  3. VOXL2 + VOXL ESC FPV 4-in-1, voxl-suite 1.6.3 — battery_status never published
Scheduled Pinned Locked Moved Solved General Questions
27 Posts 3 Posters 1.0k Views 3 Watching
  • nickanickN Offline
    nickanickN Offline
    nickanick
    esc_status is healthy: 4 ESCs online, esc_voltage 24.055 (6S pack). BAT1_SOURCE = ESCs, VOXL_ESC_PUB_BST enabled, POWER_MANAGER=none in /etc/modalai/voxl-px4.conf per its own comment ("use none for modalai mini-esc since the esc driver handles PM"). px4-listener battery_status 5 reports "never published" after a voxl-px4 restart and a full reboot. No esc_battery module in this build. QGC shows no battery, and the preflight reports -100%.
    What publishes battery_status from ESC telemetry on 1.6.3? Is the ESC path supported on the FPV 4-in-1 (M0138), or only the mini ESC?
    • Alex KushleyevA Offline
      OK, thanks for checking. maybe there was a typo before
        @nickanick ,
        Here is some background..
        The Mini ESC (M0129) and the FPV ESC (M0138) do not have individual channel current sensing (unlike M0134 ESC), so the individual ESC channel current is reported as 0, while each ESC channel still reports the measured voltage in the standard telemetry packet sent to the FC. For these two ESCs (M0129 and M0138), one of the ESC channels measures the total board current that flows through the ESC and sends out a second telemetry message with just voltage and total current. For M0129, the ESC channel 3 does this, and for M0138, channel 2 (0-indexed).
        The telemetry messages are sent from the ESC to the FC (VOXL2) via UART and is parsed in the PX4 in voxl-esc driver. In the voxl-esc driver, if the battery status telemetry message is received from the ESC and VOXL_ESC_PUB_BST is enabled, then the driver will publish the battery_status topic with the battery voltage and current from the ESC telemetry message.
        In order to do a quick test to make sure the ESC is sending out the battery status, you can do the following:
        • stop px4 : systemctl stop voxl-px4
        • test the ESC using voxl-esc tools (note that these tools are not part of px4):
        cd /usr/share/modalai/voxl-esc-tools
        ./voxl-esc-spin.py --id 255 --power 0
        Note that you will be running a spin test command (take off props for safety!), but the command is 0, so the motors will not spin, but you will see the telemetry from the ESC being printed in the terminal on voxl2. You will seeBOARD_VOLTAGE and BOARD_CURRENT being reported and that is coming from the extra telemetry message from the ESC. If you see this current printed, then the ESC is sending the correct information.
        The argument --id 255 will tell the test script to communicate with all 4 ESC channels and the commands will be sent and telemetry requested from all 4 ESC channels (including the channel that sends back the battery status telemetry message).
        Can you please check this?
        voxl2:/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 255 --power 0
        [GCC 8.4.0]
        VOXL Platform: M0054
        	Board      : version 40: ModalAi 4-in-1 ESC (M0129-3)
        	UID        : 0x2039333557555313000F0036
        	Firmware   : version   39, hash 9c6233d6
        	Bootloader : version  184, hash 10bf24c8
        	UID        : 0x2039333557555313000F0032
        	UID        : 0x2039333557555313000F0034
        	UID        : 0x2039333557555313000F0038
        WARNING:
        from all persons.
        Type "Yes" to continue: yes
        [0.015] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
        [0.015] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A
        [0.015] (2) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
        [0.015] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
        [0.036] (0) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
        [0.036] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A
        [0.036] (2) RPM: 0, PWR: 0, VOLTAGE: 16.059V, TEMPERATURE: 38.85C, CURRENT: 0.000A
        [0.036] (3) RPM: 0, PWR: 0, VOLTAGE: 0.000V, TEMPERATURE: 0.00C, CURRENT: 0.000A
        [0.059] (0) RPM: 0, PWR: 0, VOLTAGE: 16.039V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.059] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.24C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.059] (2) RPM: 0, PWR: 0, VOLTAGE: 16.059V, TEMPERATURE: 38.85C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.059] (3) RPM: 0, PWR: 0, VOLTAGE: 16.047V, TEMPERATURE: 38.86C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.075] (0) RPM: 0, PWR: 0, VOLTAGE: 16.039V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.075] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.075] (2) RPM: 0, PWR: 0, VOLTAGE: 16.065V, TEMPERATURE: 38.89C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.075] (3) RPM: 0, PWR: 0, VOLTAGE: 16.047V, TEMPERATURE: 38.86C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.047V, BOARD_CURRENT: 0.240A
        [0.101] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.19C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.101] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.101] (2) RPM: 0, PWR: 0, VOLTAGE: 16.065V, TEMPERATURE: 38.89C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.101] (3) RPM: 0, PWR: 0, VOLTAGE: 16.041V, TEMPERATURE: 38.91C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.119] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.19C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.119] (1) RPM: 0, PWR: 0, VOLTAGE: 16.054V, TEMPERATURE: 38.23C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.119] (2) RPM: 0, PWR: 0, VOLTAGE: 16.060V, TEMPERATURE: 38.88C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.119] (3) RPM: 0, PWR: 0, VOLTAGE: 16.041V, TEMPERATURE: 38.91C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.041V, BOARD_CURRENT: 0.232A
        [0.137] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.25C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
        [0.137] (1) RPM: 0, PWR: 0, VOLTAGE: 16.049V, TEMPERATURE: 38.22C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
        [0.137] (2) RPM: 0, PWR: 0, VOLTAGE: 16.060V, TEMPERATURE: 38.88C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
        [0.137] (3) RPM: 0, PWR: 0, VOLTAGE: 16.043V, TEMPERATURE: 38.90C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
        [0.156] (0) RPM: 0, PWR: 0, VOLTAGE: 16.044V, TEMPERATURE: 38.25C, CURRENT: 0.000A, BOARD_VOLTAGE: 16.043V, BOARD_CURRENT: 0.248A
          nickanickN Offline
          nickanick
          wrote on last edited by nickanick
          Attached is the output for './voxl-esc-spin.py --id 255 --power 0'
            nickanickN Offline
            nickanick
            voxl2-test-fixture (TF-M0054):/usr/share/modalai/voxl-esc-tools$ ./voxl-esc-spin.py --id 2 --power 0
            Detected Python version : 3.6.9 (default, May 22 2025, 20:54:22)
            [GCC 8.4.0]
            Board : version 42: ModalAi 4-in-1 ESC (M0138-1)
            UID : 0x203837304848570400480052
            Firmware : version 39, hash a58f5f6f
            Bootloader : version 187, hash aad89d63
            UID        : 0x203837304848570400490045
            UID        : 0x20383730484857040029004D
            UID        : 0x20383730484857040029004E
            WARNING:
            from all persons.
            [0.017] (2) RPM: 0, PWR: 0, VOLTAGE: 23.842V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.842V, BOARD_CURRENT: -0.096A
            [0.035] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.072A
            [0.054] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.48C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.080A
            [0.076] (2) RPM: 0, PWR: 0, VOLTAGE: 23.839V, TEMPERATURE: 37.49C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.839V, BOARD_CURRENT: -0.040A
            [0.092] (2) RPM: 0, PWR: 0, VOLTAGE: 23.844V, TEMPERATURE: 37.47C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.844V, BOARD_CURRENT: -0.096A
            [0.121] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.064A
            [0.133] (2) RPM: 0, PWR: 0, VOLTAGE: 23.843V, TEMPERATURE: 37.44C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.843V, BOARD_CURRENT: -0.008A
            [0.153] (2) RPM: 0, PWR: 0, VOLTAGE: 23.840V, TEMPERATURE: 37.46C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.840V, BOARD_CURRENT: -0.048A
            [0.178] (2) RPM: 0, PWR: 0, VOLTAGE: 23.841V, TEMPERATURE: 37.45C, CURRENT: 0.000A, BOARD_VOLTAGE: 23.841V, BOARD_CURRENT: -0.064A
              nickanickN Offline
              nickanick
              @alex-kushleyev
              Result: --id 255 isn't supported by my voxl-esc-tools (bin version 1.9) — it scans, finds IDs 0–3, then exits with ERROR: Specified ESC ID not found. Running ./voxl-esc-spin.py --id 2 --power 0 works and I do see BOARD_VOLTAGE and BOARD_CURRENT printed. So the ESC is emitting the battery telemetry message correctly.
              But PX4 still never publishes battery_status:
              VOXL2 M0054, voxl-suite 1.6.3, 4× M0138-1 ESCs on firmware 39, tools 1.9
              BAT1_SOURCE = ESCs, VOXL_ESC_PUB_BST enabled in QGC
              POWER_MANAGER=none in /etc/modalai/voxl-px4.conf (was voxlpm; changed per the comment "use none for modalai mini-esc since the esc driver handles PM" — I have no voxlpm module, the ESC is my only sensing)
              px4-listener battery_status 5 → "never published", after systemctl restart voxl-px4 and a full reboot
              esc_status is healthy: 4 ESCs online, esc_voltage 24.055 (6S)
              Questions:
              • How do I verify VOXL_ESC_PUB_BST on the flight side? px4-qshell param show VOXL_ESC_PUB_BST doesn't return anything readable in my terminal, so I can't confirm the QGC write reached the DSP.
              • Does the voxl-esc driver poll ESC channel 2 for telemetry in my configuration? If its telemetry rotation depends on the motor mapping, could it be missing the one channel that sends the battery message?
              • Is POWER_MANAGER=none correct for the FPV 4-in-1 (M0138), or is that comment specific to the mini ESC (M0129)?
              • Eric KatzfeyE Offline
                Can you provide a PX4 log file? If you cannot arm and fly the drone you can issue px4-logger on to start a log file. Then, after a few seconds, issue `px4-logger off' to close the log file.
                  nickanickN Offline
                  nickanick
                  Logging start time: 0:05:12, duration: 0:19:25
                  Dropouts: count: 2, total duration: 0.0 s, max: 2 ms, mean: 1 ms
                  Info Messages:
                  metadata_events_sha256: 1fc3f385e1b9dac83a6f070abbb44917a26ac8128817b0a74e5155aa3da40ed0
                  sys_name: PX4
                  sys_os_name: Linux
                  sys_os_ver_release: 68386303
                  sys_toolchain: GNU GCC
                  sys_toolchain_ver: 7.5.0
                  time_ref_utc: 0
                  ver_data_format: 1
                  ver_hw: MODALAI_VOXL2
                  ver_sw: 3e7db37f06278a7756531d926d8bac8a71c6555f
                  ver_sw_release: 17694720
                  ver_vendor_sw_release: 33588480
                  Info Multiple Messages: [excluded_optional_topics: 39], [metadata_events: 1], [perf_counter_postflight: 1], [perf_counter_preflight: 1]
                  Name (multi id, message size in bytes) number of data points, total bytes
                  action_request (0, 11) 3 33
                  actuator_armed (0, 15) 34958 524370
                  actuator_controls_status_0 (0, 20) 2328 46560
                  actuator_motors (0, 66) 11652 769032
                  actuator_outputs (0, 76) 11653 885628
                  actuator_outputs_debug (0, 76) 328227 24945252
                  control_allocator_status (0, 52) 5827 303004
                  cpuload (0, 25) 2331 58275
                  cpuload (1, 25) 2331 58275
                  esc_status (0, 336) 232935 78266160
                  estimator_aid_src_baro_hgt (0, 52) 9183 477516
                  estimator_baro_bias (0, 40) 2326 93040
                  estimator_event_flags (0, 53) 1157 61321
                  estimator_gps_status (0, 39) 1165 45435
                  estimator_innovation_test_ratios (0, 152) 113035 17181320
                  estimator_innovation_variances (0, 152) 113042 17182384
                  estimator_innovations (0, 152) 113031 17180712
                  estimator_sensor_bias (0, 118) 2981 351758
                  estimator_states (0, 209) 1165 243485
                  estimator_status (0, 114) 5827 664278
                  estimator_status_flags (0, 91) 1158 105378
                  event (0, 40) 856 34240
                  failsafe_flags (0, 85) 2302 195670
                  failure_detector_status (0, 22) 11653 256366
                  home_position (0, 48) 89 4272
                  hover_thrust_estimate (0, 41) 11 451
                  input_rc (0, 71) 2330 165430
                  manual_control_setpoint (0, 63) 5827 367101
                  manual_control_switches (0, 31) 1163 36053
                  offboard_control_mode (0, 14) 11653 163142
                  parameter_update (0, 34) 3 102
                  rate_ctrl_status (0, 24) 5827 139848
                  rtl_time_estimate (0, 17) 1144 19448
                  sensor_accel (0, 44) 1165 51260
                  sensor_baro (0, 32) 1165 37280
                  sensor_combined (0, 48) 193109 9269232
                  sensor_gps (0, 124) 1165 144460
                  sensor_gyro (0, 44) 1165 51260
                  sensors_status_imu (0, 96) 5827 559392
                  takeoff_status (0, 13) 4 52
                  telemetry_status (0, 86) 1165 100190
                  telemetry_status (1, 86) 1165 100190
                  trajectory_setpoint (0, 64) 11 704
                  vehicle_acceleration (0, 28) 23304 652512
                  vehicle_air_data (0, 37) 5827 215599
                  vehicle_angular_velocity (0, 40) 58257 2330280
                  vehicle_attitude (0, 49) 23304 1141896
                  vehicle_attitude_setpoint (0, 54) 23304 1258416
                  vehicle_command_ack (0, 21) 2 42
                  vehicle_constraints (0, 17) 3 51
                  vehicle_control_mode (0, 21) 34958 734118
                  vehicle_gps_position (0, 124) 2330 288920
                  vehicle_imu (0, 56) 2330 130480
                  vehicle_imu_status (0, 132) 1165 153780
                  vehicle_land_detected (0, 20) 1165 23300
                  vehicle_local_position (0, 167) 11653 1946051
                  vehicle_local_position_setpoint (0, 64) 20 1280
                  vehicle_rates_setpoint (0, 33) 58258 1922514
                  vehicle_status (0, 66) 34958 2307228
                  vehicle_thrust_setpoint (0, 28) 58258 1631224
                  vehicle_torque_setpoint (0, 28) 58257 1631196
                  yaw_estimator_status (0, 105) 1165 122325
                    nickanickN Offline
                    nickanick
                    Log taken with PX4 running, flight battery connected, ESCs energised, aircraft disarmed on the bench. battery_status was still unpublished during this window
                      Can you share the log file?
                        nickanickN Offline
                        nickanick
                        @eric-katzfey The log is in #7. I am getting a privilege error when I try to attach the file in Quick reply.
                          Also share the output.txt file after running this: journalctl -u voxl-px4 -b --no-pager > output.txt
                            Can you upload the log file to https://review.px4.io/ and then send the link?
                              nickanickN Offline
                              nickanick
                              px4 log: https://review.px4.io/plot_app?log=31e428fe-d363-43c6-9cc3-236af2212533
                              Will post output.txt file shortly
                                nickanickN Offline
                                nickanick
                                Is there I way that I can share the output.txt file with you? https://review.px4.io/ doesn't take my output.txt file
                                  The forum won't let you attach it in your reply?
                                    nickanickN Offline
                                    nickanick
                                    Error
                                    You do not have enough privileges for this action.
                                    Also, the text is too long so I can't copy and paste the entire log here
                                      Okay, shoot, let me see if we can get that fixed.
                                        I sent an email to the address you have linked to this account.
                                          nickanickN Offline
                                          nickanick
                                          output.txt sent
                                            File:
                                            output.txt
