                        Now that the main issue is resolved.. i am confused why the following test command did not work for you :
                        ./voxl-esc-spin.py --id 255 --power 0
                        The screenshot you posted had the command cut off -- are you sure you used the correct command? 255 is a special value that should spin all 4 ESCs: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/voxl-esc-spin.py?ref_type=heads#L190
                        Can you check if the voxl-esc-spin.py script on your VOXL2 is the same as this file?
                          nickanickN Offline
                          nickanick
                          That's weird. It's working now:
                          voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 255 --power 0
                          Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)
                          [GCC 8.4.0]
                          VOXL Platform: M0054
                          Board : version 42: ModalAi 4-in-1 ESC (M0138-1)
                          UID : 0x203837304848570400480052
                          Firmware : version 39, hash a58f5f6f
                          Bootloader : version 187, hash aad89d63
                          UID        : 0x203837304848570400490045
                          UID        : 0x20383730484857040029004D
                          UID        : 0x20383730484857040029004E
                          WARNING:
                          from all persons.
                          Type "Yes" to continue: yes
                          [0.017] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                          [0.017] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A
                          [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                          [0.017] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
                          [0.035] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.035] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.035] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.058] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.058] (1) RPM: 0, PWR: 0, VOLTAGE: 23.647V, TEMPERATURE: 37.39C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.058] (2) RPM: 0, PWR: 0, VOLTAGE: 23.654V, TEMPERATURE: 37.97C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.058] (3) RPM: 0, PWR: 0, VOLTAGE: 23.593V, TEMPERATURE: 31.06C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.654V, BOARD_CURRENT: 0.016A
                          [0.074] (0) RPM: 0, PWR: 0, VOLTAGE: 23.652V, TEMPERATURE: 31.38C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.656V, BOARD_CURRENT: -0.104A
                            OK, thanks for checking. maybe there was a typo before
                            • Alex KushleyevA Alex Kushleyev has marked this topic as solved on
