  3. VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published
Scheduled Pinned Locked Moved Solved General Questions
27 Posts 3 Posters 2.7k Views 3 Watching
  • nickanickN Offline
    nickanickN Offline
    nickanick
    voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 2 --power 0
    Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)
    [GCC 8.4.0]
    VOXL Platform: M0054
    Board : version 42: ModalAi 4-in-1 ESC (M0138-1)
    UID : 0x203837304848570400480052
    Firmware : version 39, hash a58f5f6f
    Bootloader : version 187, hash aad89d63
    UID        : 0x203837304848570400490045
    UID        : 0x20383730484857040029004D
    UID        : 0x20383730484857040029004E
    WARNING:
    from all persons.
    Type "Yes" to continue: yes
    [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 23.842V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.842V, BOARD_CURRENT: -0.096A
    [0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.072A
    [0.054] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.48C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.080A
    [0.076] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.49C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.040A
    [0.092] (2) RPM: 0, PWR: 0, VOLTAGE: 23.844V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.844V, BOARD_CURRENT: -0.096A
    [0.121] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.064A
    [0.133] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.44C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.008A
    [0.153] (2) RPM: 0, PWR: 0, VOLTAGE: 23.840V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.840V, BOARD_CURRENT: -0.048A
    [0.178] (2) RPM: 0, PWR: 0, VOLTAGE: 23.841V, TEMPERATURE: 37.45C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.841V, BOARD_CURRENT: -0.064A
      nickanickN Offline
      nickanick
      wrote on last edited by nickanick
      @alex-kushleyev
      Result: --id 255 isn't supported by my voxl-esc-tools (bin version 1.9) — it scans, finds IDs 0–3, then exits with ERROR: Specified ESC ID not found. Running ./voxl-esc-spin.py --id 2 --power 0 works and I do see BOARD_VOLTAGE and BOARD_CURRENT printed. So the ESC is emitting the battery telemetry message correctly.
      But PX4 still never publishes battery_status:
      VOXL2 M0054, voxl-suite 1.6.3, 4× M0138-1 ESCs on firmware 39, tools 1.9
      BAT1_SOURCE = ESCs, VOXL_ESC_PUB_BST enabled in QGC
      POWER_MANAGER=none in /etc/modalai/voxl-px4.conf (was voxlpm; changed per the comment "use none for modalai mini-esc since the esc driver handles PM" — I have no voxlpm module, the ESC is my only sensing)
      px4-listener battery_status 5 → "never published", after systemctl restart voxl-px4 and a full reboot
      esc_status is healthy: 4 ESCs online, esc_voltage 24.055 (6S)
      Questions:
      • How do I verify VOXL_ESC_PUB_BST on the flight side? px4-qshell param show VOXL_ESC_PUB_BST doesn't return anything readable in my terminal, so I can't confirm the QGC write reached the DSP.
      • Does the voxl-esc driver poll ESC channel 2 for telemetry in my configuration? If its telemetry rotation depends on the motor mapping, could it be missing the one channel that sends the battery message?
      • Is POWER_MANAGER=none correct for the FPV 4-in-1 (M0138), or is that comment specific to the mini ESC (M0129)?
      • Eric KatzfeyE Offline
        Can you provide a PX4 log file? If you cannot arm and fly the drone you can issue px4-logger on to start a log file. Then, after a few seconds, issue `px4-logger off' to close the log file.
          nickanickN Offline
          nickanick
          Logging start time: 0:05:12, duration: 0:19:25
          Dropouts: count: 2, total duration: 0.0 s, max: 2 ms, mean: 1 ms
          Info Messages:
          metadata_events_sha256: 1fc3f385e1b9dac83a6f070abbb44917a26ac8128817b0a74e5155aa3da40ed0
          sys_name: PX4
          sys_os_name: Linux
          sys_os_ver_release: 68386303
          sys_toolchain: GNU GCC
          sys_toolchain_ver: 7.5.0
          time_ref_utc: 0
          ver_data_format: 1
          ver_hw: MODALAI_VOXL2
          ver_sw: 3e7db37f06278a7756531d926d8bac8a71c6555f
          ver_sw_release: 17694720
          ver_vendor_sw_release: 33588480
          Info Multiple Messages: [excluded_optional_topics: 39], [metadata_events: 1], [perf_counter_postflight: 1], [perf_counter_preflight: 1]
          Name (multi id, message size in bytes) number of data points, total bytes
          action_request (0, 11) 3 33
          actuator_armed (0, 15) 34958 524370
          actuator_controls_status_0 (0, 20) 2328 46560
          actuator_motors (0, 66) 11652 769032
          actuator_outputs (0, 76) 11653 885628
          actuator_outputs_debug (0, 76) 328227 24945252
          control_allocator_status (0, 52) 5827 303004
          cpuload (0, 25) 2331 58275
          cpuload (1, 25) 2331 58275
          esc_status (0, 336) 232935 78266160
          estimator_aid_src_baro_hgt (0, 52) 9183 477516
          estimator_baro_bias (0, 40) 2326 93040
          estimator_event_flags (0, 53) 1157 61321
          estimator_gps_status (0, 39) 1165 45435
          estimator_innovation_test_ratios (0, 152) 113035 17181320
          estimator_innovation_variances (0, 152) 113042 17182384
          estimator_innovations (0, 152) 113031 17180712
          estimator_sensor_bias (0, 118) 2981 351758
          estimator_states (0, 209) 1165 243485
          estimator_status (0, 114) 5827 664278
          estimator_status_flags (0, 91) 1158 105378
          event (0, 40) 856 34240
          failsafe_flags (0, 85) 2302 195670
          failure_detector_status (0, 22) 11653 256366
          home_position (0, 48) 89 4272
          hover_thrust_estimate (0, 41) 11 451
          input_rc (0, 71) 2330 165430
          manual_control_setpoint (0, 63) 5827 367101
          manual_control_switches (0, 31) 1163 36053
          offboard_control_mode (0, 14) 11653 163142
          parameter_update (0, 34) 3 102
          rate_ctrl_status (0, 24) 5827 139848
          rtl_time_estimate (0, 17) 1144 19448
          sensor_accel (0, 44) 1165 51260
          sensor_baro (0, 32) 1165 37280
          sensor_combined (0, 48) 193109 9269232
          sensor_gps (0, 124) 1165 144460
          sensor_gyro (0, 44) 1165 51260
          sensors_status_imu (0, 96) 5827 559392
          takeoff_status (0, 13) 4 52
          telemetry_status (0, 86) 1165 100190
          telemetry_status (1, 86) 1165 100190
          trajectory_setpoint (0, 64) 11 704
          vehicle_acceleration (0, 28) 23304 652512
          vehicle_air_data (0, 37) 5827 215599
          vehicle_angular_velocity (0, 40) 58257 2330280
          vehicle_attitude (0, 49) 23304 1141896
          vehicle_attitude_setpoint (0, 54) 23304 1258416
          vehicle_command_ack (0, 21) 2 42
          vehicle_constraints (0, 17) 3 51
          vehicle_control_mode (0, 21) 34958 734118
          vehicle_gps_position (0, 124) 2330 288920
          vehicle_imu (0, 56) 2330 130480
          vehicle_imu_status (0, 132) 1165 153780
          vehicle_land_detected (0, 20) 1165 23300
          vehicle_local_position (0, 167) 11653 1946051
          vehicle_local_position_setpoint (0, 64) 20 1280
          vehicle_rates_setpoint (0, 33) 58258 1922514
          vehicle_status (0, 66) 34958 2307228
          vehicle_thrust_setpoint (0, 28) 58258 1631224
          vehicle_torque_setpoint (0, 28) 58257 1631196
          yaw_estimator_status (0, 105) 1165 122325
            nickanickN Offline
            nickanick
            Log taken with PX4 running, flight battery connected, ESCs energised, aircraft disarmed on the bench. battery_status was still unpublished during this window
              Can you share the log file?
                nickanickN Offline
                nickanick
                @eric-katzfey The log is in #7. I am getting a privilege error when I try to attach the file in Quick reply.
                  Also share the output.txt file after running this: journalctl -u voxl-px4 -b --no-pager > output.txt
                    Can you upload the log file to https://review.px4.io/ and then send the link?
                      nickanickN Offline
                      nickanick
                      px4 log: https://review.px4.io/plot_app?log=31e428fe-d363-43c6-9cc3-236af2212533
                      Will post output.txt file shortly
                        nickanickN Offline
                        nickanick
                        Is there I way that I can share the output.txt file with you? https://review.px4.io/ doesn't take my output.txt file
                          The forum won't let you attach it in your reply?
                            nickanickN Offline
                            nickanick
                            Error
                            You do not have enough privileges for this action.
                            Also, the text is too long so I can't copy and paste the entire log here
                              Okay, shoot, let me see if we can get that fixed.
                                I sent an email to the address you have linked to this account.
                                  nickanickN Offline
                                  nickanick
                                  output.txt sent
                                    File:
                                    output.txt
                                      #21
                                      This is what Codex says:
                                      The root cause is a PX4 source-enum bug, not the ESC, baud rate, or VOXL_ESC_PUB_BST.
                                        - The supplied parameters select BAT1_SOURCE=2, meaning “ESCs”: /home/modalai/development/log_debug/no-batt-status/
                                          vehicle.params:5.
                                        - But voxl_esc constructs its battery object as BATTERY_SOURCE_POWER_MODULE (0): src/drivers/actuators/voxl_esc/
                                          voxl_esc.cpp:51.
                                        - The battery library publishes only when the driver’s source equals BAT1_SOURCE: src/lib/battery/battery.cpp:172.
                                        - Therefore 0 != 2, and every battery report is silently suppressed.
                                        This matches all the evidence:
                                        - VOXL_ESC_PUB_BST=1.
                                        - All four M0138 channels, including current-sensing ID 2, communicate at 2 Mbaud: /home/modalai/development/log_debug/no-
                                          batt-status/output.txt:279.
                                        - The flight log contains 232,935 healthy esc_status samples but no battery_status.
                                        - The forum test showed ID 2 reporting BOARD_VOLTAGE and BOARD_CURRENT, proving the ESC produces the special telemetry
                                          packet. This is the expected M0138 behavior documented in the ModalAI ESC FAQ (https://docs.modalai.com/voxl-escs/faq/).
                                        The proper code fix is one line:
                                        _battery(1, nullptr, _battery_report_interval,
                                                 battery_status_s::BATTERY_SOURCE_ESCS)
                                        As an immediate workaround with the existing binary, set BAT1_SOURCE to Power Module (0), leave POWER_MANAGER=none, restart
                                        voxl-px4, and check:
                                        That should publish, although the resulting topic will incorrectly identify its source as a power module. The one-line source
                                        change is the permanent fix.
                                      Can you try setting that parameter and see if it works?
                                        I think you need to keep BAT1_SOURCE set to 0.
                                          nickanickN Offline
                                          nickanick
                                          BAT1_SOURCE set to POWER MODULE in QGC fixed the problem.
                                          TOPIC: battery_status
                                          battery_status
                                          timestamp: 332496007 (0.011529 seconds ago)
                                          voltage_v: 23.70500
                                          voltage_filtered_v: 23.70641
                                          current_a: -0.08000
                                          current_filtered_a: -0.07003
                                          current_average_a: 15.00000
                                          discharged_mah: 0.00138
                                          remaining: 0.70196
                                          scale: 1.04008
                                          time_remaining_s: 673.87732
                                          temperature: nan
                                          voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
                                          max_cell_voltage_delta: 0.00000
                                          custom_faults: 0
                                          average_power: 0.00000
                                          available_energy: 0.00000
                                          full_charge_capacity_wh: 0.00000
                                          remaining_capacity_wh: 0.00000
                                          design_capacity: 0.00000
                                          nominal_voltage: 0.00000
                                          capacity: 4000
                                          cycle_count: 0
                                          average_time_to_empty: 0
                                          serial_number: 0
                                          manufacture_date: 0
                                          state_of_health: 0
                                          max_error: 0
                                          interface_error: 0
                                          faults: 0
                                          average_time_to_full: 0
                                          over_discharge_count: 0
                                          connected: True
                                          cell_count: 6
                                          source: 0
                                          priority: 0
                                          is_powering_off: False
                                          is_required: False
                                          warning: 0
                                          mode: 0
